Question about DeLonghi EAM3500 Espresso Machine/Coffee Maker
EAM3500S will not froth milk ?
Hi
The machine will not froth milk, and will not produce hot water. Regular espresso making is fine. Have tried multiple descaling and cleaning of both the machine and the milk jug with no improvement.
I understand that the solution was to have the rubber rings on the hot water outlet replaced - but all is rings are complete (green, black and red).
What can I try ?
Please write to erhvervsjurist@hotmail.com
Best regards Martin
  • 3 more comments
  • redrock29 Sep 07, 2008
    hi, I've got a new Delonghi EAM 4500 (same as EAM 3500) and noticed, that the machine does not do a lot of frothing (comparing to my friend's machine). Can you help me? is anything I could do to maximise the frothing ability of this machine?
  • jim2molloy Jan 21, 2009
    I have a very similar problem - lots of steam comes through to cup - but with no milk! All items cleaned through and all rubber O rings in place; the machine is 2yrs old. DeLonghi service have been phoned (0845 600 6845) and they suggested a new jug top before worth calling engineer out. Have ordered one, unfortunately not in stock for >3weeks, so now sat waiting....... Service telephone staff have reference to an engineer for advice, to be relayed back to customer (why can't I talk to the engineer directly I wonder?), anyway apparently he suggested a new jug top should definitely improve performance, but if the problem still persisted it was probably due to congealed milk within the machine which would require a service visit.
  • tsheldrake Apr 07, 2009
    I have a very similar problem with my EAM3500S. Tons of steam comes out of the frothing jug, but no milk is ever dispensed. I have called delonghi and they advised replacing the rubber rings, which we did. They don't think a milk container lid will fix the problem and have advised sending the unit into service which means shipping it out of state. Has anyone actually discovered what is causing this problem? did you new milk lid fix it?
  • nolatte3500 Apr 23, 2009
    delonghi EAM 3500 will not make hot water or froth milk. makes coffee just fine.
  • corina_clint
    corina_clint Aug 20, 2012
    how many o rings should the eam 3500 have on the milk plug on the machine side before i push the jug in.at the moment its a green o ring on the short one and 2 on the lower, a black one and a red one
Here's what I did... with great success:
If you've cleaned all the milk deposits from around the o rings and you still have a problem then its almost certainly the milk spout (the little pipe that directs foamy milk into your cup)
Detatch the spout and get a 2.5 mm drill bit and use it to clean all the milk deposits out of the part that plugs into the lid. Rinse through with water to clean away all the bits of hard milk.
[If you put water through the spout before and after, you will notice a dramatic difference]
Doing this completely fixed the problem for me (I had about 3 years of milk build up in mine!).
Posted on May 02, 2011
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 30 Answers
If, when you press hot water, the machine says "Heating Up" or "Please Wait" for a moment then returns to "Ready" every time then the horseshoe (steam boiler) is cold. Open the machine and check. Test the thermal fuses (TCOs) on the horseshoe, one will probably be open circuit.
If a TCO (Thermal CutOut, the white ceramic blocks on the horseshoe) is blown, the horseshoe (steam boiler) control triac (usually BTA24-600BW) on the main board is probably breaking down under voltage stress. You will need to replace the main board (or just the triac if you are confident, can upgrade to a BTA24-800) as well as any TCOs that blew. The normal symptom for this is the machine remains in the "Heating Up" state indefinitely, often after having reported "General Alarm" during the event.
Posted on Jan 28, 2012
  • Dan Meacham
    Dan Meacham Jan 15, 2014
    The "General Alarm" followed by persistent "Heating Up..." Message described my ESAM5500 Perfecta problem. Would just replacing the Generator (Hourseshoe steam gen with orange cyclinder thing) fix the problem?
  • Dan Meacham
    Dan Meacham Feb 06, 2014
    Fixed my problem by replacing the other heating element. The fuses were fine, but the element was open circuit. Swapped it out and all works fine (for now)!
I had this problem once... It turns out the electrical connection for the solenoid valve that feeds the hot water out into the milk jug/hot water tap had come loose. They are clipped on rather than being soldered into place. Trace the wires back to the main board from the solenoid (brass bit with grommets) and check that the clips are in place.
Posted on Feb 17, 2009
Testimonial: "Thanks ;) "
My caffitaly S 23 does not dispense hot Millikan after the coffee has dispensed. Just hot steam and a little bubbly hot water. I have cleaned it it and will dispense milk and the next cup doesn't.
First; I am NOT a Caffitaly repairman. Though I have worked on mini espresso machines. Sputtering and/or poor steam is an indication that your brewer is not up to brewing temperature.
** Most of these home machines have a very small boiler or tank. They are designed to produce hot water and sometimes steam to brew a small 'European' espresso. Here in the USA we like our coffee weaker and with lots of 'other' things mixed in. The 'Americano' is the same amount of coffee but with a lot of hot water added. This amount will tax the small boiler to it's limits. Top it off with a grande latte would be probably be beyond it's ability to completely froth/heat this amount of milk. When you order a Latte from a Barista you will note that it takes a while to froth a Pitcher of cold milk. They are using a large espresso machine and probably pulling a double shot of espresso. To make a similar drink with any home machine requires doing everything 'double' or twice brew. (3 times?) You will need to check the 'ready' light to make sure the brewer is up to heat prior to brewing your next cup.
