Question about Crosley Dehumidifiers
Crosley model CDH40L, ser.# 01M30208961 My humidifier ran fine until just lately.. It had thrown the fan blade off, which I had put back on quite a few times... That started 2 yrs. ago. I have cleaned and washed off most every thing, the coils especially.. A few months ago it started switching itself off.. It will start right up, the compressor will kick in, then in about 5 minutes the fan starts slowing down, getting slower and slower... Seems like the fan motor gets warmer, then the dehumidifier shuts off! It will sit there until everything cools off?, then starts back up... This happens over and over, it gets warmer and warmer, shuts off and starts back up after it has set for a while, until I just shut it off all together .... I think it is the fan... Please tell me that is all it is??
  • 684 Answers
There must be some sort of deformity on the fan blade and this makes it unbalance. Unbalanced fan blade will surely affect the bushing of the fan motor which will tend to over heat during operation. You better replace both the fan and the blade.
Posted on May 26, 2011
Humidifier does not turn on
if your saying that the voltage drops to around 4 volts at the supply transformer at anytime , then id say the load (device connected) is too much for the transformer to supply this most likely is caused by an internal fault in the load (humidifier) also since its a water appliance id say a water leak might be a factor in that as well , taking a look under the cover of the humidifier 4 signs of a water leak (or past one) would be where id start
Nov 11, 2015 | Aprilaire Model 700 Automatic Whole-house...
Our daewoo humidifier model dhc-250 date made 02/04 runs but seems like voltage goes up and down if on low or high fan and cont. cleaned all out ran great last year but now runs can hear power click up and...
Quite frankly, from what you described, you may need to have the refrigerant gas in the compressor drained and recharged. As. it sounds like the compressor wants to turn on, but lacks the ability due to low refrigerant or a faulty condenser switch. Either one can be repaired. But, if you don't have the experience to deal with it, it's best left to the pros.
Hope this helped you to troubleshoot and solve the problem.
Jun 21, 2011 | Daewoo DHC250 Dehumidifier
How to clean filter
The de-humidifier is a niche product. Its only job is to remove moisture from air to alleviate the problems of mould and mildew. It is very similar in operation to a window air conditioner.
A dehumidifier though will add heat to the room, while an air conditioner will remove heat.
The de-humidifier is an appliance that requires regular maintenance. This may be because it’s icing up, overflowing, not removing enough moisture, or simply time for a good cleaning to maintain its efficiency. If you don’t feel handy enough to attempt this project contact your appliance repairperson.
The following is a step-by-step method used to return your de-humidifiers to its peak efficiency.
Tools required
1 Multi pocket container (old ice cube tray)
2 Long handled brush
3 Oil can
4 Rags
5 De-greaser or spray detergent
6 Selection of screwdrivers
7 New filter
1… Remove water collection bucket and put aside.
2… Remove the filter from rear of machine. Filer is usually within a frame and simply pops out. If no filter proceed to next step. If it is a disposable filter simply replace it with a new one. Other types are made in a plastic frame and can be cleaned and reused. To clean a filter lay it flat in the sink and sprinkle surface with powder laundry detergent. Plug sink drain and turn on hot water. Cover filter with enough water to submerge. Soak for 15 minutes. Remove from water and rinse. Hang up to dry while proceeding to next step.
3… Remove the rear grille from the main body of de-humidifier. If none proceed to next step. If there is resistance then look for hidden screws. If grille locks into cover proceed to next step. Once removed place the grille aside until later.
Tip: Dehumidifier may use different types and sizes of screws. Use ice cube tray to segregate.
4… Remove metal cover of de-humidifier to access inner workings. Cover screws may be difficult to see because are often painted to match body color. Usually two or three screws along each side of base. Once screws are removed lift the cover straight up. Use extreme caution at this point. Front grille may be secured to cover. Some fronts are put together like a puzzle. Parts often interconnect or are screwed to one another. If front grille lifts off with cover try to separate before proceeding. Front grille may lock into groove along front edge of cover. Avoid pulling off any wires from humidistat or indicator light.
5… When cover removed this will expose the heating and cooling coil. They may appear as one but are actually two separate coils in very close proximity. Both will need to be cleaned.
