Acer aspire 5515 says no wireless device present. i have hooked up the ethernet cable and the net connects, what can i do to get my wireless to work again.
SOURCE: Acer Aspire 4315 can't connect to internet through wireless ADSL router
netsh int ip reset reset.log
netsh winsock reset catalog
Reboot
Posted on Oct 06, 2008
  • 100 Answers
SOURCE: Net Adapter Not installed
follow this link to download your driver ---
http://www.acerpanam.com/synapse/forms/portal20.cfm?recordid=4486&formid=3394&website=AcerPanAm.com&siteid=7117&words=all&keywords=&areaid=2
download and install
if you still have problems let me know.
if it works please mark this thread as fixed :)
Posted on Dec 26, 2008
SOURCE: toshiba laptop A25 integrated ethernet and wireless lan not working
Right, you need to click
>Start
>Computer
>Vista C
>Toshiba
>Drivers
>WLAN
>Realtek
Then find a file called Setup, there may be several. You are looking for the one which is an Application. Mine is around 450kb in size.
Double click it to correctly install the Wireless adapter.
Follow the instructions on screen. This should take no more than 90 seconds from start to finish.
Good Luck
Posted on Dec 28, 2008
ebay312
  • 118 Answers
SOURCE: i have an acer aspire 5515 and im trying to hook
Somewhere on your computer's keyboard, you have a 'fn' key. Usually, this key is in the lower left corner of the keyboard. This key will need to be depressed simultaneously with another key on the keyboard that should have two pictures of monitors seperated by a '/' mark.
When you depress these two keys simultaneously, the computer switches from the output on the laptop screen to the output on the vga port.
Additionally, you will have to configure your TV to receive the signal from the svga port. Different TV's do this diffrerently, so I'm not sure exactly how you need to do it on yours.
Lastly, the sound does not follow this connection. So, while you are enjoying the use of the TV screen for viewing whatever on your laptop, if you are watching a movie or similar activity, you will not hear very much. Laptops are not designed to fill a room with sound.
good luck
tony
Posted on Jun 08, 2009
rcirone203
  • 70 Answers
SOURCE: trouble connecting netgear wireless router to rca modem DCM425
First try connection the Yellow ethernet cable from the rca modem to your computer's network connection. If you get a connection this way, then your modem will work with a ethernet cable. If not, then call Comcast for help. The modem ethernet out to computer port must be connected to the wan line of the router. Then you can connect an ethernet cable from your computer network connection to one of the 4 ports of the router. For wireless connections you must set up the router and wireless adaptor with the same settings to connect. Follow the routers directions.
Good Luck
Posted on Jul 16, 2009
Wireless not working on acer aspire 5551a
Connect to internet using ethernet cable and update wifi driver from makers site, if this does not work then buy a usb wifi adapter off ebay or from a local store, put it into usb port and install the driver from the disc supplied with the adapter and off you go (far cheaper than replacing the wifi card)
Jan 10, 2013 | Acer Aspire 5536-5224 Notebook
My Acer Aspire One was working perfectly untill today, now it wont connect to the internet either by erthenet cable or wireless, each time i click on the browser icon it thinks about if for a few seconds...
Here are some suggestions that may help you resolve your Acer Aspire One problem.
