Question about Traulsen ADT132WUT-HHS Stainless Steel Commercial Refrigerator
The freezer suddenly warm up from -2 degree to 18.4 and the display shows some sort of call Service. What to I need to do besides calling for service. It has been working fine.
Noggin
  • 944 Answers
SOURCE: Fridge working fine, But freezer will not go below -8 degrees
It does sound like you have a low refrigerant gas problem - only way to be sure is get a service guy to check. If you notice particularly cold parts on the wall of the fridge or freezer, rather than the more even cooling that would be normal, then this is almost certainly the problem, and should be easily enough fixed by a qualified technician. The other possibilities are: The thermostat in the freezer could be faulty -hard to test without the right gear, but just check that the temperature adjustment knob for the freezer if it has a rotary one hasn't slipped on its shaft - this would give you a different temperature than the setting you have set. Check the freezer door seal/hinge and make sure it is sealing properly all around especially at the bottom - only a small gap can make a big difference Check the back of the unit is getting enough ventilation - it should get fairly hot normally but if the ventilation is restricted then the heat has nowhere to go and the freezer wont cool completely - if there is a lot of dust on the back then give it a gentle brush - the pipes are quite fragile so be gentle. If you havent defrosted the unit for a while, try that - leave it open and off at least overnight until there is no difference between the temperature inside and outside - sometimes small amounts of moisture in the refrigerant gas can freeze into crystals and block or partially block the gas system, once they defrost they should be dealt with further round the system by the filter/drier and hopefully will no longer be a problem Hope this helps :)
Posted on Apr 21, 2007
  • 139 Answers
SOURCE: Freezer ok fridge warm (15 degrees)
You have a hotpoint mistral f/f i take it in silver..
Check to see if the fan is running at the bottom on the back of the fridge its next to the compressor behind the panel ...
if the compressor is running and the fan is not then your fault is the fan..
IF the fan is running then its the sensors...
These are located in the freezer section, pull out the draws and remove the panel behind it.... six screws.......... you will c threes plugs at the top ledt hand side.. the yellow one is for the fridge the green one for the freezer.... replace both if your freezer is not working...
Also just below the freezer door there is a panel remove the panel and use a vaccumm to clean the fluff that has built up on the coils..
hope this helps if you need anymore help dont hesitate to ask...
by the way the sensors are called evap thermistors...
Posted on Jan 11, 2008
22yooper
  • 828 Answers
SOURCE: compressor making a loud noise, freezer cannot cool
It sounds to me like the internal relief valve is lifting due to discharge pressure being to high such as it a system that is over charged with refrigerant. Have the system tested for pressures on high and low sides. If someone has serviced this unit recently there may be to much of a charge in the system. Also check the name place for the proper refrigerant and charge .
Posted on May 19, 2008
SOURCE: Fridge is warm, Freezer working ok
I had the same problem , you have to clean your freezer compartment out completely and take the covers off the inside back of the freezer being carefull not to break any wires, then defrost the cooling module by hand hot water towels messy job.
Make sure the cooling sensor is attached in the right spot and hasn't fallen down, it has a plastic holder it clicks into.
once clean and defrosted put back together and it will be fine...
Try not to put any frozen chip bags or peas etc right at the back of the freezer this causes the cooling system to freeze up.
How the system works it blows cold air from the freezer compartment down to the fridge to cool it and when the system freezes up no cold air to fridge ,hense the problem you are having...
If you are not confident in doing the job you can call a fisher and Paykel tech and they will charge you $150 to do the job.
Posted on Oct 24, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
What does the temp display on the freezer tell me?
unless this is a dedicated freezer only and not a side by side or over/under , there's no way it's going to get down too 0 degrees inside a warm home , nope not gonna happen
also its not good for you to set this there as compressor wont cycle properly there and entire freezer will ice up , then believe it or not it will get warmer not colder wastes a lot of power as well
Sep 10, 2015 | Freezers
Good day. My Samsung fridge/freezer SR-S22FTFB runs normal for the first few hours when been switched on, both fridge and freezer temperatures were set for (- 18 and 2), both fans are running and when
Hello Danie;
My name is Peter. I am a retired field service refrigeration technician.
The normal setting for a freezer is -2 to +2 degrees F., and the normal setting for the fresh food section is +35 to +40 degrees F.
You only have one source of cooling and that is your freezer. With the settings that you have, you are asking your unit to do what it is not designed to do.
The ice maker is struggling because if it is a cast steel ice cube mold, the heater beneath it is not designed for the current to break the ice cubes free @ -18 degrees F., or if you have a plastic flex ice cube mold it is too ridged to flex enough to break the ice cubes free. Normally your ice maker should dump 8-10 times in a 24 hour period.
A note on food storage. Make sure you do not overload your freezer of fresh food section to the point where food product extends beyond the edge of the shelves.
Nov 17, 2014 | Samsung Freezers
Freezer is set on -2 degrees, actual temp in freezer is -20. What sensor is causing this problem
I suspect that you do not have a problem. . The standard operating temperature of a freezer is around -20 degrees CENTIGRADE (-2 Farenheit)
Your freezer has an option to display degrees C and degrees F, I suspect it is showing farenheit
I have taken a look at a copy of the manual, which can be found at:
http://www.manualowl.com/m/Samsung/RF217ABBP/Manual/142915
But for the life of me, I can't see how to change the display from C to F and back anywhere in the guide. If I am right, swapping the display back to Farenheit will solve the display issue.
If you are unable to change the display, you can try calling Samsung in arlington NJ on 1-800-726-7864.
Hope this helps. Please add a comment to this thread to let me know if the problem is solved or if you need more help
Sep 15, 2011 | Samsung RF217ABBP Bottom Freezer French...
I have a westinghouse upside down fridge what tempereture should it be for freezer/refrigerator? cos its pretty to cold like bit of ice goes in the meat packages.
The fridge should be between 2 and 5 degrees C or 36 and 41 degrees F and the freezer should be between -18 and -25C and 0 and -13 defgrees F. If you cant get the temp right then call a service engineer asazp.
Sep 10, 2009 | Westinghouse Refrigerators
Whirlpool 6 sense model WSC5513- A+ X side by side, without ice or water dispenser. Refrigerator part not cooling properly. Temperature setting is -18 degrees Celsius for the freezer and 2 degrees...
The temp for the fridge is about right and -18 for the freezer is ok so check to see if the water filter is plugged, at 8 degrees Celsius is about 18 degrees fht. Which is freezing so the numbers don't add up. 26 degrees below zero on the freezer side is what you want if it that cold it could have frozen the water line.
Aug 20, 2009 | Refrigerators
Profile Artica Freezer is warming up to 32 degrees
There are 2 dials in a refrigerator. One is the thermostat the other is the air damper between the freezer and the refrigerator section. make sure your air damper is open about 1/2 way. If air does not get from the freezer to the refrigerator the thermostat might not be reading a proper temp. If you open the damper to much then you can start freezing food in the refrigerator. Some refrigerators have a opening back to the freezer down behind or beside the chrispers sometimes a paper or wraper can get down there and block air off from returning stoping the normal cycle.
I don't know if this is a solution but they are easy to check and eleminate as a possibility.
May 20, 2008 | GE Profile Arctica Stainless Steel Top...
Traulsen ADT132WUT-HHS Stainless Steel Commercial Refrigerator Logo
Top Traulsen Refrigerators Experts
Dennis Boxerman
Andrew Taylor
Andrew Taylor
John Tripp
John Tripp
Are you a Traulsen Refrigerator Expert? Answer questions, earn points and help others
