Question about Vacuums
Vacuim sweeper motor has a high pitch squeal otherwise runs fine
    Sergeant:
    Novelist:
  • 159 Answers
If you can notice a smell of burned rubber near the sweeper, then you most likely have a slightly stretched belt. The belt would be spinning against the beater brush, causing the squeaking noise -- as it heats up, the belt will begin to smoke, or at least give off the smell of burned rubber. This will be the most noticeable if you use the vacuum for a few minutes and then turn it off -- most times the suction from the vacuum will pull the smell into the vacuum and keep you from noticing it until it has been going on for quite some time. Replacing the belt should fix the problem.
Before going out and buying the belt, you might want to check between the belt and the beater brush -- if there is a lot of debris between the belt and the beater brush, it will cause the same type of slipping as a stretched belt, and could also be the cause of your problem. Either way, to fix the issue, you have to open the bottom of the vacuum and take a look at the belt -- if it looks to be in good shape, move it around a little. If it has a lot of room to move, it's probably stretched. If you notice a big hair clog under the belt, this is most likely to be your problem -- clean that out and you should be good to go.
Posted on May 26, 2011
Vacuum keeps up a high pitch noise when using the floor sweeper
A rotating dry-running ballbearing of the rotating brush or there is something something in the nozzle into the machine firmly beaten?
Feb 17, 2016 | Vacuums
Changed Belts, Changed Roller Bar, Still have High pitched, ear splitting squeal, is there a fix for this?
Remove belt and roller. Start motor- noise still there? If so noise is in the motor or caused by the motor.
Mar 09, 2014 | Hoover U6437-900 / U6439-900 Windtunnel...
Squealing noise from the top
Take the HEPA filter out of the ball. Run the machine without it and see if it quits. My guess is that it will. You can get some scissors and cut the rubber seal off the filter and re-install it and you squeal is gone.
Aug 08, 2017 | Dyson DC25 All Floors Bagless Upright...
HIGH PITCHED SOUNDS WHEN VACCUUM IS ON
Remove all filters and turn on the vacuum cleaner and check the hose for suction.If it has good suction turn it off and remove the belt.Turn it back on and if the noise is still there you have a motor bearing squealing.It's probably time to replace the vacuum cleaner if you have a motor problem.www.sewvac.com .Most of these box store models are designed for replacement if a major component fails.
Jan 28, 2011 | Bissell Vacuums
Sweeper wont pick anything up. When the motor runs it sounds like the belt is broke, but it is not. It revs real high. There are no clogs and the filters are clean. I have no idea what it is, and I...
to me it sounds like a blockage?having worked on these machines for so long,when the motor runs high as you say then its under pressure im not convinced you have cleared the blockage take another look ,i use a old wire coathanger straightened out to push the rubbish out,if that fails,go out and buy yourself a new machine you derseve it and you will be surprised at what the new machine can do..adrian,,,,
Sep 06, 2010 | Fantom Vacums FM741 Twister Bagless...
I have a Craftsman brand shop vac [model # 113.77420]. It is still picking items when I sweep with it, but it has developed a very high pitched squealing sound whenever I turn it on. The sound makes it...
I have the same problem with a CTC Shop Vac. It's he bearings ... they're worn out and dry ... no lubrication. I've trid taking the motor apart and lubricating the bearings, then it runs super for a few uses but then the squealing starts again. Oitch it and buy a new one.
Aug 23, 2010 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Lost suction high pitched squeal
the motor or the fan needs to be replaced.both are a lot of money.
Jul 04, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
High pitched sound when vacuum is on
You may be loosing your bushings on the motor,if this is an expensive machine it may be cheaper to have it fixed,if not it will burn up eventually.Also try taking the beater bar out and make sure you don't have something rapped around it causing a noise.
Hope this helped.Let me know by rating me
For more help go to live chat.
lenwest
Jan 19, 2009 | Dyson DC14 All floors Bagless Upright...
My Vacuum keeps cutting off after just a few minutes of use
You probably have a clog that is overheating your motor and tripping the thermal cutout. Check all air hoses and inlets for clogs. If all of your air pathways are clear, you most likely have a bad motor bearing, also indicated by a high-pitched squealing sound. If that's the case, it would require a motor replacement; which is not usually economically feasible.
-R
Aug 11, 2008 | Dirt Devil Vacuums
Vacuums Logo
117 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
