Question about Dishwashers
GE Dishwasher model #GSD6960N10SS. Water does not drain. Turn on & off but cycle does not run. Please help. Thank you.
SOURCE: GE Dishwasher is not draining water
GE Prifile dishwashers have a valve called a "Piston" and an "O" -Ring under the screen that become degraded over time. The part is around $10 and it takes about an hour to do the repair. You can do this yourself if you are handy and have some simple tools. You can go to the GE website and get a free owners manual.
Posted on Aug 01, 2008
  • 116 Answers
SOURCE: Not starting wash cycle
Typically this means that there has been a water leak of some sort and there is water in the lower base pan. This is the large white plastic base that the dishwasher sits on.
If you remove the toe kick and look back past the fill valve on the extreme left side of the dishwasher about 6 to 8 inches from the front you will see a red stick that goes straight up and down. This is a mechanical linkage that activates the drain feature. Be careful as there are live connections here.
This stick rests on a round piece of Styrofoam that acts as a float. If there is water present it will cause the stick to lift and the dishwasher will go into drain. The source of the leak will have to be isolated and corrected. Most likely it is the fill float assembly as referenced at the end of this post.
If the stick is not in the upright position then there is possibly an issue with the switch mechanism itself.
You will have to pull the dishwasher out from beneath the cabinet and remove the panel covering the left hand side. If it is a full panel then there are a couple of screws holding it on from the front through side trim as viewed when the door is open if it is a half panel then it can be removed by removing the large torx screw on the lower right as seen when facing the panel.
If there is a problem with the switch then the entire mechanism should be replaced.
Try the following link to a picture for reference. It is upside down as compared to the installed one:
http://www.repairclinic.com/SmartSearch/SSPartDetail.aspx?PartID=935595&PPStack=1
Posted on Sep 17, 2008
wheelshot
  • 102 Answers
SOURCE: dishwasher runs, water doesn't drain out
sounds to me that you may have some suds residue in the dishwasher that keeps it from draining completely. Get you some dishwasher cleaner which you can purchase at wal-mart or wherever you buy your detergent, and clean out your dishwasher. It is a inexpensive test. Alot less expensive than having a tech come to your house. Make sure that your drain hose is mounted higher that where it goes into the drain. This is also a common problem that I encounter in the field. Hope this helps. Let me know if I can help you futher.
Posted on Apr 04, 2009
  • 12104 Answers
SOURCE: water not draining
check and clean floor drain of unit
Posted on Oct 07, 2009
joe_lishman
  • 192 Answers
SOURCE: GE GSD2000J01WW dishwasher , full of water at bottom of machine
The drain motor (pump out motor) in line with the outlet pipe could be faulty. This motor must spin (to pump out water) in the drain mode. If AC (mains)voltage is across motor in pumpout mode and the motor does not spin indicates that the motor is open circuit and needs replacing. Has one of the 2 motor push on electrical connections dislodged?
Is the outlet pipe obstructed?
Posted on Jan 22, 2010
GSD4020Z07BB won't drain. replaced pump and piston nut
When you replaced the pump I am assuming you replaced the whole assembly that pumps water for the wash and drain. See item 310 in this diagram.
http://www.searspartsdirect.com/partsdirect/part-model/GE-Parts/Dishwasher-Parts/Model-GSD4020Z07BB/0432/0130000/G0040034/00003?blt=15&prst=&shdMod=
If the dishwasher goes through the wash cycle then it was unlikely the thing that was faulty. The pump is shared by both the wash and drain cycle. It is likely the impeller (item 429) is not getting the pulse to change direction so that it draws water from the drain sump to the drain hose rather then to the wash arms as it does in wash cycle. The solenoid connection might be faulty or the controller output is not there.
Apr 21, 2014 | GE 24 in. GSD4020Z Built-in Dishwasher
Dishwasher works fine except that after the drying cycle, water slowly builds up in the bottom of the dishwasher. It did this a few years ago for several months, but then it stopped doing it altogether. ...
This would mean that the dishwashers water valve has failed. This is a simple repair to make yourself. The lower access panel would need to be removed, four screws. You can purchase the part from the link below.
Appliance & Refrigerator Parts
Mar 23, 2011 | GE Dishwashers
My GE Model #5500 does not drain the water after a washing cycle.
Hello & Welcome to FixYa
As the water did not drain completely then check the drain hose & drain pump filter for any clogs/obstructions, to do this you'll have to take the front bottom panel out and then clean it completely. If you have already cleaned these parts and the unit will not work then replacing the drain pump is recommended repair. Please get back to me if you have any other questions.
Kevin
Feb 03, 2011 | Maytag Dishwasher
Dishwasher wont drain even after running rince cycle is there steps to reset system ;ready to overflow
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat. Hope this helps... Please post back for any further assistance.
Daniel
Oct 26, 2010 | GE 24 in. GLD5860LSS Stainless Still...
The dishweasher will not drain.
Most likely the filter plate and sump is clogged.
Have you tried cleaning it up. If you cannot hear the pump running during the drain cycle, then it is likely the pump is blocked or the motor is faulty. I am assuming the dishwasher completes the wash cycle - i.e., it takes in water and the arms move, the water gets heated, etc.
please provide full model no. of the dishwasher
Aug 11, 2010 | GE Dishwashers
Running but not cleaning
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Dec 11, 2009 | GE Dishwashers
My dishwasher does not completely drain. It leaves about 3 inches of standing water. What could be causing this?
Without knowing the model of this GE ? dishwasher, it is very hard to be specific. Most DWs have a float/switch that sense when the dishwasher is filled and empty of water. They can fail.
If you can run a cycle without the dishwasher over flowing but it simply does not fully drain, I would pull the lower spray arm and the filter beneath that arm. Look closely for debris that could be blocking the pump. SOme dishwashers simply have a timer that controls each phase of the wash, including the drain cycle. If something is blocking the drain pump, an obstruction could cause this problem.
Good Luck, Please report back with what you find.
Apr 05, 2009 | GE Dishwashers
Water doesn't run in to clean dishes
if the water line not blocked or pinched... then I would your fill valve.. it may not open all the way...before replaceing the water valve...check that the water is come into the dishwasher but maybe going out the drain..If the drain hose is too low water will run out before the dishwasher can run a cycle... to check it it must raise above the bottom of the sink ... this keeps water from running out and sink water from going into the dishwasher... let me know if it helps
Jan 29, 2009 | GE 24 in. PDW7880JSS Built-in Dishwasher
GE Triton Dishwasher fills with water but no spraying occurs.
Trouble shooting GE dishwasher
Model GSD6600G00WW
Air gap is clean
Garbage disposal is clean
Dishwasher fills with water OK
Drain pump runs after a wait of several minutes and seems to run slow but drains most of the water out of the reservoir.
Dishwasher is not running the wash cycle (spraying water on dishes)
Jan 27, 2009 | GE 24 in. GSD6660GSS Built-in Dishwasher
Jan 08, 2008 | Dishwashers
Dishwashers Logo
69 people viewed this question
Top Dishwashers Experts
Owen Barnes
