Question about Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
Gas in crankcase, how? - Briggs & Stratton Briggs Stratton Lawnmower Lawn Mower Short Block
  • glodanpow May 27, 2011
    Thanks, you confirmed my thoughts. I don't like it because the Carb is very hard to get to. It's on a rear mounted engine. I need to take the whole back end of the mower off to get to it. Mower is 12+ years old. I think its time for a trip to Sears.
    THANKS
  • 3,018 Answers
  • You need to get a needle valve and seat kit for your engine.
  • Make sure to change the oil right away.
  • Make sure to remember how or write down the governor linkage/ throttle body set up is.
  1. Remove the fuel line.
  2. Now remove the carburetor.
  3. Remove the fuel bowl by removing the fuel bowl nut.
  4. Flip the carburetor over and remove the float and needle valve by pulling the float pin out.
  5. Now you're going to remove the needle valve from the float.
  6. Remove the needle seat by pulling it out with a piece of coat hanger wire or blow the seat out with compressed air from an air compressor. Wear protective eyeware when doing this.
  7. Get the new seat. There will be grooves on one side of the seat. When installing the new seat, spray some WD-40 on it and install the seat so the grooves face down in the carburetor,. - The smooth part of the seat will be facing you. - Press in the seat with a flat punch until the seat bottoms out.
  8. Replace the needle valve with the new one in the kit.
  9. Since the size of your engine is not listed then should your Briggs & Stratton be an 8-22 HP engines, the seat is brass and pressed into the carburetor. It can only be removed with a Tap and a bolt. It's highly recommended that you take the carburetor in to a local shop and have them pull the seat out for you and reinstall the new needle valve and seat kit. Brass is a soft metal and very easily damaged. They know what they're doing.
  10. Assemble the float and needle valve to the carburetor and check the float level. Make sure the float is parallel to the carburetor body. If you have a pressure tester, connected it to the fuel fitting. This will tell you if the seat will hold gas or not. If the seat can hold 5 P.S.I., then it is ok. Install the fuel bowl and nut.
Regards, Tony
Posted on May 26, 2011
  • Iron
    Iron May 27, 2011
    • Your welcome. Yea, I hear the trip to Sear part. Good luck to you.
    Regards,
    Tony
Gas going into crankcase
Hi, Hb there are three ways in which gas can get into your oil tank/system:
1. Someone deliberately pours gas into your oil tank.
2. The vacuum petcock control rubber fails, which allows gas to flow from the fuel tank through the petcock, through the vacuum line into the intake manifold, then into the combustion chamber, where it seeps past the piston rings and into the bottom end where it gets pumped back into the oil tank.
3. Nonvacuum petcocks that are not turned to the off position will patiently wait until the float needle and seat no longer function properly thus inviting gas to enter the combustion chamber eventually finding it's way to the oil tank.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.kawasakimotorcycle.org/forum/kawasaki-streetbikes-sportbikes/130968-gas-crankcase-oil.html
Gas leaking into crankcase
Gas fuel in crankcase
Nov 12, 2016 | Motorcycles
What causes gas in crankcase
Gas in your crankcase is typically a sign of carburetor floats not set correctly. They allow too much fuel into the bowl which then overflows and goes into the cylinder and leak down past the piston rings and into your crankcase.
Jul 27, 2016 | Motorcycles
Why is there gas in crankcase
Hello Ricky, I would check the carburetor needle valve and seat along with the carburetor float. You could get lucky and just need to clean the crud out of the carburetor float bowl.
Nov 04, 2015 | Honda Es 6500 Gas Generator Electric Start...
Gas in crankcase
This sounds like it is an older vehicle with a cam driven fuel pump mounted to the block. If so the fuel pump is bad and leaking fuel into the crankcase.
Feb 17, 2014 | Vehicle Parts & Accessories
Blows white smoke
Check the Oil level. If gas got past the needle valve ( which happens more and more with this Ethanol gas ruining Rubber carburetor parts) Then gas will run down the cylinder walls and into the crankcase. Gas will mix with the oil and overfill the crankcase that will cause the mower to smoke like crazy.
Aug 09, 2013 | Garden
Have 307 86 gas in oil some pinging not really knocking or ticking. possibly diaphragm on gas pump allowing this through crank case or what should i do
there are only so many ways for gas to get into the oil.one someone purposely pured gas into the crankcase.two the engine is running very rich and not able to burn the excess gas,three the fuel pump is leaking gas into the crankcase,four the oil has not been changed regularly and the gas has thinned out to the point that it cannot seal the engine from the gas that normally is burned in the combustion chamber.If maintenance is regularly performed that fixes #4,I doubt that anyone would pour gas into the crankcase especially at the price of gas that fixes #1,if the carburetor is working as it was designed to then that eliminates running rich and fixes #2.if the above is good then the only thing left the fuel pump, can leak fuel into the crankcase and they won`t make noise necessarily.as far as the slight pinging one of two things can cause this, the engine is running slightly lean and or the timing is too advanced and needs to be reset to specs
Mar 02, 2011 | 1986 Oldsmobile Cutlass Supreme
I have briggs and stratton powered mower with the 18.5 v-twin ohv intek engine modle 407777 type 0121-E5 CODE 000512ZYG MY PROBLEM IS THAT MY CRANKCASE IS FULL OFA GAS OIL MIXTURE THE OIL FILTER ALSO...
When the float in the carb sticks, it allows fuel to drain into the cylinder, that runs pass the rings into the crankcase. When the crankcase is full the pistons cannot go down, and the starter won't turn the engine. Drain all the oil gas mixture, and refill with proper oil. Replace float, needle and seat in the carb bowl. Throughly clean fuel passages, and bowl. If motor won't turn, remove spark plug and turn over engine a few times to remove gas oil mixture from the cylinder too.
Oct 02, 2010 | Craftsman 42" Briggs Stratton 20 hp Gas...
How come the gas mixes with the oil then when u drive it it shuts off
it seems to be a fuel related problem. the gas should not be going into the crankcase. It is leaking into the crankcase . The fuel system is somehow leaking into the crankcase because of excessive flooding, or other fuel related problem like a gasket . don't drive the car like that.
Feb 02, 2009 | 1993 Nissan Altima
Briggs & Stratton Briggs  Stratton Lawnmower Lawn Mower Short Block Logo
118 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
