Question about Cycling
My son's BMX will no longer 'free wheel', the pedals turn continuously. If he stops the pedals the wheel stops, what has gone wrong?
    Novelist:
  • 184 Answers
The back hub will have a one way clutch (more like a starer pawl really) between the chain sprocket and the wheel.
You can access that by removing the axle and the bearings, what ever is left is the clutch. There were several designs for the clutch, and it's attachment. Some were just nut held and otherswere threaded on to the wheel spindle (most popular.)- You might need a special wrench, but most can be removed with a medium seized auto lug nut driven into the cavity and spun off with a wrench. Once removed- you can take it to the bike shop for a replacement as they are usually tore up pretty bad by the time they lock up.
Posted on May 26, 2011
Smartrike front wheel won't turn with pedals once on the ground
Old question but I just needed the answer and figured it out. On one side of the wheel there is a disc with two arrows, line this arrows up with the arrows on the wheel and push the disc into the wheel until it clicks into place. Pull it out to convert back to a stroller.
Nov 29, 2012 | Kent International Smart Trike Sport...
Trying to remove front tire from my son's Haro BMX bike, and can't get the bolt to budge at all.
It is possible the wheel has left-handed threads. Put your thumbnail in the groove of the thread towards the end of the axle shaft and see which direction the threads are cut.
Nov 01, 2017 | Cycling
The brake pedal went to the floor and my son in law almost couldn't stop. I changed the master cyl. The pedal feel got better but still goes down. Does not have a firm feel to it very soft. Sometimes...
just because you installed a new part doesnt mean its not defective....pull the wheels off and check to see if the pistons move freely in the calipers(remove calipers and try to press in with channel lock plyers). see if rear wheel cylinders are working with drums on , have someone press the brakes and you turn the drums.
Aug 19, 2011 | 1995 Toyota Land Cruiser
Chain is turning but the rear wheel is not moving
What??? RLtoFixYa doesn't know what they are talking about. Your problem is a faulty/broke "one way roller clutch" which is threaded onto the rear wheel. I've already replaced 2 on my son's MX500.....
May 25, 2011 | Razor MX500 Dirt Rocket
Hi my son has a 2011 Eastern Lowdown BMX bike and he bought a pair of pedals to swap onto it. I have a simple question - before stripping the threads, are the pedals reverse threaded? ie, left to tighten ,...
Only the left pedal (as you are sitting on the bike) is reverse threaded.
So for the left pedal you turn the bolt head clockwise (towards the back of the bike) to loosen it.
And for the right pedal you turn the bolt head counterclockwise instead (still towards the back of the bike) to loosen it.
Here are a few links to some website articles and videos with more information:
http://www.jimlangley.net/wrench/pedalbasics.html
http://www.youtube.com/watch?v=SXxplE_L1Rw
http://www.ehow.com/video_4415604_remove-pedals-bicycle.html
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and videos at the websites indicated.
Thank you and good luck.
May 13, 2011 | Eastern Bikes 2010 Lodown BMX Bike
Wheel does not turn when peadalled
needs a new sprocket on the wheel the teeth inside are worn
Oct 12, 2009 | Mongoose 20-Inch Gravity Games BMX...
When you pedal you dont go anywhere and everything is moving chain and gears
Your rear wheel freewheel assembly is probably shot and the easiest solution would be to buy a new rear wheel. Bring the old one in with you to be sure you get the right one. Most of these can't easily be rebuilt.
Jun 29, 2009 | Cycling
Chain & Sprocket turn, but Rear Wheel Not engaging/spinning
The problem is witht he flywheel on the rear wheel assembly. I had mine fixed by a professional last night (at a bike store). Razor uses a very cheap spring that is designed to fail and then to top that off did not use enough bearings as well (12 bearings short out of the factory). My son had also sprayed WD-40 all around the back axle (trying to make it faster). This is bad because, the bearings are packed in grease and WD-40 is a de-greaser. Never get WD-40 anywhere near your back axle!!! Anyway, the flywheel was way easier to remove than I thought. It is threaded onto the rim's axle shaft and just screws off. Once you get the flywheel, off you have to take it apart, fabricate a new spring (my son's new spring came from an old 10 speed's tensioning spring), reset the 3 pawls, repack the bearings, put the flywheel back together, and screw it back onto the wheel. I will post a YouTube video on this later. Hopefully this is enough info to get you started.
May 10, 2009 | Razor MX500 Dirt Rocket
Weird noise on my bmx bike
It sounds like you have cracked or broken one or both sealed cartridge bearings if thats what your bike has. If it has ball bearings in races they might be broken. Try loosening your rear wheel enough to take the chain off and then turn your crank. See if theres a funny noise or if it feels a little weird when its turning. If you broke a pedal bearing you should be able to tell just by carefully turning each pedal with your fingers and seeing what it feels like. In any case unless you have the tools to repair it you will have to take it in and get it repaired.
Mar 26, 2009 | Mongoose 20-Inch Gravity Games BMX...
When i push on the pedals the backwheel doesnt go around
You my friend have a stripped free wheel.  The only solution is to get a new free wheel or just go out and get a new rear wheel all together.
Feb 14, 2009 | Dell Dimension BMX Cassette hub 48h...
Cycling Logo
64 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
