Question about Quinny ZAPP Stroller
Please can you help have lost clips that sit in channel of frame that provide tension at front of seat to stop child slumping forward at base of seat many thanks jon
  • Quinny Master
  • 1,629 Answers
Good Afternoon
The clips themselves are not available as a seperate spare part item; to replace them, you'd need to replace the fabric of the Zapp.
If you're in the UK, you can do this via any authorised Quinny retailer or by calling the customer service department on 01284 413 141 Mon-Fri 8.30-4.30 RRP £40 with £3.99 p+p if ordered direct.
If you're not in the UK, please visit www.quinny.com and select the country you're in then use the "Contact Us" tab to get in touch with the customer service department in your area.
Posted on Jun 02, 2011
How do I know when to buy a bigger seat or which positions?
His legs bending does not mean that he is too big for the seat. He is too big for the seat when his head reaches one inch from the top of the chair while sitting in it.
Please read the information in these links for further information:
http://www.cpsafety.com/articles/stayrearfacing.aspx
http://www.thecarseatlady.com/
Nov 18, 2012 | Cosco Scenera Convertible Baby Toddler Car...
Pt cruiser stuck middle seat belt
The problem:
The set belt stop has been lost so the seat belt retracts too far when the seat is laid flat. When laid flat the release mechanism lock as it should when not level. So the seat cannot be raised up as the belt is too tight and locked.
The Solution:
1) Push the two little clips to release and remove the headrests.
Pull the grey lever on the right of the seat base, lift seat base up and forward toward the front seat..
2) See two red capped leversat the back of the two seat hinges and lever them to the upward position, this releases the seat.
Rock the very heavy seat unit upwards and lift complete unit upwards.
3) Take it out of the car and turn 180% so that the back of the seat and base are in the upward position and the seat belt will pull out as it should
4) Replace the missing belt locking stop (I used a tie pin permanently fixed using super glue).
5) Fold seat back down and test then either re-fit seat unit or leave out to decrease fuel consumption..
Aug 02, 2012 | Chrysler PT Cruiser Cars & Trucks
How do u release seat from base
Good Evening
At the front of the base unit (nearest to the edge of the vehicle seat) there is a large grey release clip. Pull this clip forward (toward the front of the vehicle) and lift the carseat away from the base. Ensure that you lift the carseat completely away before letting go of the release clip as otherwise it may not release fully and the carseat will still be partly attached.
Jan 16, 2011 | Maxi-Cosi CabrioFix (Black Reflection)...
How to install front facing baby start car seat
Identify the parts. A car seat will likely come with two parts - the base and the actual cradle itself. The base part is what will actually be in the car, while the baby cradle (seat) is removable and portable - the baby cradle can be taken out of the car and easily attaches to most grocery carts (the front part where bigger kids sit) and restaurant high chairs (move the standard restaurant high chair upside down and you will have yourself a cradle holder).
Give it a try. Place the booster flat on the backseat of your car and run the seat belt around it to hold it down - read your instructions and they will have detailed graphs on how the seat belt hurts. Also look at your car manual as they will have special instructions and buckles for car seats
Get confirmation. Move your baby seat cradle on top of the base (remember, it always faces the rear, when your child is old enough you will have to buy a different type of car seat that faces forward towards you). With your hand, sternly move your baby car seat from side to side, if the cradle is easily swaying your car booster is not securely fastened. Remove the cradle and pull the car seat belt as snug as you can and try again
Get double confirmation. Call your local fire department and make an appointment to stop by - they will check and confirm your car seat is installed securely. Remember, this could save your child's life so 10 minutes with your local fire department is only a very small inconvenience!
Oct 20, 2010 | Baby Gear
Cosco Alpha Omega Elite can't get straps back on right!
replace harness: 1) take **** harness and place metel bracket through the base of the seat(slot in shell) make sure buckle is facing out and not inwards. slide metal clip under small tab and push down on clip until it snaps in and locks into place... 2) thread harness without latch plate or harness retainer down through slot on one side of shell, under seat and up through slot on other side. 3) thread latch plate(clip that goes into ****clip)harness retainer onto the harness making sure they are correct. 4) thread harness end through other slot 5) make sure the harness goes over the barbut under the plastic bar, then fit loops on harness ends onto the harness bracket that looks like a triangle(kind of) 6) from the front even up harness to fit properly. And there you go the rest is pretty straight forward the base is pretty sraight forward to attach...
Aug 17, 2009 | Cosco Alpha Omega Elite 5-Point 22-155
Need to know how to put shell back on washer
If this is a Whirlpool top-loader, follow these steps:
1. While looking down through the lid opening of the case, place the front lip of the machine case UNDER the washer frame and start leaning it back onto the frame. There are four small cleats that must fit into four slots on the case or the washer will vibrate. Make sure the frame is seated properly, lean forward from the front of the washer, grasp both sides of the rear panel and pull towards the case. The rear panel should be seated and flush with the casing before inserting the retaining clips.
2. Insert the brass-colored clips into the slot on the washer rear panel first, and then push straight down into the opening on the top of the washer with some force. If you have the case seated correctly, the clips will snap back in.
3. Make sure you plug the connector from the console back into the lid switch receptacle BEFORE you reassemble the console. This is easy to forget.
Let me know if you still have questions. I hope this helps you.
Apr 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Child car seat - unable to put it back together after washing
You need to pass the belt behind the sit.
Mar 21, 2009 | Baby Gear
Turn airbag off for 5 series bmw
Hi , if you visit a dealer they will be able to let you know how much it will cost to deactivate the passenger air bag.
Mar 14, 2009 | BMW 5 Series Cars & Trucks
I need to replace the front driver's seat in a 95 saturn...
seat frame base is held to floor with four bolts, one in each corner.  Begin by moving seat to the full forward position, remove the two rear seat frame bolts, they may be covered by carpet and plastic trim.  Them move seat to full rear position and remove both front frame bolts, the seat will now be free to remove.  Keep me posted
Jan 06, 2009 | 1995 Saturn Sl
Quinny ZAPP Stroller Logo
37 people viewed this question
Top Quinny Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Michael Vincent Cruz
Are you a Quinny Baby Gear Expert? Answer questions, earn points and help others
