Mtd 22" Yard Machine Push Mower Logo
Posted on May 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Exhaust pipe from carborator cracked. cracked when removing and cleaning carborator. Where can I find a replacement.
Anonymous
Level 2:
Novelist:
  • Expert 222 Answers
  • Posted on May 27, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
222
Questions
6
Helped
102343
Points
424
My suggestion is to find a free junk mower someone is giving away and remove the part from it. MTD now makes almost every major brand mower on the market and most of them use a Briggs and Stratton engine of various sizes and an unbelievable amount of the parts are interchangeable. I've been refurbishing any and all old mowers that I can get my hands on and have even been taking the total junk ones as long as their not seized up, just for spare parts. Otherwise, find a local guy who works on power equipment and he can probably hook you up with the part from his own cache. Hope this helps. Good Luck.
James
I need to remove the exhaust manifold on the right side of a 94 4.9l engine in a cadillac deville. It has a broken bolt in the exhaust. What is involved in removing the manifold?
I suggest you use all new exhaust manifold hardware and torque new bolts to 20 Ft Lbs.
4.5L and 4.9L Engines
RIGHT
Disconnect the negative battery cable. Remove the air cleaner. Remove the exhaust crossover pipe. Disconnect the oxygen and coolant temperature sensors. Remove the catalytic converter-to-AIR pipe clip bolt. Remove the upper manifold-to-cylinder head bolts. Raise and safely support the vehicle. Disconnect the converter air pipe bracket from the stud and remove the converter-to-manifold exhaust pipe. Support the engine cradle with screw jacks and remove the rear cradle bolts. Loosen the front cradle bolts and slightly lower the Engine cradle. Remove the remaining exhaust manifold-to-cylinder head bolts, the AIR pipe, and the manifold. Clean the gasket mounting surfaces.
To install:
Install the exhaust manifold and replace the AIR pipe. Tighten the manifold mounting bolts to 16-18 ft. lbs. (21-24 Nm). Install the manifold-to-converter exhaust pipe and replace the converter air pipe bracket to the stud. Raise the Engine cradle and install the rear cradle bolts. Tighten to 75 ft. lbs. (102 Nm). Lower the vehicle. Replace the upper manifold-to-cylinder head bolts. Replace the converter air pipe to AIR pipe clip bolt. Connect the coolant temperature and oxygen sensor connectors. Replace the exhaust crossover pipe. Replace the air cleaner and connect the negative battery cable. Start the Engine and check for leaks.
Having a promblem taking off crossover exhaust pipe on a 2005 Buick rendezvous I tooken off the two front exhaust Then took bottom two bolt . But still fasten to something is there other bolts...
Thermostat? engine cooling?
2 engines, here, LYA adn LY7.
nobody here posts engine, why do that?
so ill post only for 1.
the LA1
here are the steps.
NO FSM Sux huh? nor an alldata.com account, why not that? 15 bucks?
STAT out.
Remove the air cleaner and duct assembly. Refer to Air Cleaner Assembly Replacement in Engine Controls - 3.4L.
Drain the coolant until the coolant level is below the thermostat. Refer to Cooling System Draining and Filling (Refer To List 1) .
Remove the crossover exhaust pipe. Refer to Exhaust Crossover Pipe Replacement (Refer To List 2) in Engine Exhaust.
Remove the radiator hose from the thermostat housing.
Remove the thermostat housing bolts and clean any sealer from the bolt threads.
Remove the thermostat housing and gasket.
remove STAT
next is crossover page.
Disconnect the battery ground (negative) cable. Refer to Battery Negative Cable Disconnection and Connection (Refer To List 1) in Engine Electrical.
Remove the throttle body air inlet duct.
Drain the coolant from the cooling system. Refer to Cooling System Draining and Filling (Refer To List 2) in Engine Cooling.
Remove the inlet radiator hose from the engine. Refer to Radiator Inlet Hose Replacement (Refer To List 3) in Engine Cooling.
