I cant get factory settings on my computer My hard drive wont work properly Ihavent got any memory.Computer very slow Please explain in laymans terms Obliged
  • 44 Answers
Please explain in detail what you are experiencing as far as the computer symptoms. If you computer is acting slower than it has before, than you could have a virus or spyware on your computer taking up the processor capabilities. Meaning the software that is hidden on your computer is slowing your computer down. On the other side it could be too much info on your hard drive. Just run "disk clean up" in your start/programs/accessories/systemtools/diskcleanup. I suggest getting virus software at a store or download it.
Posted on Aug 16, 2008
  • 185 Answers
In ur c: or the drive which is having the OS may be almost full,so the system perfomance is slow,u need to delete the temp files,files in system volume information and files in recycle bin. try this software cclean it may helps u to clean the above files.get the software from the link given below.
http://www.ccleaner.com/
  • 56 Answers
1. Factory settings on computer.
There really isn't "factory settings" to reset. Well it isn't simple as that. There is the BIOS which can be reset to "default settings" for the BIOS. Also most brand name computers come with a recovery feature, in which you can recovery/restore the computer back to original factory defaults with original software all installed. Therefore the computer's operating system (usually windows) will be running with the programs like it would run if you were to buy the same new laptop.
2. Hard drive won't work properly.
You can give the hard drive a test using the hard drive's company's hard drive testing software which can be download from their site. The software would test the hard drive to make sure nothing physical is wrong and the hard drive is functioning like normal.
3. Haven't got any memory. Computer very slow.
You can always buy more memory. If windows says it's running out of memory. That means there is too many software running in the background.
Comment if you want more explained.
Im a owner of a simpledrive model no. 96300-41001-065 1tb external hard drive for my mac. when i first got it it worked fine. today it decided not to work for me... when i turn on my computer, it doesn't...
drive may have gone bad. the enclosure or enclosure electronics may be at fault and drive may be good
do you have a different computer to test it in?
Are you sure the power supply is providing proper voltage?
Apr 23, 2017 | Computers & Internet
Lap top wont start up
first download an antivirus or anti malware, then run it into safemode, scan your laptop., then if this thing did not help, the solution to youre problem is to restore it to default factory settings.
Jun 26, 2010 | Toshiba Satellite A205-S5879 Laptop
17 inch monitor goes blank
  • Prepare to diagnose the computer .
    1. Disconnect all peripheral devices.
    2. Perform a Hard Reset.
    3. Disable the Automatic restart on system failure option.
  • Remove any non-system disc from the computer . During startup, the BIOS checks different devices to locate the Windows operating system. If the boot order is set to check the optical disc drive or the card reader (if the notebook is equipped with a card reader) before it checks the hard drive, and there is a non-system disc in the CD/DVD drive or there is a memory card in the card reader, the boot will fail. This problem can be resolved by setting the BIOS to check the hard drive first.
  • Reseat the memory modules . If you are getting memory errors, most BIOS versions have additional tests that can be run to test the memory. There could be a problem if one of the sticks is defective or loose in the memory slots. To determine what is causing the memory failure, disconnect all electrical power, and then remove and re-insert the memory modules firmly into the slots. Some HP Notebook PCs come with two sticks of memory and have two memory slots. On most notebooks, the memory module compartment is located on the bottom of the case, but the exact position varies by model. On some models, the memory compartment is under the keyboard. See your User Guide for the exact location of memory modules on your notebook.
  • Reset the BIOS to default condition . If you have made changes in the BIOS setting, such as disabling a device or changing the boot order, it could prevent the computer form starting properly. To restore the BIOS to its factory-recommended settings, turn on the computer and press f10 to access BIOS setup, and then press f9 to load the default BIOS configuration.
  • Perform a memory self test . There are different reasons that you may see a memory error. There could be a physical problem or it could be a program error. If the error is a program error, you will most likely see a Windows error message. If there is a physical problem with a memory module, the computer may fail part way through the boot process. Most computers have a built-in memory test to help identify if the memory modules are seated properly and are free of errors. To run the memory test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Start-up Test to run the system memory test. Press the Esc key once the memory test is complete.
    • If the BIOS Diagnostics screen displays, select Memory Test .
