Question about Vintage Keeper Koolspace Wine Cellar
I have a Minikool Model AZMN Serial # AZMN-11 It is leaking thru the plastic drain pan.How can I get this part to replace.
3 Suggested Answers
  • 842 Answers
SOURCE: Cannot get temperature below 65F. Probably
I have never heard of a wine cabinet getting below that range? Has this unit every reach temps that low before? I would make sure the unit is breathing, check the condenser and air flow through the unit. If the unit is not choking, and temps can go below 65, than yes you will need to have it serviced. It can be a thermostat issue.
Good Luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Posted on Jul 13, 2011
salasaaron
SOURCE: I need to replace my
you want the same model? if so, aaroncoconstruction@gmail.com
Posted on Sep 14, 2012
My fridge leaks water on my kitchen floor. I have replaced the defrost drain with a redesigned part. recently it started leaking again. The freezer compartment was frosted up.
The redesigned drain could be missing the evap pan completely or the pan itself (flimsy plastic) could be broken or cracked or mispositioned.
Aug 18, 2016 | Refrigerators
Leaking on floor
I would pull the back panel off of the fridge and look for the drain coming out of the bottom of the fridge and make sure it is aimed at the black plastic drain pan. The drain pan usually has the discharge lines off of the compressor ( the copper lines) going through it to evaporate the water, if the drain line is not lined up properley then it may drain on the floor instead of into the pan
Sep 07, 2012 | Kenmore Refrigerators
There is water leaking out from the bottom of my furnace. It leaks whenever the ac is running.
Hello, sounds like a clogged condensate line or a faulty condensate pump if the unit has one. Cleaning the drain line should fix the problem.
Jul 12, 2011 | Heating & Cooling
Leak from refrigerator bottom when dispensing water
Good day,
The water supply starts at the dispenser, runs thru the door to the door's bottom where it connects to a swivel connector.
From there it travels under the machine and back into the fresh food compartment to a reservoir located behind the crispers where it is chilled.
It comes back out and travels to the filter system if you have one, and from there to the water valve located on the back rear of the machine.
One of the plastic lines or a fittings is leaking.
It's a look-see repair. Should be one person drawing water, while a second should be looking with a flashlight.
Nov 20, 2009 | Whirlpool Refrigerators
CLOG DRAIN FOR REFRIGERATOR
Hi, thanks for the question. these new ,or older fridges have the drain tube, between the walls of the fridge , and what happens is the water in that drain tube freezes. so the water in the defrost cycle ,cant go down to the drain pan. to repair fridge must be turned off. for at least 24 hrs. insert a small plastic tube, from the drain tray up to the freezer, an blow up the tube to clear. thanks the appliance doc. please rate my answer thanks..
Oct 07, 2008 | Frigidaire GLRS264ZA Side by Side...
My central air conditioner which is 901282 Intertherm is rusted out and leaking. It looks like that the base can be replaced. Can you help me?
Yes, the base is called a pan and it can be replace with a plastic pan, or they have a liquid whic can be poured thru standing water and seal rusted pan leaks.. >Check out Palmer Supply in OKlahoma on the web-page but if you need the plastic pan check out the company of the unit web-page! Thank-you-very-much!
Aug 28, 2008 | Intertherm Heating & Cooling
When I keep my air condition on auto and it has ran then turns off when the temp. is reached it has began leaking
your unit needs cleaning.
when fan is running, it creates a vacuum that hold the water from spilling from your unit, then at auto, as the temperature is reached, the fan would stop and the vacuum that keeps the water from spilling would disappear and starts to leak water.
have ti clean....
that would eliminate your problem..
tnx 4 using fixya,
drcool
Aug 27, 2008 | Heating & Cooling
Water leak
Unplug the refrigerator, open the door and get a blow dryer and warm up the freezer. wait until the water stop dripping out or about 12 to 24 hours and then you can plug it back in . it will work for 2 to 3 weeks. To unplug the drain.defrost the freezer .remove the back cover. Use a pipe cleaner to clear the drain. pour a few cups of hot water down the drain. the drain hose may be just pulled off ...it must let the water drip in the pan.
Aug 17, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Leaking AC condensate drain pan
Check the drain line for possible plugged trap. Blow back through it in some way to try to clear it.
Jul 05, 2008 | Heating & Cooling
Vintage Keeper Koolspace Wine Cellar Logo
109 people viewed this question
Top Vintage Keeper Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Oloyede Monsuru
Are you a Vintage Keeper Furniture Expert? Answer questions, earn points and help others