Remove the thermostat bypass pipe. Refer to Thermostat Bypass Pipes Replacement in Engine Cooling.
Remove the exhaust crossover heat shield bolts.
Remove the exhaust crossover heat shield.
  1. Remove the exhaust crossover pipe studs/nuts.
  2. Remove the exhaust crossover pipe.
end , remove.
now the bypass pipe FWD cars SUCK
  1. Disconnect the left engine mount strut from the engine.
  2. Remove the heater hose from the bypass pipe.
  3. Remove the thermostat bypass pipe to throttle body nut.
  4. Use the J 38185 in order to remove the thermostat bypass pipe hose clamps (1,5).
  5. Remove the thermostat bypass pipe to cylinder head nut (3).
  6. Remove the thermostat bypass pipe bolt (4).
  7. Remove the thermostat bypass pipe hose.
  8. Remove the thermostat bypass pipe.
sigh.....
why not log in to alldata.com
read the page then ask ques tons that are not clear.
and next time post the engine type.
above is just 1 engine.
Gas smell coming from exhaust
May have to remove the fuel injectors & mail away
to be ultra sonic cleaned & flow tested
I suspect you need a new exhaust converter & oxygen
sensors--- once the fuel issue is solved
Why is a repair shop not your go to place for answers?
372 xp only runs on full choke. carboration, air, and fuel filter good. is their a vacume system for the carboration? am i missing something else?
There is a pulse to work the diaphram carb, this is a black pipe from the crankcase, to the pump cover on top of the carb, this feeds a positive and a negative pressure to the pump as the piston rises and falls, if the pipe is cracked, or has come adrift it will greatly effect the running
Where are the exhaust system bolts located?
Removal & Installation 2.2L Engine To Remove:
  1. Remove or disconnect the following:
    • Negative battery cable.
    • Heat shield.
    • Oxygen sensor.
  2. Raise and safely support the vehicle.
  3. Remove exhaust pipe from the exhaust manifold.
  4. Lower the vehicle.
  5. Remove the exhaust manifold mounting nuts from the cylinder head. chevy_cav_02-04_exmanifold.gif
  6. Remove the exhaust manifold.
  7. Clean the mating surfaces.
  8. Check for cracks, broken flanges and gasket surface damage.
  9. Use a straight edge and a feeler gauge. If the flanges or the mating surfaces do not align, the manifold is warped and should be replaced.
To Install:
NOTE: The manufacturer recommends using new exhaust system nuts.
  1. Install the manifold gasket.
  2. Position the exhaust manifold to the cylinder head. Exhaust manifold 2.2L 87953055.gif
  3. Install the new exhaust manifold nuts. Tighten the nuts starting from the center and working toward the ends to 110 in lbs (12.5 Nm).
  4. Raise and safely support the vehicle.
  5. Install the exhaust pipe to the manifold using a new flex coupler gasket.
  6. Install new exhaust flange mounting nuts.
    • Tighten to 33 ft lbs (45 Nm).
  7. Lower the vehicle.
  8. Install the oxygen sensor.
  9. Install the heat shield.
  10. Connect the negative battery cable.
2.4L Engine To Remove:
  1. Disconnect the negative battery cable
  2. Disconnect the Oxygen (O2) sensor electrical connector.
  3. Remove the (O2) sensor.
  5. Remove the exhaust manifold brace-to-manifold bolt and the oil pan nuts, if necessary. Exhaust heat shield 2.4L 87953051.gif
  6. Remove the upper heat shield. NOTE: Do NOT bend the exhaust flex decoupler more than necessary to remove it. Excessive movement will damage the flex decoupler
  7. Remove the manifold-to-exhaust flex decoupler fasteners.
  8. Remove the exhaust pipe.
  9. Carefully lower the vehicle.
  10. Remove the exhaust manifold-to-cylinder head mounting nuts/bolts. Remove the exhaust manifold.
  11. Discard the gaskets and/or seals. Clean the mating surfaces.
To Install:
  1. Install new exhaust manifold gaskets. Position the exhaust manifold on the cylinder head. Tighten the mounting bolts in sequence to 110 in lbs (12.5 Nm).
