Question about Whirlpool Washing Machines
I have a F2 default code - Whirlpool Washing Machines
  • Whirlpool Master
  • 3,051 Answers
Hello there and thank you for choosing fixya
F/2 Long Drain
If the drain time exceeds 8 minutes, the water valves are turned off and "F/02" is flashed.
NOTE: After 4 minutes the "Sud" error will be displayed, then 4 minutes later the F02 error code will be displayed.
Press PAUSE/CANCEL twice to clear the display.
  • Check the drain hose and make sure it is not plugged or kinked.
  • Check the electrical connections at the pump and make sure the pump is running.
  • Check the drain pump filter for foreign objects.
  • If the above does not correct the problem, replace the pump.
Posted on May 26, 2011
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
My m45se does not show anything on the screen, but the blue light shows that is on and i tried with another ram and processor.
when you turn on , press F2 and DELETE / F2,Del, F2, Del, F2, Del/, it will enter to setup, in it see where "Load setup defaults'', do it then press F10, save and exit.
May 30, 2011 | Computers & Internet
New system. Cannot enter bios with F2 key, apparently keyboard is not working, but works well in another computer. I tried bios switches 1_2 default and 2_3. With 1_2 it goes directly to PXE_E61 error,...
hallo there, tried the DEL key? (instead of the F2, some Bios of them use older input for F2, DEL sends same key. )
Also, please count how many short, how many long beeps mopbo gives when booting.
Also: try to connect with PS2 keyboard. Possible no correct keyboard connection or even worse, when its a wireless keyboard need tyo pair keyboard with receiver first.
Also possible: is the keyboard not IBM compatible?
As said: try first to use default PS2 keyboard, theyre cheap and most of the times problem is directly solved.
If that does not solve your problem, count the beep codes and tell us please, could be some other problem, ( wrong memory, memory not placed correct, voltage problems etc etc etc)
the bios codes would help us to help you fasst.
Greetings
Ganimidis
Mar 13, 2011 | Intel DP45SG Motherboard
F2 error
Well F2 error codeis on a variety of Sharp copiers, the F2 error code would normally be accompanied by a sub code that indicates the fault, You may please check out the following -
You may post further comments for more help or information......
Good Luck!!
Thanks for using FixYa!!
Sep 10, 2010 | Sharp AR-5316 Advanced Digital Imager...
Boot up problem
press f2 it should boot up your pc from default
Nov 30, 2008 | Dell Dimension C521 PC Desktop
F2 Error code displays with audible beep.
The F2 typically means an overtemperature conditions:
1. over 650 degrees F unlatched or 915 degrees F latched.
2. cooling fan stalled while over above 650 degrees F or an oper thermal switch in the yellow leads.
Check for:
1.Welded relay contacts
2.Cooling fan stalled or blocked air flow to rear of unit.
3.High resitance in over sensor leads/connectors, especially at sensor in rear.
Nov 03, 2007 | GE JTP20 Electric Single Oven
My PC will not boot but only displays "press F2 to enter bios setup"
Go to BIOS and go to LOAD SETUP DEFAULT OR LOAD OPTIMIZED DEFAULT -YESS- AND RESTART
Oct 11, 2007 | AMD (90613) PC Desktop
Washing Machines Logo
153 people viewed this question
Dan Webster
Dan Webster
Sal De
