Question about Tefal Avante Deluxe 2 Slice Toaster
Tefal Avante 2 slice toaster. Problem is that the toaster sends the toast flying across the floor. How can this be fixed?
Alan ang
  • 24 Answers
SOURCE: Bagel setting stuck on.
Mechanism slight is the problem and spring give way.
Rdgs
alan
Posted on Feb 24, 2008
SOURCE: only toasts part of bread
The solution I got from the FixYa team was: "Get a new toaster." Which is how I ended up with 4 new toasters that don't work. I'm glad I didn't PAY for THAT answer.
Posted on Sep 05, 2008
SOURCE: only toasts one side of toast
The cancel button is stuck in the in position
Posted on Jan 15, 2009
cactus bob
  • 267 Answers
SOURCE: Sunbeam 3831 Toaster (2-slice) -- toast/carriage won't stay down
great ! its a great fealing when you save a appliance from the junkyard .
Posted on Apr 03, 2009
SOURCE: T-Fal Avante Bagel Tpaster - 4 slice
Energized coil (Magnet) which holds down lever mechanism may be coated and in need of scraping for it to make full contact
Posted on Aug 31, 2009
Lever will not stay depressed
Hello. The first thing to try is to set the toasting level to a darker setting. Often this alone will solve the problem. If not, the mechanism which prevents burning or even a fire is simply worn out and it is time to buy a new toaster. J.
Aug 04, 2010 | Tefal Avante Elite Programmable - 2 slices...
Can you email the user manual for tefal toaster avanti deluxe for me to download please
Hello Val,
Here's the link directly to Tefal's site where you can select the exact toaster manual from the list provided. I wasn't sure of the exact model, since Tefal has two (2) Avante Deluxe model toasters available (both a 2 and 4 slice version) and sometimes the Fixya site only has a limited selection for certain products for users to request assistance with.
In any case, they are all on the page at the link below. Simply click and you'll get a free manual that you can save or print out for your use and future reference.
http://www.t-falusa.com/tefal/Consumer_service/Use_instructions/HomeUseInstructionsTemplateFile.aspx?NRMODE=Published&NRNODEGUID=%7bC41F9AC8-8DCD-439E-8171-0CA2B8E9C7E3%7d&NRORIGINALURL=%2fConsumer%2bservice%2fUse%2binstructions%2fuse-instructions_home%2ehtm&NRCACHEHINT=NoModifyGuest
If it doesn't come up, simply select "toasters" from the pull down window on the screen and hit "go"
I also have a folder on my computer that I've labeled "Household Appliances and Equipment" into which I save an electronic copy of all Owner's Manuals and Guides for all the appliances we have, just so they're readily available without having to search the web for them.
I hope you find this Very Helpful and best regards!
Nov 23, 2009 | Tefal Avante Deluxe 4 Slice Toaster
Lever to lower toast has snapped off just inside the toaster casing. It is plastic and cannot be reattached
Hello Sue, I've attempted to locate replacement parts for for Tefal Avante toaster, but there doesn't appear to be a broad source for these, which troubles me as I've got the same toaster and use it everyday.
I did locate the Tefal customer support/service contact that should be able to provide you with either a local authorized service location or provide you with the replacement parts you need to get it working again.
You can call Tefal directly at 1--800-395-8325 from 8:00 AM to 5:00 PM Monday thru Friday, EST
Here's a link to the contact page, in case you prefer to send an email instead.
http://www.tefal.com/Consumer+service/Contact+Us/Contact+international/United+States.htm
With luck, Tefal will be able to assist you in getting your toaster working like new soon.
Nov 23, 2009 | Tefal Avante Deluxe 2 Slice Toaster
T-Fal Bagel toaster makes buzzing sound
I'm not sure if this applies to your problem, but I found a great solution to the buzzing I've experienced on my GE toaster at the following link: http://applianceguru.com/forum1/18670.html
Jan 04, 2009 | Tefal Avante Deluxe 4 Slice Toaster
I have a 4 slive tefal deluxe toaster which has stopped working
often is the switch as you press down its a steel wire like a pin that snaps i have repaired 2 same problem i soldered a fine steel wire on its easy part to replace but so far i cant buy a replacement switch
Sep 08, 2008 | Tefal Avante Deluxe 4 Slice Toaster
May 01, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Tfal 2-slice toaster repair
look inside your toaster. there must be something inside it turn it down and see if something comes out.. if nothing is inside then try to see if the cord that you switched on is not broken. if you see a liitle bit scratch mark on it- switch off. You can get a electric shock. it is your favorite toaster so try to consult a electricion to fix the cord for you.
Feb 26, 2008 | Tefal Avante Deluxe 4 Slice Toaster
Rdgs
alan
Dec 15, 2007 | Tefal Avante Deluxe 4 Slice Toaster
Tefal Avante Deluxe 2 Slice Toaster Logo
48 people viewed this question
Top Tefal Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
paul
paul
Oscar Netto
Oscar Netto
Are you a Tefal Kitchen Appliances - Other Expert? Answer questions, earn points and help others
