Question about Maytag Neptune MDE6800A Electric Dryer
Maytag dryer MDE6800AYW chirps when power is turned on, will not respond to touch controls. will not run, but power lights and inside light is on
  • 181 Answers
SOURCE: mde6800ayw - Dryer runs but does not heat.
no it is the heater element needs replacing on the out side of the drum. hope this helps
Posted on May 12, 2009
bomark2002
  • 160 Answers
SOURCE: MayTag Neptune MDE6800AYW dryer drum making
Have someone change the bearing, it sounds like it has busted on ya. The rumbling sounds like the ball bearings in the bearing have failed.
Posted on Jul 09, 2009
miket756
  • 2702 Answers
SOURCE: maytag mde6800ayw dryer.
your guessing right then,,,
often if the power is cut off when its restored the sudden punch of power can blow the bords chips up,
its nothing new,, if they has a soft start it would not happen to them,,
sorry you need a new program bord
Posted on Oct 31, 2009
Testimonial: "very helpful, thanks"
heatman101
  • 43501 Answers
SOURCE: I HAVE A MAYTAG NEPTUNE MODEL NUMBER MDE6800AYW
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it iwll help you find tha thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 06, 2010
cpldw48
  • 120 Answers
SOURCE: My Maytag dryer is warm inside and to touch, but
unplug your dry your element on dry might short to ground cauing the element to stay on! call a techincian! but UNPLUG DRYER CAN CAUSE A FIRE
Posted on Apr 25, 2010
Maytag neptune mde6800ayw electric dryer
The tensioner pulley for the belt, oil it with 3 in 1 oil, NOT WD40, if it stops then you need to replace the pulley because it will come back :)
Jan 31, 2014 | Maytag Neptune MDE6800A Electric Dryer
Maytag electric dryer, lights flash, chirping
I had this happen with a maytag washing machine. The repair guy replaced a board and it worked fine. I'm afraid that's what happened here.
Nov 13, 2012 | Maytag Dryers
Maytag Dryer MDG6800AWW won't start, lights all on
There is no reset, There will be either a defective solder joint in the controller or the controller is faulty and needs replaced.
Mar 10, 2012 | Maytag Dryers
Maytag Neptune MDE6800AYW shows error DO (Door Open?) bu the door is closed and the machine would not turn on
door switch, it is located inside the dryers front panel, there are a total of eight screws to take the front panel off, hinges have four and lift up an out, the other four are on the opposite side there are white plastic fillers(this is for door reversal), the panel lifts up and out. Here is a website to check the switch, may have a broken keepers,loose/broken wire or just a bad switch. Hope this helps Tim:
http://www.partselect.com/dryer+dryer-wont-start+repair.htm
Nov 07, 2010 | Maytag Neptune MDE6800 Electric Dryer
It will not turn on
A dryer may not start for many reasons...
This tip that I wrote will help you to figure out what is happening...
http://www.fixya.com/support/r4422207-dryer_repair_dryer_not_turning
http://www.fixya.com/support/r4460438-dryer_repair_dryer_will_not_start
heatman101
Apr 15, 2010 | Maytag Neptune MDE5500AY Electric Dryer
heatman101
Apr 05, 2010 | Maytag Neptune MDE6800A Electric Dryer
Maytag mde6800ayw dryer. no power at all. light works inside and im getting 220v. im told that there was a power outage and when it came back on the dryer was dead. im guessing the control board.
Oct 31, 2009 | Maytag Neptune MDE6800 Electric Dryer
Mde6800ayw - Dryer runs but does not heat.
May 12, 2009 | Maytag Neptune MDE6800A Electric Dryer
Maytag Electric Dryer - Control panel doesn't light unless door is open
the power connects for the 240 volts to the outside screws on the terminal block the center connector is the nutral connection
Jun 09, 2008 | Maytag Neptune MDE6800 Electric Dryer
Open Questions:
Maytag Neptune MDE6800A Electric Dryer Logo
89 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
