Can instal a lynx op system but not any versions of windows eh??? tried xp vista and 7 boot and repair discs, keep getting bootmgr missing or insert system disc messages but lynx op system booted up and installs and runs fine ,, how and why
  • 812 Answers
I suspect your pc is not seeing the hard drive. I take it you are using a Sata drive but not installing the sata driver for the motherboard. Try installing on an IDE drive. If this works the above is correct.Good luck.
Posted on May 26, 2011
  • every1likesm
    every1likesm May 26, 2011
    thanks but nope dose not mater what kind of drive it is iv even got a convert here for a 120 gig lap hd still no joy ..
    but lynx op sys will boot anything ...how ....why??
Bootmanager missing
The latest versions of Windows, including Vista and 7, use the Windows Boot Manager to read the boot configuration files and data in order to load your Windows Desktop.
If any of these files are corrupted or damaged, you will see a "BOOTMGR is missing" error. Fortunately, you can use a number of Windows tools to repair or replace the BOOTMGR or any related file that may be the cause of the problem.
Insert your Windows installation CD disk in your computer's CD drive and restart the computer.
Press "F8" repeatedly while the computer boots up.
This command enters the "Advance boot options" screen.
Select the "Repair my computer" option and then press "Enter."
The System Recovery Options screen opens.
Select the "Startup Repair" option at the top of the list and click "Next."
The utility will scan your system for the cause of the BOOTMGR problem and repair it.
Hope this helps
Oct 30, 2012 | Microsoft Windows Vista Home Premium with...
Bootmgr is missing
Bootmgr is the replacement for NTLDR in Vista and Win 7. NTLDR (NT loader) is the OS component which literally started the operating system in XP/2000. In the past I have had to use recovery console to go in and repair the OS (this is only available on the Windows disc). I would say in this case you will have to do the same, repair the operating system using the Windows disc.
This article is a how-to on fixing this issue, if you up for it:
http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
Jan 14, 2012 | Gateway Computers & Internet
Boot MGR IS MISSING
What actual operating system do you have?
Windows XP does not use the Boot Manager as this was introduced with Windows Vista or Windows 7 and higher versions.
If you are missing the Boot Mgr for Windows Vista or 7, then you will need to do a Startup Repair which you can do using either a Recovery CD if you have one, or else using the Vista or 7 installation disc.
See the following links:
Windows 7 recovery options
Windows Vista startup repair
Jan 11, 2012 | Microsoft Windows XP Home Edition
My laptop says bootmgr is missing and i dont know how to fix
First make sure that all usb devices are unplugged and remove all cd's or dvd's or sd cards etc.
If you are running Windows 7 or Vista you can try do a repair by hitting F8 while it boots and then select repair. If this does not work you will need a install disc. If you have Windows XP you will need an install CD to do a repair. I have attached a few links that may help explain in detail. Thanks for using fixya.
bootmgr-is-missing-error-while-trying-to-boot-windows-vista/">http://www.howtogeek.com/howto/windows-vista/fixing-bootmgr-is-missing-error-while-trying-to-boot-windows-vista/
http://pcsupport.about.com/od/findbyerrormessage/a/bootmgr-is-missing.htm
May 15, 2011 | Acer Aspire 3050-1733 Notebook
Missing bootmger
Fixing the "BOOTMGR is missing" error isn't too hard; here's how.
The day before yesterday I was testing out a program with several system utilities built in. One of its components left my computer in a bit of a mess - no icons anywhere and other assorted woes. I had set a system restore point before I ran the program, so I thought I'd do a system restore. System restore gave me a message that it couldn't restore my files. I decided to restore a disc image I had made a short while back. When I booted up the computer I got a message:
BOOTMGR is missing
Press Ctrl+Alt+Del to restart
I stared at it the white letters on the black background for a few minutes, while the cursor blinked back at me. After some searching (on another computer) I had some solutions.
Barring any hardware errors, here's how to fix that error:
  • Insert your Windows Vista or Windows 7 disk into your DVD player and restart your computer.
  • The next screen you see should have the Language, Time and Currency and Keyboard boxes.
  • In the lower left side there are two options: "What to know before installing Windows" and "Repair your computer."
  • Click on "Repair your computer"
  • Windows will then try to find the installation directory for Vista or Windows 7, depending on what you have.
  • Next up is a screen with a box called Recovery Options. Click the first option, Startup Repair.
  • You'll see a Startup Repair box with the message "Startup Repair is checking your system for problems..."
  • When it's done, it will prompt you to reboot. If there is more than one problem it may reboot again to continue repairing.
  • At this point, you can remove the DVD, reboot and everything should be working.
Two sites I found helpful are BOOTMGR is Missing at about.com and cyberstorms How to fix "BOOTMGR is missing" in Windows Vista
If the method outlined above doesn't work, try Solution #2 at the cyberstorm link.
Oh, restoring the disc image went fine and all is well. All my data was backed up (somewhere other than the hard drive Windows is on) so that was one thing I didn't need to worry about. Windows Vista and Windows 7 are the only Windows operating systems where this message appears; XP users don't have to worry about this one.
Mar 29, 2011 | Computers & Internet
Bootmgr is missing
BOOTMGR is missing
Feb 18, 2011 | Acer Computers & Internet
BOOTMGR IS MISSING
I'm assumig this is windows vista?
If it is, then insert the installation CD, (check that the bios is set to boot from cd 1st), follow the steps until it asks if you want to instal vista, or repair vista. Click on startup reapair
Here is a link for doing this in Windows 7:
Jan 21, 2011 | Toshiba Satellite L300-1BW Notebook
When i turn on computer says bootmgr is missing
Hello I believe you have some system configuration problems or perhaps a damaged boot sector. A sure fix would be to boot to the installation disc and perform a repair installation. If no luck, boot to a DOS disc and type in fixmbr. Then attempt the repair installation of windows. Hope this helps.
Nov 28, 2010 | Acer Aspire One AOD250-1924 Netbook
BOOTMGR is missing? dell inspiron e1705
maby you can use xp disk to startup computer and select the R from the menu thad displays than you are in the repair funktion
type help and you see a list .
type fixboot and enter
than type exit and now you are in the dos mode
restart and i hope xp wil also repair your bootmanager and computer starts normaly
download the windows relase version and burn it to disk .it are avalebel on microsoft webpage
good luck
Sep 01, 2009 | Dell Inspiron E1705 Notebook
Computers & Internet Logo
56 people viewed this question
David Payne
David Payne
