Question about Hitachi 65SWX20B 65" Rear Projection Television
I have the typical convergence issues. My blue is way off. I order new ICs and installed them, but still have the same issue. The ICs I pulled are (1) STK392-110 & (1) STK-150. I replace both with STK392-110. Is that my problem? The is also one resistor near rear IC marked RK55. It appears to have been a hot but not burnt. Slight brownish discoloration in the middle. Do I need to replace it also? Thanks, Dan
  • 3 more comments
  • d_mulder May 26, 2011
    Ok, I understand better performance, but shouldn't it work to some extent? I do not have a schematic so I don't know the value of the resistor. How can I get the specs? Could the resistor alone cause the convergence to still be off?
    Thanks,
    Dan
    Should I buy the $104.00 ICs?
    The STK392-110 is what I used. You just said they were no good.
    I paid $60.00 for a kit from TVRepairKits.com. (2) STK392-110 & 6 resistors.
    I don't know if my reply went through or not.
    I paid $60.00 for a kit from tvrepairkits.com. They are suppose to be good STK392-110.
    I guess I have to go buy another TV.
  • 10,594 Answers
Please use STK392-150 ICs as its better than STK392-110 in performance, also check both ICs are getting +Vcc and -Vcc (approx +20V, -20V) to work properly and yes, replace RK55 with same value/ rating mentioned on resistor/ related schematics.
Usually low price STK ICs are not good, please go for medium or high price IC of same number.
Hope these info will help.
Thanks.
Posted on May 26, 2011
  • 3 more comments
  • Shahid Electronics
    Shahid Electronics May 26, 2011
    RK55 is METAL OX. 150OHM 2W resistor.
    Low price STK IC is sub par chip that has manufacturing problem so it wont work at all.
    Click PartStore.com link to view SRK392-150 chip price, one is for $13 and other is $104 but part number is same? its quality issue.
    Same thing for STK392-110 four different prices for same number chip?
    Hope this will help.
    Correction: SRK392-150 is wrong word, STK392-150 is correct one.
    I wont recommend to buy that costly chip because tv is an old model, however, STK392-110 for $37 each is better choice.
    It was not mentioned that where from both STK were bought and its proven fact that STK392-150 is better than STK392-110
    Since STK392-150 is very much costly so keeping tv in view I suggested to buy medium price ICs to solve the issue, it was also suggested to measure/ check supply volts to ICs
    If Vcc are fine then ask tvrepairkit.com to provide good quality ICs because convergence output chips failure is most common problem of rear projection tv.
    I got your follow up question emails, I just answered that.
Double image blue and green
Thats a convergence issue. Installing the sony type1 convergence repair kit should solve the issue. The kit contains both ICs the 8 associated pico fuses and some 4.7 ohm resistors plus the CD with detailed repair instructions. The kit is available from www.tvrepairworld.com
Aug 24, 2011 | Sony KP-57WS500 57" Rear Projection...
Panasonic PT-47WX53 has intermittant convergance issue
I would chack the solder connections at the convergence ICs first. Since the set "recovers" on its own, it suggests a connection issue rather than a defective component. Also, if the ICs were installed without sufficient heat sink compound, this could happen as well. Look at low valued resistors in the area of the ICs for signs of overheating as well.
Keep us posted on your progress.
Dan
Oct 19, 2009 | Panasonic Televison & Video
Convergence issues
You will find more info for identifing the ICs needed to fix your TV from the following link
http://www.fixya.com/support/r1122465-mitsubishi_convergence_ic_part_number
Aug 06, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Sony KP-511HW40 - blue/green tint issue - convergence issue?
Replace your convergence ICs STKs big black ics Go by number on them STK392-560 ect..... Parts you can order on line www.electronix.com or Call 1-800-223-3205 you will also need silicon heat sink compound to put on New ICs replace Both STKs
Dec 25, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue Convergence on Toshiba 42H82 42-Inch
it should just need new STK392-110 ICs which is actually not very difficult. You will need two ICs both STK392-110 and you can get replacements at the following link and they provide instructions on how to remove and replace Convergence ICs.
Heres the link.
http://servicemanuals.vstore.ca/
Oct 22, 2008 | Televison & Video
Convergence STK ic parts?
they have a repair kit that repairs the convergence Issue with your set at the following link that has free installation instructiona as well as the resistors and ICs. Careful about Buying ICs off ebay, as you will end up getting knock off ICs and most times they are defective inferior ICs.Heres a link where you can get quality parts.
Aug 31, 2008 | Toshiba TP55H60 55" Rear Projection...
Convergence problems
you need to replace both of your convergence ICs they are STK392-110 you can get new replacements at the following link and they provide free instalation instructions with pictures. Heres the link
May 29, 2008 | Toshiba 42H81 42" Rear Projection...
Hitachi Model 53UDX10B
The problem with your set is the convergence ICs you need to replace both ICs numbers STK392-120 you can get the new ICs at the following link and they include free instalation instructions with pictures so you can do the repair yourself which takes about 45 minutes and requires basic soldering ability. Heres the link you will need two STK3920120 Convergence ICs. The manual will not help as it doesnt show the IC instalation.
May 12, 2008 | Hitachi 53UDX10B 53" Rear Projection...
Toshiba 61H71 blue convergnece cannot be fixed using TV controls
You need to replace both convergence ICs part number STK392-110 this requires basic soldering not very difficult. If you order the new ICs at the link I am posting they provide free instalation instructions with pictures and free tech support so you can do the repair yourself and save about 400.00 heres the link.
Apr 29, 2008 | Toshiba 61H71 61" Rear Projection...
Hitachi 60SBX78B Blue Convergence Issue
You need new convergence ICs. its an easy repair. You can get replacement ICs at the link below and they provide free installation instructions with pictures as well as free tech support.
Apr 22, 2008 | Hitachi 60SBX78B 60" Rear Projection...
Hitachi 65SWX20B 65" Rear Projection Television Logo
142 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
matt martin
matt martin
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