** Suggest brewing a regular size or 1/2 a mug of coffee-latte then come back again later for another fresh hot cup.
Aloha! ukeboy57
Dec 21, 2017 | Coffee Makers & Espresso Machines
Delonghi perfecta milk not hot enough
Ummn - something in your Q. seems not right. The milk is not heated directly - its only heated by the steam as it passes by (and picks up) by the milk using a venturi effect - same as a spray bottle attached to a garden hose. You say you have froth - but you can only get that if you have steam... (it does not just blow air thru to create bubbles). So froth = steam & steam = heat... so milk must be hot.
Suggest you check manual for the 'heat' settings for your expresso as this may have been changed. While this is adjustable, the milk is not.
Also always heat your cups before using them - the silver cup 'holder' at the top does a reasonable job but boiling water does far better.
Cheers Mike
May 31, 2014 | DeLonghi ESAM6600 Espresso Machine
My Gaggia classic has suddenly stopped frothing
Hi There,
You are not getting enough steam, to produce the froth and there no blockage. I suggest you replace the thermostats. Takes 10 min max.. Gaggia thermostat set
Sep 28, 2017 | Gaggia Classic Espresso Machine
Delonghi Perfecta won't froth milk or allow hot water to come out from waterspout
Aug 20, 2012 | DeLonghi Perfecta ESAM5500 Fully Automatic...
Delonghi Lattissima EN 660CW milk frother not frothing
I don't know why my answer posted in the comments section, so here it is in the proper area.
I had the same problem and was ready to send it in for repairs, but I talked to a great guy at Nespresso who helped me fix it myself. The problem was when I pushed the latte button, it would only froth milk for a second or two and then the espresso would start pouring. It basically refused to make a latte. Here's the things he had me do:
1) Descale immediately. I have an older machine, and descaling once a year does NOT cut it. He told me descaling every 5 months at the bare minimum, if your machine is not having any problems at all. Descaling is usually the main problem for lack of froth. I descaled and it seemed like the machine was working better almost immediately. I also ran 4 - 5 tanks of water through the hot water spout and the main espresso part (but mostly this is because it seems to take this much flushing to get the smell of the descaling solution out).
2) Reset your machine to factory settings. I have a classic Lattissima, so this is how you do it on that machine. Turn the machine on and wait until the drink buttons are steady (espresso and hot water buttons are no longer blinking to warm up). Then press and HOLD the power button until the espresso and hot water buttons BLINK THREE TIMES. Then they'll go back to steady again. You're now back to factory settings.
I did notice that I started having the trouble after moving the machine, so I'm not sure which of the above solved the problem. The main thing is it worked and I'm back to yummy lattes!
Jan 09, 2012 | DeLonghi Nespresso EN660 Espresso Machine
Why won't my starbucks serina froth milk. Just stopped doing this all of a sudden. I descaled, the little hole in wand isn't blocked. The milk heats but no froth.
This problem developed on my Sirena machine about a week ago. Stopped frothing milk, but still produced lots of steam. In fact, it was splattering milk everywhere, just not producing foam. Cleaned the steam wand (including air intake) and descaled the machine (even though its only 3 months old) to no avail. Called Saeco customer support (1-800-933-7876) and the very helpful rep immediately identified the problem. Inside the Panarello steam wand is a removable plastic tube. The tip of this tube should protrude about 1/8" beyond the end of the steam wand. Mine was not. Using the eraser end of a pencil, I pushed the inner tube downward into position and, voila, I now have froth again.
Nov 23, 2009 | Saeco Starbucks Sirena Espresso Machine
Delonghi Magnifica Coffee Maker the milk is not frothing properly - there's lots of steam & very little milk being issued from the spout We clean the milk jug each day, have adjusted the plastic tube...
You did not state anything about descaling, but every now and then, I also add water and descaler to the milk container and use the "Frothing" program to run through the water and descaling-solution (double-click the Cappuchino button).
I have also noticed that the first cup (and sometimes even the second) will produce less milk, and not as well frothed milk as later cups. My theory is that the machine is warmer when producing later cups.
If possible, you could try to run two-three frothings of plain water through before switching to milk. I realize this is inconvenient, but it could be worth testing this to see if it helps. We luckily have two milk containers and keep one filled with water just for the purpose of heating up (or whatever we do :) the frothing system before serving the first cappuchino.
Sep 04, 2009 | DeLonghi Coffee Makers & Espresso Machines
Seaco Incanto not frothing milk properly
Hi
When was the last time you descaled the machine, and not with vinegar? Scale can accumulate inside the boilers and insulate the water from the heating elements, produce less steam. Descale on a regular basis.
May 12, 2009 | Saeco Magic De Luxe Espresso Machine
DeLonghi EAM3500 Espresso Machine/Coffee Maker Logo
1,530 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
