Question about Sony RCD-W500C 5-Disc CD Recorder
I am attempting to hook up the dvd player to the tv and it doesn't work
    Brigadier General:
  • 8,546 Answers
Have you read the manuals for both? It's probably explained except I'll bet the unnamed TV manual didn't anticipate someone wanting to use the TV as a speaker system for an audio-only device. The TV has at least an analog audio input. Treat the CDR as a DVD for the hook-up. There's probably an illustration.
Posted on May 26, 2011
No sound coming from sound bar
what do you mean hooked up and then no sound, hooked up with dvd player in the tv and then no sound?. ok check the cable if no loose connection, replace if possible.if still doesn't work tried to hooked up in other component input in your tv unit just to ensure if the problem is with in the signal input board.
Sep 15, 2012 | Insignia Televison & Video
Had power outage and now VCR/DVD does not turn back on. lights all work but it doesn't seem to pick up the channel?
Dis-connect the plug from the wall receptical and other leads attached to to the unit. Next press and hold power for too minutes in an attempt to reset the microprocessor, now hook everything back up and power on, if this fails it probably would be cheaper to replace the combo than have it repaired.
Jun 03, 2012 | Symphonic WV806 DVD Player/VCR
What plugs do I plug an xbox360 into on a magnavox dvd player
Jesus, not even the red white and yellow hookups? Oh, man, sorry, but I would need the model of the DVD player...and how did you hook up the DVD player if it doesn't have the red white and yellow hookups? just curious. Also I would highly recommend getting a new TV outright. If your tv is that old, it doesn't have HD, and that essentially defeats the whole purpose of having a powerhouse like the xbox 360. If you want the dvd player hooked up, give me the model number, but if you want a new tv, give me a budget and I am positive I can direct you to something reasonable.
P.S. (being tech savvy isn't a requirement for the newer tvs. in my honest opinion, You have to be a WIZARD in order to get all the inputs to convert to the correct format so it can be displayed on the older tv, so hanging onto the old tv is actually more trouble than a new one. Just saying.)
Feb 11, 2012 | Microsoft Video Game Consoles & Games
I have a rca truflat i can't get the dvd to play
are you sure you have plugs and source input the same.the tv has several diff.inputs look on back what inputs you are using then go in menu move input to the same
Dec 24, 2011 | RCA TruFlat 27F520T 27" TV
Haven't used dvd player fora while the player seems to work alright when not hooked to tv but when we hook up to tv it won't work thinking maybe connection iswrong. can't find my manual
There are usually two Scart multi pin sockets on the back of TVs (at least)
They'll be marked AV IN/OUT or AV IN or something similar.
It will probably work best in AV IN
Sep 26, 2011 | Cyberhome CH-DVD 300 DVD Player
My RCA XL100 is hooked up to cable and works perfectly fine. We've had it for ages and the picture is clear, sound is beautiful, and it gets along fine with my universal remote. There's just one...
Some of their very old sets the video input was located on channels in the 90's; Try scrolling down from 99 to 90 to see if you locate the video input; this is just the way they did things in the older sets.
Before you rate this solution let me know what you find first.
SD TECH
Jul 08, 2011 | RCA Televison & Video
We are trying to hook up our wii console how do you get it to work. TV says invaild scan freq.
You have to hook it up to a standard Yellow/Red/White RCA jack. If it doesn't work on one, try another. Make sure you're on the proper input you hooked it up to on the T.V. If this doesn't work, try hooking it up to a different T.V. to rule out the Wii as the problem. Try hooking up a DVD player to the same RCA jack as the Wii was on the Hitachi. After all of these troubleshooting methods, you should be able to get your Wii properly hooked up.
Jun 24, 2011 | Hitachi UltraVision UT47V702 47 in. LCD TV
How can i hook up an external dvd player to this tv? i followed the dvd player instructions but i cant get it to play...i can only hear the sound
On the front you have a yellow white and red port. Use the RCA cables from your DVD player to the front of this T.V. Change the T.V. input probably with the remote or just the channel buttons. If this doesn't work, use different RCA cables because the one's you're using may be bad.
Jun 17, 2011 | Sylvania 6520FDE 20 in. TV/DVD Combo
We have a SAnyo HDTV LCD Model DP19649 and can't
I have a sanyo dp-19649 tv and it's hooked up to a panasonic sound bar model# sc-htb10,and it's hooked up to a sony blueray dvd player. the sony player works on the sound bar but the tv doesn't.
Nov 12, 2009 | Sanyo Televison & Video
Can't hook up DVD player
I have a cable box and a Samsung DVD-V5500 player. How do I hook up the 3-part cable to the back of the player?
Jan 12, 2008 | Protron PD-007 DVD Player
Sony RCD-W500C 5-Disc CD Recorder Logo
53 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