  • Reseat the hard drive . If you get a specific hard drive error message on a black screen indicating the hard drive error, reseat the hard drive. If the computer has been dropped or jarred, or the hard drive has been replaced recently, the drive may not be seated tightly. The hard drive LED should blink if the hard drive has a solid connection in the notebook. Refer to the on-line User's Guide for specifics on locating and removing / replacing a hard drive. HP provides video directions for performing this task for many computer models. Remove and reseat the hard drive firmly into the mounting bracket.
  • Test the hard drive . If you get a hard drive error message, you can test the hard drive. Many computer problems are related to soft failures (or degraded performance) on the hard drive. The HP Hard Drive Self Test will repair soft errors on the hard drive, but it will not report the errors. After the test is complete, restart the computer to see if test repaired the problem you may been experiencing. To run the hard drive test, turn on the computer and press f2 .
    • If the System Diagnostics screen displays, select the Hard Disk Test to run the hard drive test. Allow the Quick and Long Hard Disk Self Tests to run.
    • If the BIOS Diagnostics screen displays, select Primary Hard Disk Self Test . Allow the Quick and Long Hard Disk Self Tests to run.
  • Feb 04, 2010 | X2Gen MG19MY 19" LCD Monitor
    Cant format my Hard drive to work with mac and pc
    Unfortunately when you format a hard drive it deletes anything on it so if you did this after putting the documents onto it they are now gone.
    Jan 30, 2010 | Western Digital Passport 320GB External...
    Computer is very slow websurfing, would changing the hard-drive from 100 gb to 320gb help alot with this, and if so, will I loose all my stored info?
    you can check to see how much free space you have on your 100 gb drive ... just right click on the C: drive icon .. and then select "properties" .. if you have lots of space left then thats not your problem and a new 320 gb wont help .. if you see that you are running out of space (like less than 10 or 20 gb) then it will help .. you can transfer or ghost your entire drive over to the new drive if you have the proper equipment .. or if you take it somewhere to have it done .. you may have to reregister your operating system but that only takes a phone call or an internet click .. much more likely your computer is full of spy and ad-ware unless you have a good security suit that takes care of that sort of stuff ... if you dont have any anti spy-ware program then "spybot search and destroy" is a good start and its free ... some anti virus programs can really slow a computer down .. if you have a good one stick with it .. if you dont then AVAST or AVG are really good and free ... if you havent done so you can "clean up your hard drive" .. that includes getting rid of temporary file clutter and defragging the hard drive ..you should do that every couple of months or schedule it to happen at set intervals .. check how much memory you have .. most computers today should have 1gig or more memory .. if you have only 256 or 500 meg then things will run slow .. depending on what your operating system is .. XP will work ok on 500meg Vista wont .. ...both can benifit form increased memory ..
    Nov 22, 2009 | Sony VAIO VGN-FE550G Notebook
    Boot failure Asus P5Q-EM
    Disk boot failure. Issue:Disk boot failure.
    Cause: This issue could be caused by any of the below possibilities.
    1. Boot options are not set properly in CMOS
    2. Non bootable disc or USB in computer
    3. Remove added hardware /check connections
    4. Hard disk drive is bad
    Solution:Boot options are not set properly in CMOS
    Verify that the boot options within CMOS are set properly. Below is an example of how we recommend the boot options be set. Additional information about how to enter CMOS can be found on document CH00192.
    1. Floppy drive
    2. CD-ROM drive
    3. Hard Drive
    4. Other / Network
    Non-bootable floppy diskette or disc or USB in computer
    Verify that there is no floppy diskette or disc in the computer. If the boot options are set improperly the computer could be trying to boot from the disc drive instead of the hard drive.
    In addition to verifying there is no disc in the computer make sure that no USB jump drive, external hard disk drive, or memory stick is inside any memory card reader.
    If you're wanting to boot from a floppy diskette, CD, DVD, or USB drive and are getting this error message and have verified that your CMOS settings are in the proper order as explained in the above paragraph the diskette or disc you're using is either bad or does not have the proper files on it to make it bootable.
    • Additional information about how to make a boot disk can be found on our boot disk help page.
    • See document CH000669 for information about creating a bootable disc.
    Remove added hardware / check connections
    If you've recently installed any new hardware it's suggested that it be removed to verify it's not causing this issue. If after the device has been removed the computer works and it was another IDE / EIDE device ensure that the jumpers are properly set on the hard disk drive.
