Question about Optimus F-1660 Fan
How do I remove the fan blade cap - Optimus F-1660 Fan
  • 300 Answers
After you have unplugged the fan and removed the front meshguard, please turn the knob clockwise.
Posted on May 27, 2011
Looking for replacement parts for Windchaser fan
You can take plumbers tape and wrap about 5 to 8 turns around the shaft threads and put blade on and cap. (Plumbers tape is white plastic tape on a roll with a pop off cap like medical tape comes in)
Remote? Maybe batteries.
Mar 15, 2015 | Windchaser Dryers
How do i take of the fan from a paslode im350+ gun ?
1) Remove the 4 bolts at the head, remove filter cap
2) Remove 2 bolts at nose holding the front assembly to the handle
3) Carefully pull the nose out and down to separate the cylinder and handle.
4) Remove fan blade - there is a very small torx screw on the fan blade
5) Remove the 3 screws holding the fan motor in and pull the motor straight out
Inside the cylinder head where the fan motor sits is a plastic spacer - if your fan kit does not come with a new one don't forget to take it out and reinstall it in the new head.
Jun 17, 2014 | BreatheAudio Paslode Impulse Cf325...
Got front of fan off but can't get the fins off to clean the fan. How do I do that. I have pulled them but they won't come off.
The cap holding the fan blades on should twist off. It should turn counter-clockwise to remove the cap and clock-wise to to put it back on.
Aug 30, 2011 | Lasko 1827 Table Fan
How do I remove my car radiator?
Section 303-03: Cooling, Engine 1997 Explorer, Mountaineer Workshop Manual REMOVAL AND INSTALLATION Radiator - 4.0L Removal
  1. NOTE: Refer to following illustrations.
    Drain the cooling system by removing the radiator cap (8100) and attaching a 9.5 mm (3/8 inch) inside diameter hose to the draincock nipple, located at the lower rear corner of the radiator tank. Then, open the radiator draincock (8115) and allow the coolant to flow through the hose into a suitable container.
  1. Loosen hose clamps at throttle body and engine air cleaner assembly. Remove air cleaner outlet tube and position aside.
  1. Remove radiator overflow hose from the radiator, disconnect two hose locators at top of radiator and position hose aside.
  1. Remove two fans shroud bolts. Lift the fan shroud out of the lower retaining clips and position it on the fan blade.
  1. Position upper and lower radiator hose clamps, remove hose from radiator and position it on the fan blade.
  1. Disconnect the two transmission cooling lines from the oil cooler fittings on the radiator, install protective caps over lines and position aside.
  1. Remove two upper radiator bolts.
  1. Tilt the radiator back (rearward) approximately 25 mm (one inch) and lift directly upward, clear of the radiator support bracket and the fan blade.
Installation
  1. Position the radiator into engine compartments, make sure that mountings on both tanks are inserted into radiator support brackets. Install radiator retaining bolts. Tighten to 6-8 - (54-70 lb-in).
  1. Remove protective caps from cooler lines. Connect the two transmission cooling lines at the oil cooler fittings on radiator. Tighten to 16-24 - (12-17 lb-ft).
  1. Install upper radiator hose and position hose clamp. Tighten to 3 - (26 lb-in).
  1. Install lower radiator hose and position hose clamp. Tighten to 3 - (26 lb-in).
  1. Position fan shroud in lower retaining clips and install upper bolts. Torque to 6-8 - (54-70 lb-in).
  1. Position radiator overflow hose, connect to radiator and locators.
  1. Position air cleaner outlet tube to throttle body and air cleaner assembly. Tighten to 2-3 - (18-27 lb-in).
  1. Fill the cooling system; refer to Cooling System Draining, Filling and Bleeding in this section.
Oct 28, 2010 | 1997 Mercury Mountaineer
The fan on the asus videocard does not work.
