Question about Cooktops
I've installed an Electrolux 30"
I've installed an Electrolux 30" Induction Cooktop.....when the breaker is turned on the control panel items light up for approximately 3-4 seconds then they shutoff.......there is no response when I press (for 4 seconds) either the Lock Pad or the Main Power Pad. I have flipped the breaker (40 AMP) off and on and the with the same result. I also have an Electrolux 30" wall oven sharing this circuit and it works perfectly. Suggested Solution(s)????
  • 157 Answers
SOURCE: Electrolux induction cooktop shuts off and won't turn back on
There is an internal thermal circuit breaker. The breaker has gone bad. On-line of Electrolux find a service manual of your model to locate the breakers location. Contact a local appliance parts store for a replacement also ask for heat sink gel(very small amount). Trip the circuit breaker, remove bad one, clean the space, apply gel and replace it.
Posted on May 14, 2010
SOURCE: Kenmore Elite Induction Cooktop Error Code 41
I realize this is over a year old. I have the same unit with the same error code. Last night, mine made a popping noise followed by smoke and then displayed the 41 and all E's. I pulled the breaker immediately. I'm sure that at least one controller board is toast.
I called Sears and it is under warranty but for parts only, so I guess I will give them a call and schedule the repairman. This should be fun.
Anyone else experienced this failure??
Posted on Jul 16, 2010
SOURCE: whirlpool induction ceramic cooktop error E6
my induction ceramic cooktop is showing an error code E6 on two of the elements...what is the problem and how do I get it fixed
Posted on Dec 21, 2010
  • 10865 Answers
SOURCE: 36" Wolf induction cooktop cannot get past show
Hello John..... Call the store and ask them what code is needed for this model. They put it in showroom mode and they should have taken it out of showroom mode before it left the store. Shame on them. Joe
THanks for choosing Fixya!
Posted on Dec 29, 2010
chrispolkele
  • 4342 Answers
Our people make the difference
    Verified Fixya Pro
    SOURCE: Electrolux Induction Cooktop E36IC75FSS Error Code 41
    Hi Sue -- when you switched the breaker, how long did you leave it off before switching it back on? Generally, it's a good idea to leave the breaker off (or unplug the unit) for a full 30 seconds before switching the unit back on. If you did have it off for 30 seconds and the error code came on after that point, then it may possibly be a relay isse. That will more than likely require a visit from an authorized servicer to properly diagnose the cooktop. Hopefully the 30-second test prevails and the issue is resolved. Best of luck!
    Posted on Aug 29, 2012
    Displays error 40. Why won't it turn on?
    Hi Dolores, I understand that your cooktop will not turn on after receiving an error code "40". Usually this error code can indicate a communication error between the Induction Module, Relay Board, and Control Board. I would also recommend doing a hard reset by unplugging or turning the household power breaker off to the appliance for five to ten minutes. If the problem persists, please reach out to a professional technician. Hope this helps! -JK
    Oct 01, 2015 | Electrolux 36" Electric Hybrid Induction...
    Prestige induction cooktop showing error E4
    Good Afternoon friend, I appreciate your inquiry!
    Typically on an Electrolux induction cooktop the "E4" error code stands for key sensor for timer. Which means you could be experiencing an issue with the right board, center board, or left board. I would perform a reset on your cooktop and you can do that by flipping the household circuit breaker off for ten minutes.
    If that does not assist with clearing any false error codes or the error "E4" continues to display I would suggest seeking assistance from a professional for proper diagnosis and repair. Hopefully this helps. -Matt
    Oct 18, 2014 | Electrolux 36" Electric Hybrid Induction...
    Induction error e6
    Hello it07002 - You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then the unit more than likely may be experiencing an issue with the EOC (Electronic Oven Control) and/or user interface board. This is not a typical do it yourself job; please consult a professional or your manufacturer.
    May 07, 2013 | Electrolux 36" Electric Hybrid Induction...
    Electrolux E 95 code
    Hello Robert - Typically, error code E95 indicates a power voltage miscommunication to the main components of the unit. You may try and reset the induction cook top by disconnecting the power to the unit for up to 30 seconds by flipping the circuit breaker off and back on. This often clears most false error codes. If the error code does not clear, then I would recommend contacting a professional to proceed further.
    Apr 25, 2013 | Electrolux 36" Electric Hybrid Induction...
    F11 reading on control panel of electrolux induction range
    Go to the Electrolux website on your computer and look up the model of your range. Th owner's manual should give you what you need...download it!
    Dec 25, 2012 | Electrolux EW30IF60IS | 30" Induction...
    Aug 27, 2012 | Electrolux 37 in. Designer Series...
    ELECTROLUX ERROR CODE E95
    Verify AC input voltage at the cooktop input. Verify AC main input cables, screws and jumpers. Verify the fuse resistance to be approximately 0 ohms on the Induction Module. Replace the Filter Board on the Induction Module.
    Aug 07, 2012 | Electrolux 30" Electric Hybrid...
    May 13, 2010 | Cooktops
    Cooktops Logo
    44 people viewed this question
    Top Cooktops Experts
    Dan Webster
    Dan Webster
    Paul Carew
    Are you a Cooktop Expert? Answer questions, earn points and help others
