Question about Dryers
Pluged in push star says its working not working
    President:
  • 3,074 Answers
You will need to open the dryer up and see if the belt is off or broken:
opening up a dryer:
http://www.partselect.com/dryer+open-cabinet+repair.htm
belt diagram:
http://forum.appliancepartspros.com/dryer-repair/25860-dryer-belt-diagrams.html
Posted on May 26, 2011
How to replace spark pluges in a 2003 cadillac deville northstar engine
With alot of hard work - Just kidding. You might find the answer at "justanswer.com". Or type your question into your Computer search engine. You'll probably need a swivel type spark plug wrench, as the plugs on many cars are hard to reach.
http://justanswer.com/
Aug 12, 2014 | 2003 Cadillac Deville
2001 f350 won't star unless pluged in
Sounds like it's the controller for the glow plugs, also, if the first glow plug in line from the controller is bad it will effect all the others. I've had this same sitituation, mine turned out to be the controller.
Jun 10, 2012 | 1993 Ford F350
How do i set the clock on my yamaha v star 1300
Turn key to on, hold select switch up for 10 seconds, and hold reset switch for 5 seconds while continuing to hold select switch. Hours should be flashing. Push select switch down to change hour. Push reset switch to select minutes. Push reset switch to finish.
God Bless and ride safe :-)
Oct 14, 2011 | 2007 Yamaha V Star 1300
How do you set the clock on a 2006 royal star tour deluxe?
Select the clock (push the "select" button for at least 2 seconds).
Push both the "select" and "reset" buttons for at least two seconds.
When the "hours" digits begin flashing, push the "reset" button to set hours.
Push the "select" button, and the "minutes" digits will begin flashing; push the "reset" button to set minutes.
Push the "select" button to start the clock.
Mar 03, 2010 | 2006 Yamaha Royal Star Tour Deluxe
2004 V-star 650 won't idle
Sounds like the fuel filter is pluged or you got crud in the carbs and they will need took apart and cleaned.
Sep 05, 2009 | 2005 Yamaha V Star Classic
Wants its unlock code
BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert a half of it,
so it won't ask for network password and shows "Insert SIM" message.
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
(star 7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable network lock By typing: #7465625*638*00000000#
(hash 7465625 star 638 star 8zeros hash)
Phone is unlocked (check with *#7465625#)
Sep 04, 2009 | Samsung SGH-D900 Cellular Phone
Cannot enter service mode to reset e007.
for IR model press star * then press 2 & 8 keys at the same time and then press * again,
(if there are star (*), 2 or 8 key are not working, it's not possible to get enter in the setup mode.
for NP model there are a small push button inside the front door (press only from a thin pin because there are a very small hole to push them) to enter in the setup mode
Jun 16, 2009 | Canon Office Equipment & Supplies
Operating instructions for Aqualink RS8 pool/spa combo panel?
To clear the memory
Push the menu button once
Push the back arrow to "System setup"
Push star * or enter button
Push back arrow till display says " clear memory "
Push star or enter
Push star or enter again to confirm.
You will get a message "erasing memory"
Now you can reprogram system
Nov 18, 2008 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Default security code?
Hello keith g670,
turn off the phone
2. take out the battery and sim and put non-network SIM and insert it half way only,
so it won't ask for network password and when it shows "Insert SIM" message.
Only then fully insert the sim without removing battery or turning it off (tip: use a pin to push the sim in)
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#(star 7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable network lock By typing: #7465625*638*00000000#(hash 7465625 star 638 star 8zeros hash)
Tried and tested OK
This was taken from http://forum.gsmhosting.com/vbb/archive/index.php/t-510615.html
Please post what you decide to do and how you do it. I look forward to your posts.
Nov 11, 2008 | Samsung SGH-E370 Cellular Phone
Fortec machine has not power
fortec machine has not powwer
Dec 09, 2007 | Fortec Star Lifetime ULTRA
Dryers Logo
43 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
