Question about Poulan Garden
How to replace a fuel filter for weedeater gas blower BV200
  • yadayada
    yadayada May 26, 2011
    These do not have an inline filter.
    Sergeant:
  • 281 Answers
There is a filter inside the gas tank on the end of a flexible tube.You need to bend a hook in stiff wire and use it to fish out the filter so you can put another filter on.
I always add this for your information. If this is not the solution that you are looking for please re post because when we pick a question to answer FixYa takes it out of the questions.
Posted on May 26, 2011
Weedeater BV200 will not crank. I have put in a new plug and a new Ignition Module (gap at .008). It is getting spark and appears to be getting fuel. The compression is at about 85 after 3 pulls. Any...
if your getting spark, then most likely its bad gas, or carb needs adjusting. i would rebuild the carb 1st, then adjust. if it has old gas in it, quite possible its gunked up. if no help there, take muffler apart and check screen. these go bad quite often. and always make sure air filter is atleast clean, or replace it every season. most neglected, and so so important. if a machine cant breath, it cant preform!
Sep 22, 2010 | Poulan Garden
Gas does not seem to be getting to the carburetor
Check the fuel lines going to the carburetor from the tank to make sure none of lines have decomposed or gotten soft also check the fuel filter inside the tank to make sure gas can get through...if the lines or filter are bad... replace them...bulk fuel line and filters available at any mower shop or mower parts house....a fairly easy job !!! hope this helps... ;-D
Aug 11, 2010 | Weedeater Gas Blower
My Weedeater Leaf Blower will start OK, when it has not been used for several days. But after running about 10 minutes it, just begins to slow down and die. I have cleaned the air filter and that did not...
The fuel filter is in the tank. Make a hook from a coat hanger and snag the filter, gently pull it out the fuel filler opening. Then it just pulls off of the fuel line.
Jul 25, 2010 | Weedeater Gas Blower
Weedeater blower will not prime
The primer bulb sucks fuel from the tank to the carb. When the carb has enough fuel the remainder is sent back to the tank. When you replaced the fuel line did you use the exact length of line and did you re-install the filter. On some of the trimmers the filter is weighted and holds the line in the fuel. Good luck...Lee
Sep 24, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replace fuel lines WeedEater FL 1500 Blower
On the FL1500:
  • The Smaller line goes on the Lower inlet tube on the carborater the other end goes to the gas filter inside the gas tank.
  • The Larger line goes on the upper outlet tube on the carborater the other end goes to a fitting that holds this tube from coming out on the gas tank .This tube is only for Air, it helps fill the primer bulb when pushed.
I hope this helps.
Mechs correct me if I have made a mistake.
Thaxs Jon
Sep 09, 2009 | Garden
On weedeater blower and vac gas line is broke from carb into tank does it just connect to fuel filter in tank model 1925
Yes if your asking about the fuel line yes it hooks to the filter out thru the wall of the gas tank straight into the carb. if it broke out side the tank you can try a smaller plastic hose to stick inside to reconnect the two parts. if it broke inside the tank try to replace as one hose.
Jul 12, 2009 | Poulan/Weed Eater No. Bvm200le 711482 24cc...
Routing of fuel lines for a weedeater bv200 type 2. Which lines go where from the carb into the tank?
The line with the filter goes to the bottom of the carb. The other line goes to the outlet side of the primer bulb and the other line from the primer bulb goes to the top of the carb (The primer sucks gas through the carb).
Ps. if you are not sure which nipple of the primer is the outlet port then put your finger on one of the ports and push the bulb. If the bulb stays ridged then that's the outlet and if it collapses but doesn't fill but up then that's the inlet side.
Jul 10, 2009 | Garden
How to you repalce a fuel line on a weedeater gb1/22v leaf blower
When replacing fuel line, make sure that you have the correct size lines. Depending on the size of your engine, the lines may vary in size. The primer bulb line will sometimes be larger in diameter than the fuel line to the carburetor. The primer bulb line will be the shorter of the two. When replacing the fuel line, make sure you have enough line to go from the bottom of the tank up to the carburetor. Give yourself a couple extra inches to work with. Cut one end at an angle, this makes it easier to feed down through the hole. Continue feeding the line until it comes out of the gas cap hole. Then cut the end of the line square again and attach the fuel filter that goes on the end of the line. Place the filter back in the tank, then adjust the line so that the fuel filter lays comfortably at the bottom of the tank. Then attach the other end of the line, (where you inserted it), to the carburetor, cutting off any extra line you may have.
Mar 27, 2009 | Poulan/Weed Eater #Wt200 711724 24cc Gas...
Garden Logo
170 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
