Question about Yamaha RX-V730 Receiver
How do you reset a yamaha rx-v730 the protection switch on the relay keeps tripping
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as a root cause for ntermittent shutdown.
Posted on May 26, 2011
How do I reset my Yamaha Rx-a730
How do I reset my Yamaha RX-V730 A/V Receiver? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
May 31, 2013 - I'm stumped on how to reset this receiver. I have no remote and just purchased a Powered sub woofer and it doesn't work that loud through the ...
RX-A730 - Yamaha Downloads United States
download.yamaha.com > Support > Downloads
13 items - ... About Yamaha. My Account ... Downloads for RX-A730. Find Your Model .... RX-A730 Owner's Manual, 14.07 MB, 4/17/2013. French, Manual, pdf ...
How do I reset my RX-V1800 parameters to the factory ...
faq.yamaha.com > Support > FAQs > Search Result: RX-V
Nov 13, 2010 - YAMAHA ... Power the RX-V1800 back on using the [Master On/Off] button and the receiver is now set back to the original factory settings.
Resetting/Initializing the receiver to factory settings - RX ...
Feb 08, 2016 | Yamaha Audio Players & Recorders
Yamaha rx-v679 only standby red power bottom when you turn on its only blinking what is the problem ?
It is most likely locked in protect mode. Try resetting by holding the TONE CONTROL and INFO buttons and pressing power. Watch the front panel display when you do this, and it will tell you what protect was tripped.
Jan 11, 2016 | Yamaha Audio Players & Recorders
Can I download the speaker wiring instructions for surround sound, lost mine
try here : https://www.manualowl.com/p/Yamaha/RX-V730/Manual/87206
Dec 20, 2015 | Yamaha RX-V730 Receiver
Yamaha RX-V730 OSD problem
I assume you have a component connected source coming into the Yamaha to give it sync and you are component connected out to the monitor. If you have no input you won't have osd on component only without a signal to sync lock.
It is always possible that the 730 doesn't actually have component overlay for osd, just its a 2in 1 out switched affair. Hence the manual says you also need the composite/ Svid as well...They certainly don't use both at the same time. Newer units have full up + down video conversion but at this age it won't have.
Oct 31, 2009 | Yamaha RX-V730 Receiver
How can I reset all settings on my yamaha rx-v730 to factory default?
Use Advanced Setup mode - see the manual. From standby press both STANDBY + STRAIGHT buttons, then choose INIT / ALL.
Oct 05, 2009 | Yamaha RX-V730 Receiver
Yamaha Rx-v730 - only hear "click" when try to turn it on
That may due to a bad power transistor, huge current flows when it's powered up, protection circuit kicks in and switch off the unit. Get to repair shop for check up and replacement.
Mar 07, 2009 | Yamaha RX-V730 Receiver
How to hookup yamaha rx-v730 receiver to projector & cable unit.
hook up hdmi cable from cable box to receiver hdmi input 1 then from hdmi out to your projector or tv,i don't know what kind of inputs you have on your projector .whatever you have run from projector to receiver input example component red,blue,green then run from both say to the av input 1 then set your receiver to av1 and you should get picture.
Jan 25, 2009 | Yamaha RX-V730 Receiver
No output on left main speaker on Yamaha RX-V730
To the shop.Do a web search and check around carefully for someone with a good reputation.
I have a shop but I'm in Vermont.
Feb 23, 2008 | Yamaha RX-V730 Receiver
Yamaha av receiver rx-359
go to best buy and buy a new recever
Jan 12, 2008 | Yamaha HTR-5560 Receiver
Yamaha RX-V850 receiver
how can i hook a subwoofer into yamaha RX-V850
Dec 25, 2007 | Yamaha Audio Players & Recorders
Yamaha RX-V730 Receiver Logo
313 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
