Question about Zebra QL 420 Plus Printer
I have a big problem whit my zebra ql420+, dont take the position of paper correcto, just open and close header and the paper dont adjust whit the sensor and the continuos paper. Simply dont calibrate. Please helpme!!! thanks
5 Suggested Answers
itdude4321
  • 13 Answers
SOURCE: Zebra S600 printer continues calibrating
The factory default settings for the S600 is to auto calibrate every time the printhead is closed and every time the power is cycled. If the media sensor is not positioned correctly for the media you are using the label size will not be detected during a calibration. You mentioned the media has no markings, doe sthe media have a space between the labels? If so, the media sensor may not see the gap in the labels adn therefor is not calibrating properly or not calibrating at all. Check the media sensor position. I have found that the media sensor must be at least 1" from the inner wall of the printer so it doesn't see the edge of the backing in oder to read the size of the labels.
Posted on Feb 02, 2008
  • 35 Answers
SOURCE: Zebra 140xi II error
If you open the case there is a sensor that detects whether the head is opened or not that is connected to the open and close lever. Sometimes the tab that blocks the sensor when it is closed get out of alignment or comes loose or the sensor is jarred loose. Make sure the tab breaks the beam.
Posted on May 12, 2008
Joed911
  • 4338 Answers
SOURCE: how to adjust and align the printout downward
Here is a video which shows you how: (should be the same for your printer)
http://www.findinternettv.com/Video,item,554494454.aspx
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Posted on Mar 03, 2009
Sakeninja1
  • 5 Answers
SOURCE: Zebra 105Se power on calibration
If this unit has the LCD screen you need to Press Setup. Then Press Next till you get to Media Power Up and set it to FEED. Next go to Head Close and set it to FEED also and then save settings. It will only shoot one label out instead of Calibrate. Which is needed when they install new lables if its the same type of label all the time really don't need to Calibrate every time you stick new labels in it.
Posted on Mar 25, 2009
Getting blank page feeding while printing with Zebra ql420plus....but it is working with MZ320
I have experienced similar issues between two zebras. I found that the driver was the issue. I recommend:
  1. Confirm the operating system your using. [32 or 64 bit is important]
  2. remove old driver and install new driver from Zebra's support website. https://www.zebra.com/us/en/support-downloads.html
  3. If you are still having issues after all that, I really must recommend contacting Zebra as your printer may be defective and may be under warranty for service or replacement.
Dec 23, 2014 | Zebra QL420 Thermal Printer
LA IMPRESORA ZEBRA ZM400 CUANDO SE ENCIENDE APARECE EN LA PANTALLA LCD, EL MENSAJE HEAT OPEN, COMO QUITARLO?
there is a possibility that you need to just the print head assembly, if when its at close position, the print head is far from the sensor.
With the print head is open, you will see 3 screw on the left, louse them and adjust all the print head mechanism, up and down some milliliters tie the screws again, close the printhead , try again and see if errors desapeer
Jul 24, 2014 | Zebra ZM400 Thermal Label Printer -...
How to enable ZPL on a QL420 wifi printer
Include this command before the start of your ZPL code:
! U1 setvar "device.languages" "ZPL"
Apr 20, 2011 | Zebra QL420 Thermal Printer
Zebra QL420 portable printer label gets misaligned frequently
There are two things to consider here: 1) Is the printer set to the correct media handling setting? Look in the manual for the terms BAR-SENSE and GAP-SENSE and make sure that you have sent the correct command to the printer. 2) There is a TOF or Top of Form setting that you can send to the printer to align the perforation of the labels with the tear bar. Look for the syntax in the manual, which is free for download at zebra.com, and make sure that your perfs line up with your tear bar.
Oct 19, 2009 | Zebra QL420 Thermal Printer
Jan 31, 2008 | Zebra Printer 140-751-00000
AS400 Spool files stuck in outq in send mode
I have WiFi Zebra QL420. In my case a simple header label prints fine then the complex label (many fields, barcode, lines & boxes) gets stuck. Labels are in separate spol files. We have many other labels printing fine, just this one ALWAYS gets stuck.
If I send same data from PC to printer it works fine.
I can see with ethernet sniffer that header label data goes but complex label doesn't even leave the iSeries. My sniffer is too crude to tell me what LPR level protocol is saying.
Oct 10, 2007 | Printronix T5000 Thermal Printer
Zebra QL 420 Plus Printer Logo
37 people viewed this question
Top Zebra Office Equipment & Supplies Experts
pkwc
Dave Busselle
Level 1 Expert
CheckitRight
CheckitRight
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
