Tatung TLT3002S LCD tv, will not start up, power to tv,standby light keeps going from red to green to red
  • 1153 Answers
SOURCE: Pioneer SD-62A5 has red standby light, won't turn on
Check C258 video assy.
Posted on Aug 16, 2007
SOURCE: Sony KF-WE50
my front panel sound is not working.......?
how i can do this.?
Posted on Jan 05, 2008
davebies
  • 43 Answers
SOURCE: Sony KDF-E55A20 55 in. LCD... Problem red light flashes 5 times
A 5 blink error indicates a bad lamp driver. However a lamp may possibly cause this too. I suggest putting a new lamp in if you have one just to verify the lamp is not the problem. If it still fails with a new lamp then the lamp driver is the problem. This part should be replaced by a Sony authorized servicer. The lamp can be replaced easily by you. The lamp replacement instructions are in the TV's owners manual. Good Luck
Posted on Jan 06, 2008
thaurfen
  • 623 Answers
SOURCE: No picture but normal sound.
projection bulb needs replacement
Posted on Aug 11, 2008
mistersony
  • 320 Answers
SOURCE: standby light flashes 3 times
A 3 flash pattern indicates that either the lamp is not seated correctly or that the lamp door is not latched properly. It can also be a fault with the switches that sense whether the lamp is seated or the door is latched. Try reseating the lamp and relatching the lamp door
Posted on Oct 20, 2008
I have a new LG 32 LD450 TV. When the set is on, there is a green light in lower right. when set is off there is a red light in lower right. should this red light be there all the time, even when set if...
The red light means it's on standby mode but if you wish to turn off the red light you can just go to menu >option>power then choose standby light off.
Jan 08, 2011 | LG 42LH40 LCD TV
Dear sir/Madame, I?m having a problems with installing my PS3 on mine TV. TV that I?m using is a Tatung V32MCGI 32inch LCD. Problem I?m having is following. When I try to connect my PS3 on to my TV...
Have you tried "resetting" the ps3 with it hooked up to your hdmi port? When the ps3 is in standby (red light), hold the power button to power it on, however, dont let go, keep hold the button down for 5 or so seconds until you hear a beep again, let up and wait about 15 seconds and it should detect the hdmi port.
Brandon
Dec 09, 2010 | Sony Playstation 3 (PS3) Console
When I power up my LG LCD TV the power light continuously switches from green to red and the TV does not start up?
Hi,my name is John. Welcome to FixYa. Its going in to protection standby mode. Something in the high voltage is shutting it down. Try to unplug it , wait 30 minutes and try it again. Thanks for Choosing FixYa....John
Nov 26, 2010 | LG 32LP1DC 32 in. HDTV LCD
I have an LG 17LX1R LCD TV/monitor that won't go on. The power light on the TV flashed red . . . but that's it.
My LG 17LX1R had a almost the same problem. Red standby went to green for 1-2 seconds then back to red standy. Turned out to be bad caps on the power supply board. Yours is definately going to need to be opened up. Not a generic fix. You gotta ask yourself if its worth fiixing a 6-7 year old LCD tv with limited LCD life. New ones can be had for about $130-150.
Nov 06, 2010 | LG 17LX1R 17 in. HD-Ready LCD Television
Tv wont power up Standby light keeps flashing.
First step in any Sony LCD projector repair is bulb or lamp replacement. Fixes 95% of problems.
Taking apart and trying to measure things without a known good bulb is a waste of time and effort.
easyab
ConvergenceRepair.com
Feb 26, 2010 | Sony Grand WEGA KDF-60XS955 60" Rear...
Akai lct3201ad red standby light turns green then red again!
Symptoms of a Defective or dying Power supplies on LCD TVs.
1. Light(s) on the front panel are behaving not normal example, blinking, amber color or not steady, fainting, etc.
2. TV not turning ON properly.
3. TV turns OFF by itself.
4. Needs to be unplug to many times to make it work.
5. Humming or high pitch noise heard through speakers or at the back of the TV.
I repair these power supplies. Write to jah2mil@hotmail.com if you require further assistance
Feb 22, 2009 | Akai LCT3201AD 32 in. LCD Television
26PF8946/37 Red light
Hey habo,
The red light you are referring to most likely is the power indicator light. On many newer TV's this light will appear red when the TV is off or in "standby" mode, and green when the TV is in operation.
Please keep in mind that some TV models may use the power indicator light to notify owners of ay potential hardware problems as well, so you may wish to refer to your owner's manual documentation if you have been encountering any problems during TV operation.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jul 22, 2008 | Philips 26PF8946 26 in. HD-Ready LCD...
No power on Tatung V30DMTT Flat Panel
Sounds as if you have the same problem as mine where the 6 FET Transistors have blown. I took mine apart and found it too difficult to get in to fix it so am looking for a new power board.
Nov 19, 2007 | Tatung V30DMTT 29.6 in. LCD Television
Televison & Video Logo
60 people viewed this question
Top Televison & Video Experts
