Question about Dewalt D28402K Heavy Duty 4 - 1/2" Small Angle Grinder Kit
My son's Dewalt D28402 angle grinder gets so hot on the metal "gear box" area that you can't leave your had on it. This happens after about 5 minutes of off/on use. Is this normal? Can the lubricant be changed? If so, with what?\r\nthanks
    Scholar:
  • 87 Answers
That is normal...
Posted on May 26, 2011
How do I remove the gear from the gear housing assembly?
first grinding wheel > flange> safety cap > 4 screws >remove axis with drive shaft crown wheel > then 4 screws remove front with the armature if you must replace cone wheel and crown wheel. remove first the carbon brushes before take the armature out.
Dec 29, 2015 | Dewalt 4 1/2" Small Angle Grinder D28402
While using my dewalt 7amp small angle grinder (using it on and off about an hour grinding hard walnut wood) I heard a pop inside the unit so I turned it off, then a few seconds later turned it on again it...
burnt out the motor
the fix is a new unit
when grinding or sanding you use light pressure and let the disc do the work
change or unclog the pad or disc on a regular basis
for fast rip down use very course then finish with a fine pad
Jul 31, 2017 | Dewalt 65091601 Brush Set D28110 D28112...
I want to use flap disc's on my grinder with out the threaded portion attached. What do I have to do to install them on the grinder.
flap discs can be used on a grinder the same as grinding disc and cut off wheels . You may need a centre adaptor as some flap discs are larger in the centre hole
Aug 31, 2011 | Dewalt D28402 412" (115mm) Small Angle...
Hi, I'm trying to change the fiber disc on a DeWalt DW402 but after pushing the locking button on top I'm not able to unscrew the wheel. If I turn counterclockwise the wheel turns, but it seems I...
  • 1 Check the grinder before you begin. The newer discs on rotary grinders have patented buttons that allow you to remove the disc without any tools. You may have one like that. In models like this, there's usually a spot to depress and then remove the disc.
  • 2 Turn off the grinder before you attempt to remove and change the disc on your rotary grinder. If it's battery powered, put the grinder in lock position so you can't accidentally turn it on. If it's electric, unplug the grinder from the wall.
  • 3 Look for a nut in the center of the disc. This is a give away that you need to use your special wrench. Sometimes the grinder comes with a tool necessary to loosen and remove the nut. Other times you need to use a wrench.
  • 4 Lock the wheel into place before you begin. You can find a button or switch at the side or back that allows you to do that. When you lock the wheel in place, the disc remains still as you loosen the nut in the center.
  • 5 Remove the nut in the center with either the tool provided with the grinder or a shop tool and lift the disc off your rotary grinder.
  • 6Lift the disc off the rotary grinder. If you have different discs, remember to check for the best fit. Put the nut back on a different way for different discs. Check for a rim and indentation on one side of the nut and a flat side on the other. A visual inspection of the disc for the rotary grinder gives you information about the side to use.
  • Here is a diagram of your grinder and the tool you are looking for is number 50...
    http://www.ereplacementparts.com/images/dewalt/DW402_TYPE_6.pdf
    Jun 11, 2011 | Dewalt 4 1/2" Small Angle Grinder D28402
    I have a Dewalt Angle Grinder (4 1/2'' D28402) Checked that I have the O rings and don't see anything missing....don't know why but blade won't tighten down (unless I put the tightening wheel, wheel side...
    What do you mean wheel side out? It should look just like the picture, the nut side of the disc threads on first. Depending on what disc you want to put on you may need a spacer that goes on first and then a threaded washer on the outside.
    Jul 08, 2010 | Dewalt D28402 412" (115mm) Small Angle...
    How do i change wheels
    There usually is a locking pin that stops the wheel from turning. MAKE SURE YOU HAVE THIS UNIT UNPLUGGED!!! Press this button in while slowly rotating the wheel, once it engages the wheel will lock. With your wrench you can now take off the blade. It may have a left handed thread so going clockwise will loosen it.
    Jun 06, 2010 | Dewalt 4 1/2" Small Angle Grinder D28402
    My dewalt dw 402 grinder, starts fine, runs for a few minutes and then shuts down. Brushes appear to be fine.
    Pull it apart and clean the armature, you will find something between the brush contacts getting larger and making contact thus shorting it out, so clean the armature with fine point object do not gouge the material out of the area between the copper plates. Also blow out any metal dust you may see.
    Jul 31, 2009 | Dewalt Small Angle Grinder 4 1/2"
    Dewalt D28402K Heavy Duty 4 - 1/2"  Small Angle Grinder Kit Logo
    328 people viewed this question
    Top Dewalt Saws Experts
    Parson's Repair...
    Parson's Repair...
    JOHN LAPIER
    Are you a Dewalt Saw Expert? Answer questions, earn points and help others