  3. Install the exhaust manifold heat shield. Tighten the mounting bolts to 10 ft. lbs (14 Nm).
  4. Install the exhaust manifold brace-to-manifold bolt and the oil pan nuts. Tighten the mounting bolts to 41 ft lbs (56 Nm) and the nuts to 18 ft lbs (24 Nm).
  5. Position the exhaust pipe to the manifold. Install the manifold-to-flex decoupler mounting bolts. Tighten to 26 ft lbs (35 Nm).
  6. Lower the vehicle.
  7. Coat the threads with a suitable anti-seize compound and install the O2 sensor.
  8. Connect the O2 sensor electrical connector.
  9. Connect the battery ground cable and check for leaks.
2helpful
2answers
How to change an exhaust manifold leak 7.5L
Right-Hand
Removal
  1. Remove spark plug heat shield (12A406).
  1. Remove distributor to spark plug wires (12286) using Spark Plug Wire Remover T74P-6666-A.
    1. Disconnect muffler inlet pipe.
    1. If equipped with secondary air injection, disconnect the secondary air injection check valve tube (9B480).
    1. Remove attaching bolts and right exhaust manifold (9430).
    1. Inspect joint faces for signs fo exhaust leaks, cracks or any defect that would make exhaust manifold unfit for use
Left-Hand Removal
1. Remove oil level indicator tube (6754).
  1. Remove spark plug heat shield.
  1. Remove distributor to spark plug wires using Spark Plug Wire Remover T74P-6666-A.
  1. Disconnect EGR valve to exhaust manifold tube (9D477). If equipped with air injection, disconnect the secondary air injection check valve tube.
  1. Remove attaching bolts and exhaust manifold (9431).
  1. Inspect joint faces for signs of exhaust leaks, cracks or any defect that would make the exhaust manifold unfit for use.
Installation
  1. Clean mating surfaces of right exhaust manifold or left exhaust manifold and cylinder head (6049). Clean mounting flange of right exhaust manifold or left exhaust manifold and inlet pipe(s). Clean mounting surface for air injection tube or right exhaust manifold. Apply light film of Premium Long-Life Grease XG-1-C or -K or equivalent meeting Ford specification ESA-M1C75-B to right exhaust manifold or left exhaust manifold.
  1. Position right exhaust manifold or left exhaust manifold on cylinder head. Install attaching bolts and washers, starting at fourth bolt hole from front of each right exhaust manifold or left exhaust manifold. Tighten bolts to 34-47 Nm (25-35 lb-ft), working from center right to both ends.
    1. Position inlet pipes to right exhaust manifold or left exhaust manifold. Install attaching nuts and tighten to 34-47 Nm (25-35 lb-ft).
    1. Position the secondary air injection check valve tube and the secondary air injection tube gasket (9C435) at rear of right-hand exhaust manifold. Install attaching bolts and tighten to 19-25 Nm (14-18 lb-ft).
    1. Attach the secondary air injection manifold tube (9B449) to left-hand exhaust manifold fitting (located under EGR tube). Tighten nut to 30-40 Nm (22-30 lb-ft).
    1. Attach the secondary air injection check valve tube to rear of right-hand cylinder head. Tighten bolts to 75-85 Nm (56-62 lb-ft).
      1. Connect EGR valve to exhaust manifold tube to left exhaust manifold, if removed. Tighten nut to 53-72 Nm (39-53 lb-ft).
