Question about Shark Navigator Bagless Upright Vacuum
The beater brush doesnt work on the carpet and makes a loud squeeking noise.It looks like the brush sticks out past the base and gets stuck on the carpet . Works good on the bare floor.
  • Anonymous Mar 18, 2014
    When the Navigator is in Bare Floor setting, it will not **** up any dirt. The brushroller setting seems to work fine.
    Sergeant:
    Novelist:
  • 159 Answers
It seems that your drive belt for the beater brush is stretched. This is a common problem -- if you flip the vacuum over so you are looking at the bottom, you should see several screws holding a faceplate in place. Unscrew these, and you should be able to get access to the beater brush and belt. Pull on the belt a little -- if it has a lot of give, or seems stretched or cracked, replace the belt and your vacuum should be fine. If it is not stretched or cracked, move the belt and look between the belt and where it holds onto the brush (there should be a little groove that the belt is sitting it). If there is a lot of debris or hair (I have long hair and this happens to me quite often) between the belt and the brush bar, clean it out, and you should be good. The squeaking noise leads me to believe that the belt is stretched and could be replaced.
Posted on May 26, 2011
Y Shark "Professional" model 540 26 is making a terribly loud noise and not picking up dirt. t also gets HOT
Check( 'beater bar',suction tube to canister) for accumulation of hair,carpet fiber,pet hair,etc....cut hair,etc,with scissors,clean...might also be hair stuck in belt that drives beater bar
May 08, 2017 | Shark Vacuums
Oreck vacuum cleaner stop and burn smell
sounds like hair or string or something like that is wrapped around the beater bar(the long brush under the head that brushes the carpet) keeping it from turning. The belt that drives the bar is getting hot because the beater bar is stuck.
Aug 12, 2014 | Oreck Vacuums
Beater bar making a loud noise
Our DC33 was making the same ratcheting sound immediately upon placing the cleaner/brush head on the carpet. We carefully pulled the beater/brush bar out of the vacuum. Once removed, we pulled the black plastic end nearest the belt off of the center rod. We discovered hair wrapped around each end of the center rod. After the hair was removed and the clean/brush bar was re-installed, the vacuum ran flawlessly. Hope it works as well for you as it did for us.
Apr 02, 2014 | Dyson DC14 Animal Bagless Upright Cyclonic...
Sounds like the beater bar hits the front plastic makes a loud awful noise
Hi Cathy,
Your DC33's brush control is designed to make a ratcheting sound to warn you if something is jamming the brush bar. You should be able to resolve this by making sure the cleaner head is free of any obstructions, and removing any threads or hair from around the brush bar. For guidance in doing this, please follow the steps shown in our online Support guide:
http://www.dyson.co.uk/support/dc33/dc33-multi-floor/dc33-maintaining-your-dyson-machine/how-to-remove-a-blockage/from-the-brushbar/removing-debris-from-the-brushbar
This should resolve the issue, but if you're still concerned about the machine after following these steps, please give us a call on 0800 298 0298 (UK), or 1-866-693-9766 (US), so we can provide further assistance.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Apr 27, 2012 | Dyson DC33 Animal Bagless Upright Vacuum
Dog hair gets caught all the time in the belt drive spool, is there a fix for this other than having to pull it out all the time by hand? I have replaced the belt and the brush but this hasnt solved the...
My Dyson started making a loud noise when in "carpet" mode. After reading a ton of forums I thought it was the clutch assembly. Got a new one on eBay for a great price. Somewhat hard to replace, but thanks to this YouTube video, I was able to get it in: http://www.ezvacuum.com/dyson-dc07dc14-clutch-assembly-90025204-genuine-p-1636.html
HOWEVER this did not resolve the issue. I realized the beater bar was not spinning or was slipping. I thought I cleaned it all out but realized you need to take the beater bar out and pop the end cap and clean out the INSIDE of the beater bar (tons of lint and cat hair). I additionally sprayed WD40 in there.
It spins great now and in the end I think that's all I had to do was clean out the cat hair build up inside the beater bar. But now I have a new clutch & belts too. Hopefully won't have issues anytime soon.
Dec 20, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
Beater bar not turning, making loud sound
This machine has a clutch assy. that slips and makes a loud noise
when something gets stuck in the roller brush. If you have nothing stuck in the roller brush chances are the clutch is worn and needs
replacing. Not an easy job and best done by a repair tech. You can find a video on youtube showing how to replace the clutch if you are
inclined to try to do it yourself.
Tom
Oct 22, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Dyson making loud noise
If your brushroller isn't spinning it will make the loud sound. Try removing the brushroll and reinstalling it. If this doesn't work, you may need a new brushroller.You can find one here...
http://cgi.ebay.com/DYSON-VACUUM-DC07-DC14-DC-07-14-BRUSH-ROLL-BEATER-BAR_W0QQitemZ120452265897QQcmdZViewItemQQptZLH_DefaultDomain_0?hash=item1c0b83b7a9&_trksid=p4634.c0.m14
Marci
Aug 05, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Belt wont turn makes a loud noise when put on carpet setting
If this is a Dyson with a protected belt that can't be replaced then it will have to be sent out to Dyson or get a Dyson servicepersonnel to check it over - protected belt motors are difficult to fix by yourself. If its clicking all the time, then it means the belt has to be replaced. In the mean time check that there are no obstructions on the beater bar and behind it and also check that the brush stop roller at the top of the hood is in the right position. It should move automatically when the handle is swung down in normal operation.
Feb 23, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Correct position of beater bar on a Dyson DC14?
I had the same problem. I removed the brush from the machine. The brush should move freely when removed. If it doesn't move freely, pull the ends from the brush, both ends come off(one will have a rod fixed to it). I would suggest you clean the ends and the inside of where the ends sit on the brush. I applied a little grease on both end housings(inside end housing) if no grease available try washing up liquid. Put the brush ends back on the brush. I then spun the brush to check that it moved freely. It should move freely, if it does fit it back on the machine and it should be silent. If you cant get it to move freely I suggest a replacement brush. Tip: I used a blunt knife and placed it through the belt to avoid removal of the belt. Good luck. Cheers Jason
Jan 19, 2009 | Dyson DC14 Animal Bagless Upright Cyclonic...
Shark Navigator Bagless Upright Vacuum Logo
1,495 people viewed this question
Top Shark Vacuums Experts
Thomas Perkins
Thomas Perkins
Ruth summersides
Are you a Shark Vacuum Expert? Answer questions, earn points and help others
