Frigidaire crws5700aso washer. Timer can be heard, but does not start cycle. Every 15 minutes it will begin a cycle then stop seconds later. After a few hours it will start the cycle and continue all the way through.
SOURCE: SPIN CYCLE
Front load Neptune model
Posted on Nov 25, 2007
  • 125 Answers
SOURCE: frigidaire front load washer problems
most likely something is stuck in the pump. it could also be that you are not using high effiency detergent.
Posted on Jan 06, 2008
  • 130 Answers
SOURCE: Frigidaire (LTF2940E) Washer starts, stops, starts, stops...
The cycle doesn't advance When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Posted on May 07, 2009
  • 11 Answers
SOURCE: wfmc2100uc Bosch Washer
It could be the brushes on the motor or the belt has come off
Posted on May 09, 2009
VtToolMan
  • 704 Answers
SOURCE: timer gets stuck on frigidaire front load washer
It appears that your timer is failing. The process to remove and replace the faulty timer is relatively easy to do with just some simple hand tools.
You should unplug the washer from the wall outlet before taking the top backsplash (control panel) apart. There are screws on the backside of the control panel, that you need to remove the back panel. Doing this will let you get to the wiring plug connector on the timer motor.
You'll also need to remove the timer/cycle knob on the front of the panel so you can use a socket (or a adjustable wrench) to remove the mounting nut and lock washer that holds the timer to the metal panel.
Once you have everything loose and accessible, all you need to do is unplug the connectors on the old timer and out them on the new timer and reinstall the lock nut and washer and button up the panel.
That shoud be all that's needed to get things working again.
Here's link showing a drawing of your washer along wtih the parts list (and prices) for parts.
The timer is part #134378400 and costs about $89.00
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=FTF530ES1&productCategoryId=0153200&brandId=1428&modelName=WASHER&diagramPageId=00001&componentDescription=CONTROL%20PANEL&documentId=R0509003&backToLink=Return%20to%20Sub%20Components%20list
Hope you find this Very Helpful and best regards!
Posted on Aug 22, 2009
Testimonial: "Thank-you for the help I'll lt you know if it works after replacing timer. scott"
My frigidaire front load washer will start a wash, complete the first cycle but then stop and flash all the lights and beep continously until I press "start" or "cancel". If I press "start" again it just...
Hello there:
If your cycle does not complete or The cycle doesn't advance
When the cycle should advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. than check the cold water supply line and the filter
Aug 15, 2010 | Frigidaire ATF6000ES Front Load Washer
Frigidaire GLGT1031CS1 washer timer
Yes. Replace the timer and you are good to go.
Jul 05, 2010 | Frigidaire GLGT1031C Dryer
May 07, 2009 | Frigidaire GLTF2940ES Front Load Washer
Frigidaire washing machine gets stuck on cycles
Apr 01, 2009 | Frigidaire Washing Machines
Runs through the all cycles in 5 minutes!
Only the timer controls time, so it needs to be replaced. But usually they STOP turning. I've never heard of one going into fast forward.
Jun 11, 2008 | Frigidaire GLTF1670A Front Load Washer
My machine runs for 5 seconds and stops for 15 minutes
The spinning motor are not turning / try it manually /if okey / the timer contactor is malfunction.
Jan 09, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
Unit goes through any cycle in mere minutes
it could be drys on the modul its not the prgramer you will have to get your local applince second hand shop to take a look tell them it should take them 10 to 15 mins if there any good
Dec 14, 2007 | Frigidaire GLTF1670A Front Load Washer
Kenmore 44072 Front Load Washer help
my kenmore washing machine has the timer out of time
Aug 08, 2007 | Kenmore 44072 Front Load Washer
Washing Machines Logo
47 people viewed this question
Top Washing Machines Experts
