Do you know if the HP Deskjet 3745 printer will work with 2 black # 27 ink cartridges instead of one black and one color? Thanks Michelle
  • 4,338 Answers
All HP printers will work with both the color and the black cartridges. You can not have 2 black cartridges in the printer. This is true for all inkjet printers
Posted on May 26, 2011
How do I insert Ink Cartridge into HP Deskjet 1510. Do I need to have 2 cartridges inserted. Only use Black.no other details
Dear
You can follow the link. Yes you do have to install 2 carts. to work the printer. However from printer setting you may disable color print.
Note Ink cart head gets clogged when not used prolonged time.
Thanks. Replacing Cartridge HP Deskjet 1510 All in One Printer
Mar 05, 2015 | HP Deskjet 1510 Allinone Inkjet Printer...
The printer's black ink cartridge won't print without the Tri-color print cartridge
Most of the HP printers are designed to allow printing onlywhen all cartridges are installed and
have ink.
Install a new tri-color ink cartridge and printing will continue as usual.
My printer, which is HP, does the same thing as yours, until I replace the empty cartridge,
printing stops.
Feb 22, 2011 | HP DeskJet 3745 Printer
Can you use the HP 27 Ink Cartridge with the HP Deskjet F340?
No you cannot use Cartridge 27 with Hp Deskjet F340 printer. The printer only supports, 21 (black), 22 (color) and 58 (photo). I hope this clears your doubt.
If you need further help, let me know.
Good luck.
Thanks for using FixYa.
Sep 04, 2010 | HP Deskjet F340 All-In-One Printer
My deskjet 3745 wii not print with new ink. The cartridge shows full and the printer goes thru all the motions. The final print is no color and light black
Use the HP software (installed when you installed the printer) to run a "print-head-cleaning" cycle -- you've got lots of ink, but the print-heads are CLOGGED.
Aug 24, 2010 | HP DeskJet 3745 Printer
Hp printer 3745 is printing in green only.
Uninstall your printer software and install it again and try to print again. It should work.. because your printer setting seems to be messed up. If it still does not work then it is recommended that you change your ink cartridge
Have a nice day!
Jan 19, 2010 | HP Deskjet 3745 Inkjet Color Printer
I cant print with my hp deskjet 3745 when i put my black ink. so i only print with my color ink. i didnt change any setting and it happens with no reason. what should i do???
Seems that your black ink cartridge is damaged, try it in another printer of the same type to see if it works, or replace it with a new one.
Jul 14, 2009 | HP Deskjet 3845 InkJet Printer
Check print cartridge error
Set the properties to print on HP paper. This usually solves the problems
Mar 09, 2009 | HP DeskJet 3745 Printer
Installing hp deskjet 3745 without a cd
Here's what you need to do sir:
1. go to support.hp.com
2. then select the language you prefer
3. choose Software and Driver Downloads, then type Deskjet 3745 into the text box and proceed to next page
4. then select HP Deskjet 3745 Color Inkjet Printer
5. select your operating system
6. then choose the type of driver that you want to install
Hope this one works!
Please give me a rating, thanks!
Jul 26, 2008 | HP DeskJet 3745 Printer
Hp 3745 prints only the red color
This is Romeet, id like to try and help. Assuming you have windows XP installed,
go to "Start", select " Printers and Faxes"
go to your printer ( HP deskjet 3745 ) and right click it and select properties.
Click on " Print Test Page ", tell me what color does the Printout come in.
B.Regds
Romeet
Oct 31, 2007 | HP DeskJet 1280 InkJet Printer
jasbo
jasbo
