Question about Car Audio & Video
I have a pioneer head unit (DEH-P6900IB), which i bought second hand but i have no ISO wiring harness tofit into the back, do you know the model number of this or where i can etone from? Thanks.
  • 39 Answers
Your local pep boys will have them. if they dont, take it to any car audio installation place.
Posted on Aug 16, 2008
Pioneer DEH-3300 UB
Apparently, you have no power at the 12 volt battery/memory wire at the radio harness of the vehicle. This wire is white with blue in color.
Also, based upon your description, you have connected the battery/memory wire and the accessory wire of the radio to the 12 volt accessory (switched) wire of the vehicle. This wire is white with red in color.
Check the radio/ stereo fuse of the car. You may have blown the fuse during your installation.
You have no memory at the radio because when you turn off the key, you lose all power to the radio.
Also, I mentioned the wire colors just in case you used an aftermarket radio wiring harness. Make sure that the yellow from the Pioneer unit is going to the battery power source and, the red of the Pioneer is going to the switched power source.
Sep 12, 2012 | Pioneer Car Audio & Video
I Have a 2000 Impala without onstar, i tried to replace the in-dash radio with an aftermarket one, i bought an 80$ wiring harness for my car because of a chime and it came with 4 rca cables along with the...
The four RCAs are for the speaker outputs.They plug into the rear of the Pioneer unit (front and rear outputs). Also, you didn't mention the model number of the wiring harness (necessary to properly diagnose the situation) but, some these units have one or two philips head dials to adjust the volume of the stereo and the volume of the chime. These dials may be on the side of the unit or, oyu may need to open the casing to see them.
Jan 26, 2011 | Pioneer DEH-3900MP CD Player
European Wiring harness not compatible with US bought Stereo
This is not as straightforward as you may think.
You can certainly buy a generic adapter harness which will plug into the European DIN harness and then provide you with the bare wire tails to patch into. You may even find one which plugs directly into the rear of your head unit without the need for patching.
But you'll find that your head unit still won't work properly as the US uses a different FM channel range to Europe (US frequencies are odd, e.g.102.7, Euro frequencies are even e.g.102.8). The channel spacing is also different.
The radio itself cannot be converted, but you may be able to buy an external converter. It won't be cheap, and the head unit display will still always show the wrong frequencies. Channel changing may have to be done directly on the adapter and not on the head unit as I don't think that the DEH-P3000 has any way to communicate a request for a channel change to any external device and this also means that radio channel presetting may be impractical/impossible.
Considering that the DEH-P3000 is an obsolete unit and nothing special to begin with you can buy a brand new Euro-spec head unit of equivalent quality for less than the cost of adapting your unit and it will work correctly without any awkward Heath Robinson adaptations.
Sell your Pioneer back to the USA where it belongs or bin it as it's useless over here.
Jan 24, 2010 | Pioneer DEH-P3000 CD Player
Can't fit subwoofer amp leads to pioneer DEH-2000MP Head unit
pioneer head units only distribute like 200 rms or so to the speakers. you might have to find a blue maybe even blue with white striped wire and nick it just enough to tie your amp wire around it. tape it up and see if it works.
Feb 24, 2009 | Pioneer DEH-2000MP MP3 CD AM/FM Car Stereo...
Pioneer deh 1600 has no power
Well.. if there is smoke coming from the head unit, the head unit could be bad. It odviously may have a wire crossed or a fuse blown, or even the wire harness could be bad. First, check the fuse for the radio on drivers side door, then check the other fuse box under the hood. Make sure all radio fuses are intact and not blown. Second, check behind the head unit to make sure no wires are touching each other and shorting out. Third, if nothing else helps, buy a new head unit & wiring harness :]
hope this helps!!!
Jun 12, 2008 | Pioneer DEH-1600 CD Player
No plugs
Do you mean there are no wires attached to the unit, or are you saying there isnt a harness. Odds are if there isnt any wires, that was probably stolen out of something.
Dec 08, 2007 | Pioneer DEH-P7800MP
Car Audio & Video Logo
124 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
