Question about Agilent E3632A 120-Watt Power Supply
Hi, I have a power supply, Agilent E3632A, which sometimes gets the "unreg" anunciator on and I can't control the voltage. If I increase or decrease the voltage, suddenly the power supply works. This happens with load and without it.
1159A differential probe wont adjust properly
needs repair - send it back to Agilent for repair
Apr 04, 2013 | Agilent 1159A Differential Probe, 1 GHz
Carlsbro Bass Reactor 400 bass amp - power section dead
• Could be drive transistor , output transistor or both on the main amp.
But check for power supply and in the preamps also.
• A signal tracer will come in handy when troubleshooting these kind
of symptoms.
• Measure supply voltages,
• Check offset voltage
• Check idling current
Isolate , and trace afterwards.
• Schematic is really needed when there are burnt and unrecognizable
component. But one can use similar schematics to analyze circuit
problem.
Aug 01, 2012 | Audio Players & Recorders
MY PC SHUT DOWN NOT WORKING
Try to check the power supply, if the fan rotates as you turn it on, the try to open it and look for the motherboard capacitors there maybe some leaks on it. but if you have a spare or extra power supply try to change it. maybe you power supply brokes.
Jul 12, 2011 | Biostar G41D3 - Motherboard - micro ATX -...
Controler and sub woofer no power
This previous diagnostic, isn't good, if you test and no continuity between the positive and negative terminals generally means a blown sub.
You won't always get scratching or distortion from a blown sub. Sometimes the voice coil just overheats and burns out like a fuse. In this case there will be no sound at all from the sub, because no power can flow through the voice coil. A continuity test between the positive and negative terminals will show no connection.
Hope this helps.
Jul 05, 2011 | Audio Players & Recorders
Hi I have a Sony Bravia KLV-40S200A which wont turn on. The standby button flashes five times then pauses for about 4 seconds then flashes again. Any ideas?
Diagnostic Test Indicators
When an error occurs, the POWER LED will flash a set number of times to indicate the possible cause of the problem. If there is more than one error, the LED will identify the first of the problem areas. If the errors occur simultaneously, the one that corresponds to the fewest flashes is identified first.
LED ERROR DESCRIPTION CODE
1 Supply Voltage Trouble Panel 5V UNReg (10.5V)
2 DE5V Voltage Trouble FE5V (DCALERT2)
3 Voltage Trouble D3.3V/D2.5V/D1.8V. (DCALERT1)
4 Backlight Trouble
5 Main Supply Voltage Trouble (17.5V.DET)
6 Speaker Applied Voltage Trouble
7 Monitor an Increase in Inside-Temperature (esp. on the panel side)
8 Trident IC Trouble
Apr 18, 2011 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Just moved into a house that has low voltage outdoor lights. They were working a month ago, but not sure what's happening now. Checked transformer. Lights work in the "on" position, but...
Hi GlennMayer1
The high pitched noise you here is the switchmode electronic type power supply/control electronics malfunctioning. This could be caused by component failure in the power supply or a short circuit in the wiring preventing it from firing up correctly. Hard wiring a lamp directly to the power supply would allow you to check the system, but a replacement power supply is probably required.
regards
robotek
Jul 15, 2008 | Universal Remote Control Hampton Bay...
Wont power on
thers an open resistor near power supply secondary section,supply voltage to 5v and 12v to system control ic, or check the vertical ic for malfunction
Sep 14, 2007 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Agilent E3632A 120-Watt Power Supply Logo
112 people viewed this question
Top Agilent Computers & Internet Experts
David Payne
David Payne
Are you an Agilent Computer and Internet Expert? Answer questions, earn points and help others
