Question about Hannspree HANNS-G 19" Widescreen Monitor
Hannes G JW197D Monitor goes black every few minutes, then comes back on again. I repolaced all the cables and other monitors work normally on my PC. My PC is an E Machine ET1831, 3gb ram, 64bit operating system, Intel Celeron 450@2.20Ghz. My video card is NVidia GeoForce 7050/NVidia nforce 6201 - my drivers are up to date. When connecting the monitor I get a message that a driver failed to load. Do you know if there is a driver I can download manually?
5 Suggested Answers
  • 523 Answers
SOURCE: No picture on the monitor
try to log into safemode, change the setting of your monitor or install the vga driver if its needed.
Posted on Jun 17, 2009
micromend
  • 748 Answers
SOURCE: I have a Hanns G 173BBD Wide screen with a XP
Hello
Probably capacitors on the power supply board are beginning to change value. Take the monitor to a local repair person or see my website: www.micromendllc.com
Good Luck
Posted on Sep 23, 2009
  • 70 Answers
SOURCE: monitor will be on and working fine and then
oh no i have same monitor well the only thing i know to do is take it apart and wiggle stuff maybe a culprit will show up if noting then i would just replace on mine the power plug on the back came loose now i cant take out the plug else itll be useless
Posted on Nov 03, 2009
  • 80 Answers
SOURCE: The monitor goes black while on
Open it up and look at the capacitors. The round "tin can" looking components. If the tops appear bulged, then replacing them may help. Check out the YouTube video... and web site...
http://www.youtube.com/watch?v=9Q6_TgNJvQw
Good Luck!
Posted on May 15, 2010
Why does screen go black after a few seconds
Hope this helps.... Your monitor has an inverter issue. You know it's an inverter problem when:
1. Your monitor starts normally and displays the startup/desktop screen for a while.
2. Then it suddenly goes off, leaving a blank (black) screen or a very dim display.
To fix this black screen problem, change the inverter board (based on your monitor brand).
Source(s): http://lcdmonitorrepair.annics.com
May 05, 2014 | ASUS VK193D LCD Monitor 19-inch - Black
LCD monitor turns off
I have had the same problem as others seem to have had with the dell flat panel. After leaving the screen on for some time, the monitor brightens for a moment, then goes black, while the green light stays on. When I reboot, it works again for some time, or if I remove the cable for a few minutes and plug it back in (with monitor turned off) it will come back on...only to repeat the black screen. I have changed the power features, screen resolution, downloaded updated drivers from dell, and viewed dells troubleshooting advice on the monitor cd that came with the computer. Nothing directly advises on this problem, but I have read here and in other online message boards the exact same problem. Anyone able to fix this?
Nov 02, 2012 | Computers & Internet
SCREEN TURNS OFF AND GOES BLACK
The picture board on your monitor is faulty or bad, since it goes black after few minutes, it means the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board or any service center because the fault is not something you can fix yourself. in order not to complicate issues.
Take care.
Apr 21, 2010 | HP w1907 LCD Monitor
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Monitor goes black after running for a few minutes. Brand new 22 inch sceen.I prees the button to turn it on and it says Analog and goes black again. I have to shut down the computor to get it to come back...
Sounds like the computer is shutting it down and the monitor is fine. Check for viruses then check your settings in device manager for the screen saver and power down (screen off) options.
Aug 10, 2009 | Dell Computers & Internet
My screen goes black after a few seconds
Sounds like a bad solder joint on the printed circuit board. Once it heats up then it no longer makes good contact and the monitor goes black until it cools down and makes contact again. You could resolder it if you knew where it was but monitors are dangerous to go playing around with as they can hold very high charges of electricity in their capacitors that are very dangerous. It's a throw away world. Go buy a new one.
Jun 02, 2009 | Gateway FPD 1750 17" Flat Panel LCD...
Monitor Turns Black
Try reseating the Graphics card first..It may be loose. Or try it in a different slot.
May 21, 2008 | LG Flatron L1715S 17" LCD Monitor
Screen suddenly goes blank
when you open your pc now,do you still hear a click sounds like you hear before ,when your computer has no problem yet? now there is no sounds .do the ff..
1.try to press the numlock key and observe it ,if the indicator LED lite on and off,the problem of your computer is your video card,
2.if you can't hear anything, when you open your unit and the indicator of your monitor goes the color orange,pls..check your memory .clean the memory and the memory slots using the contact cleaner .before you replace a new memory.
3. and try to use a another monitor,maybe your monitor has the problem.
Apr 01, 2008 | Samsung SyncMaster 551 15" CRT Monitor
Screen goes black and power light goes out after a few minutes
it would seem that one of the internal components has failed / overheated Dont open the rear of the monitor !
if pos drop it into your nearest pc repair shop and have is serviced it may just need cleaned to free it from dust build up
on the inner parts this may be causing the unit to over heat
Nov 04, 2007 | Gateway FPD1760 17" LCD Monitor
ViewSonic VX2235wm LCD Monitor
hello do you still have the monitor maybe i can trade you something for it i could use the parts to fix a unit i have lmk thanks
Sep 08, 2007 | ViewSonic VX2235wm LCD Monitor
Hannspree HANNS-G 19" Widescreen Monitor Logo
231 people viewed this question
Top Hannspree Computers & Internet Experts
tomar33
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