      1. Install spark plug heat shield and distributor to spark plug wires.
      1. Install oil level indicator tube to left exhaust manifold, if removed. Tighten nut to 13-24 Nm (10-18 lb-ft).
      2. Start engine (6007) and check for exhaust leaks.
Hope this helps you...WF †
1helpful
2answers
What repair is needed to stop exhaust manifold leak and what do i need to do the at home repair
It depends on the leak. First of all - see if you can see any cracks on the manifold - telltale signs would be a visible crack and black residue around it from exhaust. If you see that the manifold should be replaced. - welding would be a possible alternative. If there are no cracks - check all the nuts and studs to make sure they are tight. Make sure the exhaust pipe is tight and not leaking at the connection. If everything looks tight and secure - change the exhaust manifold gasket. All of that could be done at home depending on your comfort leel with the tools and time available.
How do i change my thermostat on my 2001 pontiac aztek. also how do i remove the crossover exhaust pipe to get to the @#$%^ing thing?
Removal Procedure
  1. Disconnect the battery ground (negative) cable.
  2. Remove the throttle body air inlet duct.
  3. Drain the coolant from the cooling system.
  4. Remove the inlet radiator hose from the engine.
  5. Remove the thermostat bypass pipe.
  6. Remove the exhaust crossover heat shield bolts.
  7. Remove the exhaust crossover heat shield.
89160026
  1. Remove the air cleaner and duct assembly.
  2. Drain the coolant until the coolant level is below the thermostat.
  3. Remove the crossover exhaust pipe.
  4. Remove the radiator hose from the thermostat housing.
  5. Remove the thermostat housing bolts and clean any sealer from the bolt threads.
  6. Remove the thermostat housing and gasket.
Removal Procedure
89153578
My dirtbike shuts off when i pull the throttle
The problem is probably that your carborator is not clean or there is water down your exhaust pipes. Or something solidified in your gas tank. hope this helps
Apr 28, 2009 • Watches
4helpful
2answers
05 susuki forenza
Removal Procedure
1. Disconnect the negative battery cable.
2. Drain the engine oil from the engine crankcase.
3. Remove the exhaust flex pipe retaining nuts from
4. Remove the exhaust flex pipe retaining nuts from
the catalytic converter or the connecting pipe.
5. Remove the exhaust flex pipe.
6. Remove the oil pan flange–to–transaxle retaining
bolts.
7. Remove the oil pan retaining bolts.
8. Remove the oil pan from the engine block.
Cleaning Procedure
1. Clean the oil pan sealing surface.
2. Clean the engine block sealing surface.
3. Clean the oil pan retaining bolts.
4. Clean the oil pan attaching bolt holes in the engine
block.
5. Clean the oil pan scraper.
Installation Procedure
1. Coat the new oil pan gasket with sealant.
Important : Install the oil pan within 5 minutes after applying
the liquid gasket to the oil pan.
2. Install the oil pan to the engine block.
3. Install the oil pan retaining bolts.
Tighten
Tighten the oil pan retaining bolts to 10 NSm (89 lb–in).
4. Install the oil pan flange–to–transaxle retaining
bolts.
Tighten
Tighten the oil pan flange–to–transaxle bolts to 40
NSm (30 lb–ft).
5. Install the exhaust flex pipe.
6. Install the exhaust flex pipe retaining nuts to the
exhaust manifold.
Tighten
Tighten the exhaust flex pipe–to–exhaust manifold
retaining nuts to 35 NSm (26 lb–ft).
7. Install the exhaust flex pipe retaining nuts to the
Tighten
Tighten the exhaust flex pipe–to–catalytic converter
or connecting pipe retaining nuts to 35 NSm (26 lb–ft).
8. Connect the negative battery cable.
9. Install the oil pan drain plug.
Tighten
Tighten the oil pan drain plug to 35 NSm (26 lb–ft).
10. Refill the engine crankcase with engine oil.
Top Mtd Garden Experts
ZJ Limited
ZJ Limited
Sean Wright
Sean Wright
john h
Are you a Mtd Garden Expert? Answer questions, earn points and help others