Try to eliminate possible causes by
1. Shut down / power off all the PCs - the Aspire One and those belonging to your son and daughter.
2. Shut down / power off all game or multi-media consoles that can connect to internet via router.
3. Power off any another network connected devices (hard drives, printers, scanners, picture frames)
4. Power off your wireless router and cable/dsl modem for about five minutes.
5. Power on your cable/dsl modem.
6. After a couple of minutes, power on your wireless router.
7. Power on your Aspire One and a few minutes after desktop is loaded, shut off its wireless.
8. On the desktop's Taskbar, make sure the Wireless Network Connection icon has a red x beside it.
9. Look for the double-screen icon representing Local Area Connection in the desktop's Taskbar.
10. If not there, click start, control panel, network connections and right-click Local Area Connection.
11. Click enable on the pop-up to enable the Local Area Connection and its icon appears with red x.
12. Connect ethernet cable from one of the router's RJ-45 LAN ports to Aspire One's ethernet port.
13. The red x should disappear from the double screen icon in the Taskbar.
14. Hovering your mouse cursor over the icon should get a pop-up with the connection's status.
15. If OK, click on your IE browser icon on the desktop.
16. If nothing happens, click start button at bottom left and click on IE in start menu or program list.
17. If nothing happens, press Ctrl and Alt and Del key together to bring up Windows Task Manager
18. In WTM, click Applications tab to see if IE Task is running.
19. If not, click Processes tab to see if iexplore.exe process is running.
20. If not, check if you can start anything else such as Notepad.
21. If nothing starts, you should consider doing a recovery using Acer eRecovery Management.
22. If IE does start, click on its Tools tab then click on Diagnose Connection Problems...
23. Follow on-screen instructions to diagnose your connection problem.
24. If successful, close down IE, remove ethernet cable and restart the Acer Aspire One.
25. Disconnect the ethernet cable and turn on the Acer One's wireless with its wireless switch.
26. Big green letters "Wireless LAN Enabled" should appear momentarily at bottom of desktop
27. Followed by a pop-up balloon over the Taskbar's wireless icon announcing connection made.
28. Open IE browser again, click on its Tools tab then click on Diagnose Connection Problems.
29. Follow on-screen instructions to diagnose your connection problem.
30. If OK, the problem may be an interaction with one of the other networked devices/systems.
31. Redo this procedure but power on one of the other devices/systems before the Aspire One.
32. Redo one at a time for each of the other device/systems.
33. If the Aspire One is found to be OK with all of the devices/systems connected one at a time
34. Then the problem may be when ALL of the devices/systems are on and connected.
For example, depending how it is setup, the router's DHCP may have run out of IP addresses.
Another example is IP address conflict due to systems not flushing their IP cache on restarting.
These two examples assume the problem exists regardless either on wired or wireless connection.
If just one of the devices/systems is causing the problem, it may have been infected with a virus.
Jan 16, 2011 | Acer Aspire One Netbook 8.9" Notebook
I have an acer aspire 5515. After downloading a
hi
you have problem with you OS just reinstall OS it will solve the problem
Jun 04, 2010 | Acer Computers & Internet
I recently purchased an acer computer that has windows vista. I have a hp2200dn laser jet printer and I want to hook it up by ether net into a wireless router. Unless this printer is wireless. I have a...
All you should need to do is connect the HP printer to your wireless router via Ethernet cable (which should be included with the printer). Follow the instructions that came with your printer to set it up on your computer.
May 13, 2010 | HP LaserJet 2200dn Printer
Acer aspire one kav60 will not connect to internet using ethernet cable O/s windows xp
check your lan driver if you are using cable.
right click on my computer
select properties
select hardware
then device manager
check network adapters
the device must be enabled or driver is present.
lastly check your cable or use other cable.
Apr 04, 2010 | Acer Aspire One PC Notebook
How do I get an owner's manual for the for acer aspire 5515?
Go to the manufacturers website and search for the brand of your laptop, you can download pdf manuals from there or you can search for the owners manual on google.
Jan 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
Touch pad won't work on Aspire 5515.
If the touchpad has gone bad there's not much you can do, unless it just happens to have a loose connection. You can try disassembling the keyboard to get access to the touchpad cable and verify it but to be honest, that's an unlikely scenario.
Can you plugin a usb mouse? Or you could try an external touchpad like the Bamboo made by Wacom although that's a bit expensive. Again, it would need a usb connection though.
Oct 12, 2009 | Acer Aspire 5500 5570-2609 Laptop
Trouble connecting netgear wireless router to rca modem DCM425
Good Luck
Jul 10, 2009 | RCA DCM425 DIGITAL CABLE MODEM (RCADCM425)
I need to hook my Acer 5515 to a big screeen or a projector
most of the laptop nowdays have a vga port on them the projector can easily connect to thse laptops as it has a facility to do so
use the properties option to select the Projector screen as a 2 nd screen and open your presentation up on that screen
Jun 30, 2009 | Acer Extensa 5420-5687 Notebook
Computers & Internet Logo
113 people viewed this question
David Payne
David Payne
