Question about Panasonic KX-T7630 Corded Phone
How do I program a button to turn on headset mode? I tried the following instructions but they didn't work... "My new TDA is still in the box, but try PROGRAM 511 STORE and then pick a button and press PROGRAM the button 67 STORE. When you press it, it should say HEADSET ON" Thanks.
  • Panasonic Master
  • 2,460 Answers
67 is for Bluetooth, which I doubt that you have. Try PROGRAM 61 Enter 1 Enter for on and 61 enter 0 enter for off.
Check your OM for specific instructions on assigning a button.
Carl
Posted on May 27, 2011
Is a Plantronics 220 headset compatible with a LG800G phone?
Try to put your headset in pairing mode, prior to trying to pair it with your phone. To do it, begin with it turned off. Then, if it is the first time it is being paired ever, just by turning it on (i.e. by pressing and holding the call button for some 2 seconds), it should enter the pairing mode. Otherwise, keep holding the call button past the turning on phase (a total of some 8 to 10 seconds), until its indicator light is flashing in red and blue, thus indicating it is in pairing mode. Either way within the next 2 minutes, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or passkey, or PIN) is requested, enter '0000' (four zeros). If the pairing process is successful, your headset should enter the stand-by mode. By the way, if its data sheet happens to be missing, feel free to download it from this location.
Really hope you are able to sort your problems out soon.
Anyway, please, let me know if I can help you any further .
Regards,
Carlos
Aug 19, 2012 | Plantronics Explorer 220 Bluetooth Headset...
Y isnt my headset work how do start motoralla defy wants to match with h350headset wirelass headsets
You must put your headset in pairing mode, prior to pairing it with your phone. In order to do it, starting with it turned off, press and hold the call button for some 6 to 10 seconds, until the indicator light is steadily lit (it will flash, as if you were turning it on, but don't release the button at that phase). Then, within the next couple of minutes, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes). If the pairing process is successful, your headset should enter the stand-by mode. On your phone, there could be an indication that a bluetooth device is connected too.
Hope it works for you.
By the way, if your headset's user guide happens to be missing, feel free to download it from this location.
Anyway, please let me know if you need further informations.
Regards,
Carlos
Apr 23, 2012 | Motorola Mobility H350 Wireless Headset
I've followed the instructions to change the names of the extension numbers but when I press PROG ** it just beeps at me and then goes into normal programming mode, rather than manager programming...
Keep pressing PROG ** until you find the phone that doesn't beep. In a basic TDA system, it's the first extension (101) that is the default master phone.
Carl
Sep 21, 2011 | Panasonic KX-T7636W Corded Phone
Can you find out 4 diget number if you cant remember it for this headset
Put your headset in pairing mode right before trying to pair it with your phone. In order to do it, start with it turned off. Then, press and hold the on/off button for some 5 seconds, until the indicator light is steadily lit (it will flash as it was being turned on, but don't release the button at that phase). It will be kept in pairing mode for a couple of minutes. Within that time span, make your phone's bluetooth application search for new devices. After a little while, your headset should appear on-screen. Select it and make it connect. If a pairing code (or PIN, or passkey) is requested, enter '0000' (four zeros, without the quotes).
Hope you are able to sort your problems out.
Anyway, please, let me know if I can assist you any further.
Regards,
Carlos
Aug 08, 2011 | Jabra Bluetooth Headset - BT2070
Just purchased a headset to use with my Mitel 5212 phone but I can't connect it. It's plugged into the back of the phone. All instructions i find tell me to press the headset key on the phone but I...
you have to program a headset button on the phone or hit the blue key (superkey) then hit no until you see headset mode then you can turn it on or off. if you don't see it you will have to login to phone system and program it.
Aug 05, 2011 | Mitel 5212 IP Phone
I have an LG phone and my Discovery 925 bluetooth from Plantronics won't connect anymore. When I have it in discovery mode my phones message states "no devices found."
You want to make sure that there is no other bluetooth interference on your phone and follow the instructions on the link for the Plantronics Discovery 925 (see page 4).
Good luck from Headsets Direct!
Jul 17, 2011 | Plantronics Discovery 925 Bluetooth...
Mitel 5224 Speakerphone not working
it is likely the phone is in headset mode. If you've got a headset button programmed, then it should be lit.... if so, press it and it should work for you.
If you don't, you might be able to use the blue superkey to either turn off headset mode or set a button.
Press the Blue superkey, Press an unused button in the two rows of buttons. Press the "Change Key" softkey (under the display). Press No until you see headset key... press Yes.
Press the superkey again to get out of the programming.
Now that you've got the key programmed for headset, press it, if it's lit, press it again. Test your speakerphone.
If this doesn't work, I believe you would have a defective phone and should report it to your system admin or telephone system vendor for repair/replace.
Sincerely,
Mark
May 31, 2011 | Mitel 5224 IP Phone
Hello, i cannot pair my jabra sp5050 to my htc desire hd phone. i have followed all the online instructions but cannot seem to "find" the jabra on my handset. thanks!
To get the Jabra SP5050 into pairing mode: Start with the unit turned off Press and hold the answer/end button Hold until the light starts blinking constantly, without pauses Release the button - this is pairing mode Your phone should be able to "find" it when it's in this mode.
May 13, 2011 | Jabra SP5050 Bluetooth Headset
I put the Voyager pro headset in the car and is turn on, after work, I back to my car and the headset light is out and I go home put in the charger that headset no light on and can turn on again, I try to...
What you probably need to do is turn off, then on, the headset. In today's push button happy society, sometimes we don't always follow the instructions the manufacturer provides. Please follow the instructions carefully in the link below for the Plantronics Voyager Pro+, paying particular attention to "Listen to the Voice" and "Tips." You should be up and running in no time.
Plantronics Voyager Pro+ User's Guide
Oct 27, 2010 | Plantronics Voyager PRO Bluetooth Headset
I am trying to use a headset with my phone but everytime I place or answer a call they can not hear me. Why?
Did you turn it on and program a button? My new TDA is still in the box, but try PROGRAM 511 STORE and then pick a button and press PROGRAM the button 67 STORE. When you press it, it should say HEADSET ON.
Does that work better?
Carl
Sep 10, 2010 | Panasonic KX-T7630 Corded Phone
Panasonic KX-T7630 Corded Phone Logo
127 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