Use a narrow brush to remove surface dust and dirt from the front and rear surfaces of coils. Use an up and down motion to avoid bending fins. Area between two coils must also be cleaned. Use caution, the fins are soft aluminum and can be easily damaged. Once surface dirt is removed, spray with de-greaser or light cleaner. There is a good product on the market called HVAC cleaner. As the name implies it is meant for Heating, Ventilation, and Air Conditioner coil cleaning. If this is not available Fantastic Spray cleaner used in kitchens and bathrooms works quite well. Remove dirt and excess cleaner by slowly pouring warm water into fins. Do not allow the water to enter any electrical connections or components. As an added precaution cover the motor with one of the cloth rags to protect it from the water.
6… With cover, rear grille, and front grilles removed locate fan motor for oil holes. Add a few drops of oil to each end of the motor body. Use a general purpose (3in1) oil or clean motor oil. A #30 oil is sufficient. Three or four drops on both ends of the motor body are sufficient. Add the oil slowly, pausing a few seconds between each drop. If added too quickly over-lubrication will result.
7… Straighten any bent fins. Use a fin comb if available. If no fin comb then use something soft such as a Popsicle stick. Straightening the fins will increase the efficiency of the airflow through the coils. Use caution as these coils are filled with high-pressure refrigerant.
8… Wipe any dirt from fan blade using a soft rag. Do not bend blades. This would cause a vibration that would harm the motor.
9… Vacuum all surfaces including front and back of grille assembly. Vacuum underside of metal cover. Vacuum dirt buildup from base and any other exposed surfaces.
10… Drain any water left in the base and allow it to dry.
11… When completely dry plug in and test operation. On some models testing may require temporary override of bucket overflow switch. Test that cooling coil begins to sweat water within few minutes of operation. If everything appears okay unplug and reassemble. Insert water collection bucket slowly to avoid damaging float switch mechanism.
Jul 17, 2009 | Dehumidifiers
Humidifier Fan Doesn't Stop
RH at 70 % seems to me a little excessive you really should be working somewhere around 50 to 56% the fan has to move Air through the system.
I would like to know your room Air temp what is the Air temp comming off the system. what are your parameters.
Jun 08, 2009 | GE AHG40LA Dehumidifier
Dehumidifier won't run
After all that testing you have diagnosed the problem. It is the main circuit board. So there is not reason to do any more test. I would just get a new control board and off you go
Apr 21, 2009 | Haier HDN305 Dehumidifier
De Longhi DE220 De-Humidifier not collecting water
Hi there - you have to vacuum the filter several times. You can pull it out of the back left hand side of the unit. Vacuum it several times, and then start the unit on the lower fan setting, at a humidity level of around 60%. It will kick in after a bit, and then you can start adjusting the humidity level to where you would normally use it.
Sometimes - after you have vacuumed the filter, it still doesn't work. I used my fingers to pick lint off the filter, and ran a BIC safety razor over it as well, to try and get more out of the filter. You can also wash the filter in warm water, and leave it to dry over night. Don't put it back in until it's completely dry.
This will work! Cheers... E
Sep 12, 2008 | DeLonghi DE500 Dehumidifier
Problem with fan
just replace the fan motor is the proper fix. you may dissasemble the fan motor and it may run for a while but the cost of a compressor is not worth the cost of the fan motor
Apr 23, 2008 | Kenmore 54501 Dehumidifier
Kenmore 54501 dehumidifier
Try this:
Remove *ALL* screws first! (you'd be surprised....)
Take a SMALL screwdriver, or better yet, thin putty knife. CAREFULLY insert it where the back seems loosest (usually half-way up), keep the blade fairly flat against the side and slowly work down. There are probably little tabs that snap into the side, and you want to pry them out (away from the side) without breaking them. Figure on finding two per side, near the top and bottom.
Hope this helps
Jan 01, 2008 | Kenmore 54501 Dehumidifier
Does not collect water
ok Carmo
first remove the back of the unit and turn it on. it sounds like the fan motor may not be working.there by making the dehum get hot. make sure your filter and coils are cleaned. you may need a new motor. if so buy a new motor and fan blade.be careful with the 5/16th nut holding the fan blade. the blade might look good but you have to check the hole where it rides on the motor shaft. if you into the hole it should look like the letter "D" because the motor shat is shaped that way.---good luck
Nov 11, 2007 | Kenmore 54501 Dehumidifier
Parts
What is the model # from the sticker on the unit? I'll see if I can help.
Nov 03, 2007 | Dehumidifiers
Dehumidifiers Logo
32 people viewed this question
Top Crosley Dehumidifiers Experts
Bill Long
Gil Shultz
jasbo
jasbo
Are you a Crosley Dehumidifier Expert? Answer questions, earn points and help others
