Question about Garden
I have the Cub Cadet CC4125. The head for the line is very wasteful.Line will not stay in the spool. I also have Toro with the spool type head on it,and this is more efficicnt. Does Cub Cadet have a spool type head that can be used on CC4125?
    President:
  • 1,545 Answers
If the head is shot, go to Home Depot and in the garden center, you will find many replacement type heads. They may have one that will fit your machine, because they carry universal replacement string heads. Check them out because they are cheaper than the small engine repair shop.
Posted on May 27, 2011
Part soft gas primer button
Don't quite get what your question, but this may be what you're after.
http://www.ebay.com/itm/CARB-PRIMER-Bulb-BLOWERS-TRIMMERS-OEM-LG-new-/151151863704
Apr 17, 2016 | Garden
Got a new cub cadet cc 720 es when I engage the drive belts it makes a squeak/rattle noise from the front deck, took off the top and can not seems to pinpoint the source of the noise.
A lot of hydrostatic rotary mowers squeal when u engage the PTO (blades) even when properly maintained or even factory new ev like the toro groundsmaster which is top of the line in its style of mowers. At the shop at work we think it's due to a change in the angle of stress from the floating deck. Nothing to worry about. Just make sure that you completely drop the deck before you engage the blade drive.
Apr 16, 2015 | Cub Cadet Garden
How to replace drive belt cub cadet z force s 60?
Go to you tube On line how change drive belt cub cadet z
May 19, 2014 | Cub Cadet Garden
How to replace trimmer line ?
1. Remove the cap on the trimmer head, it unscrews.
2. The spool comes off, and on the inside of the spool there is a small hole, this is where you will start your trimmer line. It it will hold it in place while you wrap it. There is also arrows on the spool showing the direction that you need to wrap your spool.
3. Insert the line in the hole and start to wrap the line in the directions of the arrows, try to keep the line in rows, or else the line may bind and you will have to do it all over again.
4. Feed the line through the retainer and reinstall the spool by lining up the retainer and the slot on the outside portion on the trimmer head, the screw back on the trimmer head and you will be ready to trim.
Jun 29, 2011 | Toro Electric Trimmer
Cub Cadet cc4125 - Worn out, excessive smoke with
It's not worth the expense and time, just purchase a new one.
Jul 04, 2010 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
I have a Cub Cadet cc4125 string trimmer not starting
need a little more information .. but look for the following .. take out the spark plug and look inside with a flashlight ... if the piston is moving with the rotation of the flywheel then you likely have a blown head gasket .. if there is no compression there wont be a load on the pull cord .. a cracked or damaged piston can also do this .. ... if the piston is not moving when you rotate the flywheel then you likely have a bad "shear key" sometimes called a "shear pin" .. thats usually a half moon shaped small metal part that keeps the flywheel locked rotationally to the crankshaft .. it is designed to shear off if there is an excessive sudden load on the engine .. the flywheel will then spin without turning the crankshaft .. the same thing will happen if you have broken the connecting rod .. (a rod failure is often preceded by lots of clatter from the engine) .. the head gasket or shear key are much more likely to be your problem .. if you cant see in the spark plug hole you might try using a straw to feel the piston motion .. its possible that without the spark plug in place the piston might move even with a bad shear pin .. because with no compression the piston will move freely .. if thats the case you can stop the piston motion with a wood dowell thru the spark plug hole .. if it moves in spite of your dowell resistance then consider the head gasket option ..
Sep 19, 2009 | Garden
I can't remove the spool to replace the line. How
there is a button on the end of the shaft. it can be tight sometimes so a large pair of channel locks might help. turn the button counter-clockwise, and the pull the spool head off.
Aug 30, 2009 | Toro Garden
Garden Logo
271 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
