Ovens Logo
Posted on May 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My oven will not come on and is showing the message 5A6. Could you tell me what this might be?
Anonymous
Level 3:
  • Maytag Master 2,605 Answers
  • Posted on May 26, 2011
Anonymous
Maytag Master
Level 3:
Answers
2605
Questions
0
Helped
1118929
Points
11111
Hello, welcome to FixYa.
It sounds like the unit has been placed in "sabbath" mode somehow, hence the display showing the digital abbreviation for sabbath "5A6".
If you have you owners manual it should instruct you how to disable it, but if you don't have it you will need to confirm the make/brand name is a Maytag and model number and I'll see what I can find.
I'll watch for your reply and if you need anything further I'll be glad to help in any manner I can.
Regards,
Macmarkus :)
The bottom oven shows the message "no mode available in this oven". It doesn't work
restart the oven and check if the message shows up. Also, switch between modes on your machine and check if it affects the bottom oven. Thank you.
Oct 03, 2022 • Ovens
My oven is comimg up with the F4 fault message?
Hello Rose,
The error code F4 are code that mean their is a problem with the oven tempature sensor and that sensor is uncappable of telling the control board what the temp. is in the oven. This is what the sensor looks like,oldtech2332_20.jpgTo check the sensor,unplug it and place meter leads into the white plastic plug at the end and check for between 1060-1100 ohms of resistiance when its good.
The F4 error code is for sensor that has a open circuit,so instead of the 1060-1100 of a good it the display on the meter will show infinate resistiance ( the meter display will not change)
If at room tempature when checking the oven sensor if the display shows anything other that 1060-1100 ohms the sensor is going to be the problem and needs to be replaced.
GENE
Oct 19, 2011 • Ovens
In trying to change clock did something wrong and now will not do anything, screen showing 5A6 6ath. what can i do to fix?model#mew5527ddb16 serial# dx2614846
power down the unit at the circuit breaker for an hour or so and see if this clears the memory,otherwise try pressing stop/cancel or any combination of these types of end buttons at the same time to cancel the error message
6helpful
2answers
WENT TO SET CLOCK, SOMEHOW DIS-TURBED THE CONTROL BOARD, IT IS LOCKED, READS 5A6, CAN I UNLOCK IT?
Your range is probably in the Sabbath mode. The error code shown on the display is"Sab", not "5ab" or "5A6.
To disable the Sabbath mode push and hold the Clock pad for 3 seconds
Mar 13, 2011 • Ovens
4helpful
2answers
My oven will not move from SAb o 5A6 and buttons
You have inadvertently entered the Sabbath Mode.
Try holding the clock button for 5 seconds to clear it out.
RANDOM F-? Flashes...
the problem is the sensor in the oven this a probe looking item they are costly so tell the landlord
1helpful
Oven will not turn from top panel electric panel is stuck on 5a6
Unplug this unit for 3 minutes. if the control fault still exists after the 3 minute reset, replace the affected control board.
Top Maytag Ovens Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Paul Carew
Are you a Maytag Oven Expert? Answer questions, earn points and help others
