Question about Garmin nuvi 200W GPS Receiver
Switches on ok but wont work when the charger is connected,the screen just shows the charging screen
    Top Expert:
  • Garmin Master
  • 75,235 Answers
The plug at the back of the GPS where the charger connects is shorted, very common issue on the Nuvi series.
Posted on May 26, 2011
My Blu Neo 4.5 wont turn on and its charged... what can i do to fix it?
Check the battery and the charger. Try with a same of your friends. If the problem still existing, visit the mobile service.
Aug 14, 2014 | Blu Cell Phones
Lattitude e5520 wouldn't charge
Ted try this once more:
1. turn off the machine.
2. keep pressing the off switch a little longer 3. remove the battery.
4. press the off button for say 15 seconds.
5. re-install battery after a few minutes.
6. connect charger to computer and see if it shows % charge.
7. when it shows 100%disconnect charger and see if the battery still shows 100% If it does you are now reset. IF not,will cross the bridge then.
Jan 24, 2014 | Dell Latitude E5520 Laptop Computer PC...
RCA tablet wont charge
Possible charger damage.
If you know someone with a charger you could use, you should first plug their charger into your unit to see if it works, if not, plug your charger into their unit.
If your unit will not charge with new charger, you may have serious damage, if the other will not charge with your charger, your charger is broken.
Jan 13, 2014 | Tablets & eReaders
I turn rocker switch on with one battery I show full, plug in a different battery, turn on rocker switch get nothing, both batteries show a full charge on charger. I think one battery is 3 years old other...
Hello
Check the following:
* Circuit breaker on main control box is tripped
* Fuse blown (check fuse in main control box assembly).
* Incorrect polarity at battery terminals
* Dead batteries.
* Charging cable is still connected to charging receptacle
* One of the cable connections at the main control box is loose.
* Control connection cable disconnected
* Broken key switch
* Throttle stuck fully open
* Throttle control potentiometer broken.
* Speed potentiometer broken
* Battery voltage too low.
* Faulty charging cable.
* Charger not working.
* Charging circuitry in main control box assembly not working
If these check OK, the problem is likely to in the control connection cable or upper control box Verify that the upper control box is getting 24V. (Blue wire on red connector.)
* If the upper control box is not getting 24V, replace control connection cable
* If the upper control box is getting 24V, check key switch operation and verify wiring in the upper control box. Trace voltage from keyswitch on to find where the problem occurs. (Replace upper control box if necessary.)
* Charge batteries with a 12V charger or replace if necessary.
* Ohm test the charging cable - replace if necessary.
* Test scooter with a different charger, if new charger works, replace charger.
* Check wiring in main control box assembly - replace in line relay if necessary
* If batteries, charger, and all wiring is good, replace controller PCB. (Note the model number for the PCB, for example 1208-2330.)
Aug 22, 2011 | Shoprider SL73 Echo 3 Wheel Scooter ()
If the phone does not power what may be the cause
hi, does the screen say charging when you plug the charger in if it dont then the problem could be the screen, the battery or the charger.
if the screen lights up and says charging but the phone wont switch on then this points towards the on/off button not working properly.
if you dont know the history of the phone then to me it sounds like it could be liquid damage which means its probably not worth getting fixed.
let me know what happens when charger is plugged in ok then i can assist you further
Aug 14, 2010 | Nokia E71 Smartphone
Mp3 player shows that battery is dead even though its charged and the screen only works if i hold the on off switch the whole time
try inserting the charger to a different socket until it works. if not you might be having problem with the charger. not the mp3 player and if you already triedto change the charger you might be having problem with the battery of your mp3 player ok send me a message for more concerns.
May 04, 2009 | SanDisk Sansa m240 MP3 Player
My phone wont charge
check your charger first, if charger is ok then check the charging connector on the phone, clean it with a toothbrush and solvent cleaners.
Mar 27, 2008 | Samsung SGH-V200 Cellular Phone
Screen on Razr
You will need a hot air soldering/desoldering gun for the work. Not possible. Only a trained technician can do it.
Oct 27, 2007 | Motorola Mobility RAZR V3
It dosent even charge!!
Are you sure it's not charging? What makes you think it's not charging? When you plug the USB cord in (and it's attached to the charger or the PC)a screen should appear temporarily. It shows a picture of a PC with a usb cable coming out of it. Are you not even seeing that much? Remember that this is a no-name Chinese player, so don't expect iPod or iRiver quality. I didn't think mine turned on, but that's because the on/off switch was sticky and because you need to press play once or twice after it's turned on to get it to do anything. But so far, mine's working fine.
Aug 21, 2007 | Kaser Corporation Mambo Mano Digital Media...
URGENT: INSERT SIM - UNABLE TO CHARGE
dear for not charging first check ur charger if ok then check and clean charging jeck. even not ok chen the status of solder of jeck if it is unsolder then sold it. even if not ok then check the charging fuse 0 ohams if meter shows continuty then ok other wise replace fuse. for inser sim card check connection from sill card ic(like combice resistor)
Mar 25, 2007 | Motorola Mobility RAZR V3
Garmin nuvi 200W GPS Receiver Logo
81 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