    In addition to removing any new hardware it's also suggested if you've recently moved the computer or installed anything inside the computer that the connections for the drive be checked. Usually it's best to simply disconnect the cables from the back of the drive and reconnect them to make sure they're connected properly. While inside also disconnect and reconnect the cable connected to the motherboard as well. While inside your computer make sure you're aware of ESD.
    Bad hard disk drive
    If you have followed the above steps and you continue to experience the same issue, unfortunately it is likely that the hard disk drive is bad or the controller is bad.
    If available, you may want to connect another known good hard disk drive to the computer to determine if it can be detected. If it is able to be detected then replace your hard disk drive. If it is not detected, unfortunately you will need to replace the motherboard or controller as it is bad.
    If no additional hard disk drive is available it is recommended that the hard disk drive be replaced first or that the computer be serviced / repaired.
    Jul 01, 2009 | ASUS P5QL-EM - Motherboard - micro ATX -...
    Low memory slow running video/audio programs host process stop working
    The most common reason for slow processing speed is insufficient RAM memory.
    Increase the RAM, if RAM available is no more than 512MB, then it must be upgraded.
    Check also your hard drive state. If you have less than 1GB free, that will slow down the system. Go to Start>>Programs>Accessories>System Tools>Disk Defregmenter and do a Defrag of the hard disk.
    If you have at least 1 GB RAM, and you took care of the hard drive, then you can check the process starting up on their own and remove the useless one, or spot mala-ware that can affect speed. You can use a software like Hijack This, and search on google te function of each process started on the list reported by the software.
    You can download Hijack this here MajorGeeks | If download does not start, then click at the top of the page, where it says Click Here If It Does Not.
    Be careful if you delete the wrong files using this software you can harm the system, and Windows may not work properly.
    If you think you have malaware you can also install Spy Bot, and do a system scan. Download Spybot from The home of Spybot.
    If all the above does not work, and there is no malaware, then you usually reinstall the system.
    Check also the bios settings, BIOS can downgrade the CPU speed on default , even if this is uncommon on recent BIOS.
    If a computer is still slow with a fresh system and enough resources then it is one of those rare occasions when you have an hardware fault.
    Hardware that can cause slow down is: RAM CPU Motherboard HD Video card.
    Some tips on procedure can damage your windows installation. Do not download Hijackthis software and do not change BIOS settings and do not touch hardware unless you are sure of what you are doing.
    May 17, 2009 | Acer Aspire 5520-5908 Notebook
    C drive memory Asus Eee pc 901
    I assume you download using firefox. There is a guide how to change default download folder/drive:
    http://www.lytebyte.com/2008/05/27/how-to-change-default-download-location-in-firefox-3/
    Apr 25, 2009 | ASUS Eee PC 900 Notebook
    Toshiba Satelitte 100/105 series won't boot up. When you turn it on it does the loading your settings, show desktop background, and then logs you off. We have tried removing the power and holding down the...
    have u got factory backup disk for OS , actually i just repaired my laptop affected by Conficker , so u just need the factory backup OS disk to repair ur pc otherwise changing hard drive in this case wont help conficker cant damage the hard drive it just stops some policies and services and make ur computer slow and un usable with out network access dont worry just get a backup disk and install it
    i can guide u thru if u want me !
    Apr 06, 2009 | Toshiba Satellite A135 Notebook
    I dont find it
    First, have you tried it in another computer? Take a look here, problems with other external hard disk drives are explained- unfortunately they don't suggest any easy fixes. http://www.dataclinic.co.uk/data-recover... These external drives, according to this site, and my own limited experience, are merely a standard drive in a housing with the proper adaptive circuitry for USB/Firewire connection. It looks like your unit uses a drive more like what would be found in a laptop, where others use what is used in a standard desktop computer. One possibility: open the housing, check the connections to the drive. I've seen one drive where the IDE interface cable wasn't seated properly. If what the above link explains is the problem with your drive, a simple solution looks bleak. You could try some of the diagnostic software available on the 'net. I'm sorry no easy fixes are provided.
    Aug 20, 2007 | Teac (HD10U8/KIT) (HD10U8KIT) 8 GB Hard...
    Computers & Internet Logo
    155 people viewed this question
    David Payne
    David Payne