Hello Teerosy, hi, your asus videocard fan is dirty, there is a sticker that covers the fan, remove the sticker, then a circular cap under the sticker, remove it also, this reveals a shaft, drop a small amount of oil inside the shaft of the fan, and turn the fan blades manually to loosen the dirt. A spray of wd40 would also do the trick. replace the circular cap and the sticker back again.
Jan 21, 2010 | ASUS Computers & Internet
Buzzing fan on a Marshall mg 100 head
Try to remove the fan and look for the sticker on the back side where the wires come out.
Remove the sticker, underneath it there will be a small aluminium cap (sometimes there is no cap and the axis is readily visible when you remove the sticker).
Take the cap off with a sharp tool (it shouldn't require a lot of force to do it), now you should be able to see the fan axis being held in place by a small clamp - put a drop or two of machine oil in there, move the fan blades a little to make the oil flow past the axis into the bearing.
Reinstall the cap, put the sticker back in place, reinstall the fan and test it.
Sometimes this will make things better, but if it doesn't then it is only fair to replace the fan.
regards
Triarcuate
Sep 25, 2009 | Marshall Mg100dfx 100-Watt Combo Guitar...
Cleaning
not sure of the lasko brand but some fans have a cap over the center of the blades that must be unscrewed to remove the blades.( the motor shaft has threads on the end of it ).
some older models actually have the blades that unscrew opposite of turning direction, and you have to find a way to grip the motor shaft and unscrew the blades........
hope this helps.............jay
Mar 20, 2009 | Lasko 1820 Stand (Pedestal) Fan
Need to take off fan clutch, have taken off parts in the way
4.9L SFI
SPECIAL SERVICE TOOL(S) REQUIRED Description Tool Number Fan Clutch Holding Tool T84T-6312-C Fan Clutch Nut Wrench T93T-6312-B
Removal
  1. stj~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: The large clutch assembly nut has a right-hand thread and must be rotated counterclockwise to remove it.
    Remove the fan clutch (8A616) from the water pump (8501) by turning the large nut, which is part of the fan clutch, using Fan Clutch Holding Tool T84T-6312-C and Fan Clutch Nut Wrench T93T-6312-B.
  1. Remove two screws retaining fan shroud.
  1. Remove the fan blade (8600), fan clutch and shroud.
  1. If the fan blade and fan clutch have to be separated, remove the remaining bolts attaching the fan blade to the fan clutch
5.0L, 5.8L and 7.5L Engines
Removal
  1. Remove screws retaining fan shroud (8146) to radiator (8005).
  1. Remove four screws retaining clutch on water pump hub.
  1. Pull fan clutch and fan blade off water pump pilot and remove fan clutch, fan blade and shroud from vehicle.
  1. Remove four screws and separate fan clutch from fan blade.
Item Part Number Description 1 8509 Water Pump Pulley 2 57632-S Screw and Washer Assembly, 5/16-18 x .62 Hex 3 8600 Fan Blade (5.0 and 5.8L) 4 8600 Fan Blade (7.5L) 5 8A616 Fan Clutch 6 380288-S2 Screw and Washer Assembly, 5/16-24 x .88 Hex A — 16-24 Nm (12-18 Lb-Ft)
Mar 10, 2009 | 1994 Ford F150 Styleside Supercab
Removing ceiling fan blades
Wait? Why would you want to remove the blade? Are they broken? Is the fan unbalanced? Try cleaning the blade. If the fan still wobbles, try tightening the screws. If the fan still wobbles, Unscrew the blade and unconnect the blade from blade iron. Buy the new blade iron. If the blade is broken, Also buy the new blade.
Jun 13, 2008 | Angelo Brothers Westinghouse (r) Savona ES...
Dryers Logo
215 people viewed this question
Top Optimus Dryers Experts
Pranavendra Pranav
Pranavendra Pranav
Level 1 Expert
Tom Chichester
Mister Danger
Are you an Optimus Dryer Expert? Answer questions, earn points and help others
