My laptop takes an age to boot up sometimes over 10 mins. I would like to wipe the hard drive and re install windows vista. The laptop came with vista pee installed so I do not have a boot disc. HELP,
    Sergeant:
  • 236 Answers
You didn't say the make/model of your laptop so this answer may not work for your specific laptop but then there is nothing to lose in trying it. Usually if the laptop comes with pre-installed windows and you have never loaded it with anything else, there will be a factory image in a hidden partition on the system's hard drive. On powering up the laptop, usually while the manufacturer's logo is showing on the screen, you would press the Alt-key and hold it down while pressing the F10 key repeatedly. This should access the laptop's recovery or restore to factory image procedure. Wait for it to load completely and then follow the on-screen instructions to do the restore. Note that the restore will erase all user data from the hard drive including any malware or viruses that might be on it. Once restore is complete, you will have to re-enter your initial system configuration again such as the windows user ids and passwords. Also, if you were accessing wireless, you would need to reselect the SSID of the access point, and re-enter the WEP/WPA key if encryption is being used.
Posted on May 26, 2011
Boot manager is missing on Satellite A105-S2051 laptop
Anything that the reps from Acronis did that you no longer want (together with all the information on the hard drive) can be got rid off by wiping the partition information on the hard drive. You will be given just such an option when you begin to install Windows 7 by booting off your Windows 7 installation DVD. You should not get any MBR error messages if you have correctly booted off an installation DVD. The errors you are getting indicates you are still trying to boot from a hard drive (that is probably "wiped clean" or new, and does not have an operating system installed).
Oct 08, 2017 | Toshiba Satellite A105-S2051...
Toshiba satellite notebook error 10-FC06-000D system windows vista
When dealing with this error (10-FC06-000D) message in Toshiba unit is very comment in the L300 series, I don't know if Toshiba is using cheaper hard drives or what but I see a lot of them with the same problem. If you have a Toshiba unit got to their website to check if your unit is still under manufacture warranty if it is you have some options send it to Toshiba direct they should cover the shipping but I'm not to sure, or take it in to any Best Buy or Future shop stores with your proof of purchase and they will send it out for you. This is a hardware problem that is related to the hard drive, I wiped the hard drive and all it's boot records still unable to reinstall the OS OK, I finally decided to use a test hard drive to reinstall the OS worked fine so there is something wrong with the hard drive that most likely would need to be replaced
Sep 11, 2012 | Toshiba Satellite P35-S611 Notebook
I dont know how to start the process of restoring factory settings on my laptop which is a - packard bell easynote r1005 - i cant seem to find the keys to start the ball rolling for a reset and i really...
To restore factory settings the process comes in 3 flavours from the factory. One way has a hidden parition on the hard drive. When you boot up you press and hold the F11 key (may be differ on yours) and it starts the pacardbell recovery manager. This should give you the options to save off documents and settings but will wipe out the windows directory and everything under it so don't save it there. It will give you a few other options on what to save or install. This can take it back to factory new but save your stuff. The next method next two actually are booting off of the recovery dvd/cd. You may have gotten one wit the unit or were expected to make one when you got it. This tends to be a bit more agressive when restoring and usually wipes out everything on C drive. Some versions will have the option of just doing the windows directory but don't count on it. The usual problem with the dvd's is that the drive won;t read them. The last option is to just use a windows install cd. You do have a valid windows serial number so as long as you match the type it should work. Sometimes you may need to find a OEM version to get the serial to work.
You sould be able to use the boot/F11 method. As long as the os isn't Vista that usually works just fine. Vista installs had errors.
Sep 02, 2010 | Computers & Internet
ADVENT 5431 RUNNING WINDOWS VISTA. SINCE BRAND NEW ON XMAS DAY THIS PROBLEM HAS OCCURED. WHEN STARTING THE LAPTOP, 9 TIMES OUT OF 10 IT DOSENT BOOT AND OPERATING SYSTEM NOT FOUND APPEARS ON SCREEN.WHEN YOU...
May I know whether the Hard Drive is listed in the BIOS? This issue will occur if the Operating System is corrupted or if the Hard Drive is failed. You can use the Windows disc and reinstall the Windows once. If the reinstallation process is not successful, then you may have to replace the Hard Drive.
Jul 04, 2010 | Advent Netbook
Windows Vista won't install on my laptop.
Hello
Is this a clean install or an upgrade?Sounds like a upgrade.
You may need to format or wipe your hard drive clean,then try to install.
Try to boot from the vista disc and choose the clean install method.
Remember you will loose everything on your laptop doing this kind of install.
Mar 21, 2010 | Microsoft Computers & Internet
How to install now os on my nec laptop and could not damage my laptop
To install a new OS like windows 7/Vista/XP set your laptop to boot from CD/DVD in BIOS put the disk in and boot your laptop then follow the on screen instructions. This will normally wipe the hole laptop unless you are planing on dual booting in this case you will need a free partition or hard drive to install the 2nd OS and it normal cases have the lower OS installed 1st
Tom
Jan 16, 2010 | NEC Computers & Internet
Can't restore, want to erase HDD and install over from scratch
You'll have to departition the hard drive. Also, copying Windows from another computer probably won't work.
Try running a registry cleaner. It can fix a lot of problems after having a virus or malware.
Aug 06, 2009 | Computers & Internet
Laptop hard disk using vista
First of all, you need the password. If the password was set in the BIOS, you'll have to take it to a Tech for disassembly so they can reset the password from the motherboard jumper set. If it's a Windows password for windows logon, Boot from the Windows CD and run FDISK to format and wipe the Hard drive for a New Windows Installation. You'll need to "Partition" the Hard Disk for Multiple Operating Systems.
If Vista is running, Login and goto Control Panel. Select Help and enter "Multiple Operating Systems" in the Search box. The information you need is there for Vista.
Jun 11, 2009 | Dell Latitude D600 Notebook
Pc wont boot after vista update
You need to boot in safe mode then do a Windows System Restore to before you installed the updates. You can try redownloading and installing them and if the problem occurs again, just repeat the process.
Feb 21, 2009 | Computers & Internet
Installing windows xp
You cannot install Windows XP over WIndows Vista. Microsoft has put a lock on the Vista software and will not allow you to downgrade to a lower software. The only way you can do it is to wipe your hard drive completely clean first with a disk deleting software or with the command "fdisk" at the DOS prompt. However, this is dangerous and I do not recommend it unless you have someone professionally trained to do it. It will wipe everything off of your disk and then you can load Windows XP.
Don't forget to rate his solution with 4 stars before you log out.
Jan 27, 2009 | Compaq Presario C700T Notebook
Computers & Internet Logo
David Payne
David Payne
