I have an Armstrong- compak-10 gas and air, air condition for my home the fan will come on and run for a few minutes then it goes off and while it is on it will cool when the fan stops it quits cooling. do you have any suggestions
louislevel_2
  • 374 Answers
SOURCE: Samsung Ac compressor stops after 20 minutes and fan keep running
eventually,cycling process is doing done if the thermostat sense the configure temperayure set up it will trigger to stop your compressor motor as well as the blower fan,blower fan independenly to you compressor.if your thingking that your compressor is tripping off,check your operating current on one line using clamp ammeter and compare to the rated current that tag on
motor compressor body,if the current flow is higher than the rated current specified on compressor motor,well problem occured it will trip your compressor,because overload protector is becoming your thermostat.but if you got same current result it was cycling process.If tripping off maybe air is present in your system call qualified ac tech, to purge out air in system.
Posted on Mar 16, 2009
  • 588 Answers
SOURCE: RV air conditioner. Compressor running, fan stops before cool
The fan motor is getting hot and going off on the internal overload in the motor.
This is caused by either a low voltage, a bad capacitor, or tight or dry bearings in the motor.
To check the bearings turn the power off to the unit, then spin the fan blade if it spins freely then the bearings are ok.
To check the capacitor you will need some kind of tester or you can buy a capacitor and replace it, that's what a lot of people do. They usually don't cost very much.
To check the voltage you will need a voltmeter and measure the volts at the unit.
Posted on Jun 09, 2009
  • 51 Answers
SOURCE: duo-therm mod # 57915 not cooling fan?????
need to get at the capacitor for the fan. Try spinning blower when it hums. If it runs then the cap is bad if not the motor.
Posted on Aug 14, 2009
  • 358 Answers
SOURCE: fan motor will not come on
That thing connected to the capacitor is a booster for the compressor .But if the outside fan doesn't work , the compressor will shutt off on overload because the high pressure in the condenser coil.
First try to replace the capacitor in the condensing unit (it's the only one that works for the compressor and the fan motor) ,but if the fan doesn't start, you need to replace the fan motor.
Posted on Sep 14, 2009
  • 14 Answers
SOURCE: Unit cools for a few minutes then stops cooling. E...
unit may be short of gas. will run for a few mins before low pressure switch turns the compressor off. you will need to get an engineer to check gas pressure
Posted on May 23, 2010
I have an armstrong compak 10 gas and air. I can't get the blower to come on to blow the air through the vents. I replaced capacitor. The motor turns very freely by hand but just won't start.
Even if the motor is ok iit won't work unless the circuitry switches on the power to it.
Even if the circuitry is ok there are typically at least a couple of safety devices that have to be satisfied before things can get going.
I suggest the motor is tested by providing an independent current to it and then it might be a good idea to read the manual and study the circuit diagram - or cal in a repairer.
Apr 27, 2018 | Heating & Cooling
Furnace starts and ignites and fan comes on but when thermostat is turned off the gas shuts off and flame off but furnace continues to run. whu?? any suggestions?
The fan normally runs for a few minutes or so after the gas shuts off.
This removes the heat from the furnace and transfers it into the living space instead of just letting it possibly cause overheating of the furnace until it dissipates. If it is a fan that blows outside, that fan also needs to run for a few minutes to clear exhaust gasses from the furnace - to keep them from dissipating into your home.
Sep 28, 2015 | Heating & Cooling
Just replaced the capacitor, and reconnected. Turned power on and heard a buzzing sound from the condensor, then the fan turned on. the unit only runs for a few minutes then shuts off
The buzz is the compressor failing to start.The blue or purple wire from the compressor goes to herm on the capacitor. If it's wired right and does not stare the compressor is bad.
Jun 23, 2014 | Bryant 2 Ton 17 Seer Air Conditioning...
Air conditioner blower won't run
need too check your orifice tub it could be colgged but make sure you check first your high pressure switch
Jun 18, 2014 | Lennox Armstrong Furnace Control Board...
Wiring schatic to wire a 10 kw heat strip inside of a trane gas furnace
If you are using strip heat as seperate mode you must install a fan isolation relay which would be energized by emergency ht mode of stat.
Nov 25, 2012 | Carrier 38CKC042 Air Conditioner
Rheem 3204-80D furance. Turns on and fan starts. Then in about a minute the fan shuts off.
Problem: Your furnace will not ignite the gas to produce heat for your home. When a furnace has a bad ignitor what I see most of the time is the following sequence of operation:
1. Thermostat calls for heat. 2. Draft inducer motor starts. 3. Pressure switch attached by a small plastic or rubber tube senses the negative pressure produced by the draft inducer and closes. 4. Draft inducer runs for 30 seconds to a minute before you hear a gas hissing sound. The ignitor did not glow, the flame sensor (a small metal probe about 1/8" in diameter, with a white porcelain base) does not sense the flame, so after 8 to 10 seconds the hissing sounds stops with no ignition of gas to heat your home. Your furnace shuts down and goes into a lock out condition until you turn your power switch back off and on again. Then the sequence starts all over again with no ignition of the gas. Solution: You probably need to purchase and install a new ignitor. I would suggest that you inspect your ignitor closely for cracks. Make sure you do not touch the ignitor with your bare hands. If you do not visually see a crack, then you could have a furnace control board problem or a limit, rollout switch problem. The furnace's control board might not be supplying the voltage to the ignitor. If your furnace lights and the gas stays on for 8 to 10 seconds, then shuts right back off, then you need to clean your flame sensor with light sand paper or steel wool. You might need a new flame sensor, but most of the time they can be cleaned an will work well after cleaning.
Nov 26, 2010 | Heating & Cooling
Looking for elec. wiring diagram Armstrong unit pge10a42d100a-3a
Google Lenox and you will get armstrong also. The have tech site for diagrams and instructions.
Nov 28, 2009 | Heating & Cooling
I need a schematic for an Armstrong Compak 10 furnace. PGE10B30D075-3A
Contact Quality Smith, thats www.Qualitysmith.com as they deal with Armstrong Heaters. Give the all of you're information you have as that PGE number did not come up. Hope this will help you.
Good Luck, Shastalaker7
Nov 06, 2009 | Heating & Cooling
Armstrong v tech 91 furnace. will not make heat. when on unit runs continuosly no matter what thermistat is set at. could mother board be bad,replaced once already. cah this be done by the home owner to...
These furnaces goes thru 4--steps for complete run time.... step-1, the small draft inducer blower motor blows and prove thru the small air tube that sucks a switch close to tell the circuit board to go to step-2......the glow plug glows for 15 seconds and step 3 the gas valve opens and dump gas in the venturi tubes and lights off the glow plug and proves thru a flame sensor (pin with 1 electrical wire connection) on the last venturi tube which tells the circuit board to go to the last step 4--, to turn on the main blower fan after 90 seconds!. Where ever it stops at then thats where your problem is!
Sep 12, 2008 | Heating & Cooling
Heating & Cooling Logo
404 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
