Question about Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner
T0893/713 error has come up on printer which says cannot recognise ink cartridges
    Problem Solver:
  • 19 Answers
Make sure that the cartridges are clear get a cotton swap with a little rubbing alcohol on it and wipe cartridges if dirty and where the cartridges go in. If dirty it will at times not recognize the cartridges.I have had the same problem with my all in one printer. Also if you fill your cartridges a certain number of times that also will cause not to recognize your cartridges. I hope that this has helped you.
Posted on May 26, 2011
My black ink button on my pixma mp495 printer is blinking. Why?
A B LED light denotes that the black ink cartridge is running low.
A C LED light denotes that the colour ink cartridge is running low.
If the alarm light is on (lightning bolt in a triangle) it should be accompanied by an error code.
Canon MP495 - Error Codes If the printer displays an error message, the following information should help to diagnose the problem.
The led screen on the printer will flash a letter E and will then be followed by two numbers:
Error Description More Info Error E02 The machine is out of paper or will not feed. Error E03 Paper jam or output tray is closed. More Info Error E04 The Cartridge cannot be recognised. More Info Error E05 The Cartridge cannot be recognised. More Info Error E07 Cartridge is not installed in the correct position. More Info Error E08 Ink absorber is almost full. More Info Error E13 The remaining ink level cannot be detected. More Info Error E14 The Cartridge cannot be recognised. More Info Error E15 The Cartridge cannot be recognised. More Info Error E16 The ink has run out. More Info Error P02 Carriage encoder error. More Info Error P03 Line feed error. More Info Error P07 The waste ink absorber is full. More Info Error P08 Print head fault. More Info Error P10 Print head fault. More Info Error 5100 Carriage Encoder error. More Info Error 5200 Print head fault. More Info Error 6000 Line feed error. More Info Error B200 Print head fault. More Info Error 5B00 The waste ink absorber is full.
Feb 24, 2015 | Canon PIXMA MP495 InkJet Printer
Canon mx350
Hello, your error is - U140 The ink cartridge
cannot be recognized.
A non-supported ink
cartridge is installed. Install
the supported ink cartridge.
Please check that you have the correct ink cartridge.
Nov 01, 2013 | Office Equipment & Supplies
Epson workforce 520 won't recognise ink cartidges
When replacing ink on the Epson Workforce 520, Ensure the cartridges have the correct/same number of gold contacts. Ive seen them with 7 and 9 gold square contacts and they were otherwise identical, and the ones with 9 contacts threw an "cartridge not recognized" error on the printer's dispay.
Feb 24, 2012 | Epson Workforce 520 Printer
Dell 942 AIO printer won't recognise black cartridge:
I think you purchased a black cartridge with bad electronics. Basically your cartridge can't communicate with your printer and you should exchange it for a new one. There is no way to "fool" your printer into accepting refills with bad electronics. What you can do is when you get the message that you aren't using genuine cartridges and it won't be able to estimate ink levels is to check the box indicating to ignore the ink levels.
Nov 13, 2009 | Dell 942 All-In-One InkJet Printer
Error message saying cannot recognise ink cartridges
hello
Double check to see if the cartridges that came with your machine are really the correct ones. And if they are then make sure they are snapped in securely as they must make a solid contact to read the cartridges. Also make sure the drivers and software are properly installed onto your computer.Also make sure that the tape that is usually on the cartridges to protect them in handling and shipping are removed before installation.
regards
Jul 13, 2009 | Epson Stylus NX400 InkJet Printer
Epson DX8400 does not recognise ink cartridge
on the ink cartridges there should be a little gold chip on them if they dont have that then your printer will not recognise the ink my best bet for you is to buy cheep and reliable placement epson ink or you can buy these ink cartriges which have tubes which feed ink into these replacement cartridges and i have got one of these my self and i would recomend these to anyone
Apr 15, 2009 | Epson Stylus DX8400 All-In-One InkJet...
Canon MP460 ink cartridge not recognised
Perhaps the chips in the cartridges have failed? In which case you may need to replace them with brand new cartridges. If that doesn't work you might need to send it for repair as the cartridges might have damaged your machine.
Apr 06, 2009 | Canon PIXMA MP460 All-In-One InkJet...
U150 Canon no cartridge recognised
Because these a refills inks the Chip things they are full so you must replace the cartridge with a new Canon one and the fault will go. If not just replace the chip with a new one!
Then your error u150 will go.
Sep 25, 2008 | Canon MP610 Photo All-In-One Printer
Printer wont recognise new colour cartridge
most common, is there is a tiny piece of lint or paper shred, has worked its way between the ink cartridge and the print carrieage connectors,
take the cartridges out and wipe down the connectors on the cartridge and carriage with a lint free cloth or lens brush
Isopropyl alcohol is a good residue free cleaning fluid,
if no all the connectors answer, the printer assumes a wrong cartridge
not a guarantee, just something to try
Sep 03, 2008 | Canon PIXMA iP1600 Printer
Epson Stylus Multifunction Inkjet Printer/ Copier/ Scanner Logo
1,340 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
