Seloc Service Manual - Mercury Outboards - 1-2 Cyl - 1965-89 Logo
Posted on May 26, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a 1984 Mercury 9.8 outboard and it runs fine on idle but when you go to full throttle it goes for a couple of minutes then starts to lose power dramatically until in konks out. It will restart but then won't idle. Any suggestions would be appreciated. Also is there any place you know of to get the service manual online for free
Anonymous
Level 2:
Novelist:
  • Expert 184 Answers
  • Posted on May 26, 2011
Anonymous
Expert
Level 2:
Novelist:
Answers
184
Questions
Helped
56664
Points
268
Sounds like a simple fuel starvation. Simplest first- did you open the tank vent? Are you able to pump pressure with the primer when it starts to fail and make a difference?l. This would indicate a fuel pump problem or clogged filter. Then take a flashlight and look into the gas tank for water or **** floating round which might plug up the intake.
Harder stuff might be stuff floating round the carb bowl that gets sucked into a jet. I have seen a coil act this way when hot an shaken.
should always give it a compression test.
  • PG Nilsson
    PG Nilsson Jun 17, 2014
    Thnak you for the advice it could be fuel starvation. I changed the fule hose including the black rubber pump (for fuel) and added carburator cleaner to the fuel as it could be resin ing the carburator. the boat has been stored 8 months on the hard in a cold climate with gasoline in the tank. ump
What will make a johnsonew 50 hp out board motor bog when under load
Evinrude 50 HP Bogs at WOT - MarineEngine
www.marineengine.com > ... > Johnson Evinrude Outboard Archive
Aug 6, 2002 - 17 posts - ‎3 authors
83 50 HP Evinrude - sat out in weather for 4 yrs. Been cleaning ... At WOT, she bogsdown. Up to. ... Yes, this boat/motor is new to me. Actually ... Mercury 50 1987 bogs down when full @ full throttle
Sep 12, 2013
Motor Runs great bogs down under load.
Jun 23, 2011
1984 Johnson 70 idles but won't go
Jun 1, 2011
Johnson 70 hp no power under load Update
Oct 30, 2006
More results from www.marineengine.com
motor bogs down at full throttle Page: 1 - iboats Boating Forums ..
Please only marine mechanics reply I have posted a question about my 90 hp force outboard the warning sound starts sounding while running full throttle after about 15 minutes of running full throttle I can...
Is this motor used in salt water?
That warning buzzer on your motor is really only tied to the temperature. In order to triage sensor or overheat condition, I'd recommend an infrared thermometer to get a reading on the engine as the buzzer is sounding. There is a product that is like a glue stick which can be pressed against the engine which melts at a very specific temperature... not sure if it's around anymore as the remote thermometers are pretty inexpensive now. Is there good water flow out of the ports below the cowling on the back?
1helpful
Full throttle
check when its on full throttle that the carb butterfly is at 90deg and not over as this will reduce throttle but max advance on ignition !
Have 115 Hp mercury outboard motor missing at full throttle and on idle. At mid throttle it is running fine. Any Idea what the problem could be. Thanks, Milton
Have your spark plugs changed AND carbs cleaned and adjusted.
Usually that can also be caused by a seized advance system ( plate under the flywheel, commanded to turn with the throttle linkage... )
1helpful
1996 Mercury 150 Nitro EFI outboard- just bought the boat, running fine on the lake for about 35 min. Motor is 2 stroke- oil injected, oil tank is full. While running at partial throttle, an alarm...
Dont have the manual in front of me...recollect that there's two types of warnings. The pulsating warning is oil (starts with 30 minutes of oil left) or the fuel filter (or sperator, something like that) may have water in it. Running outboard with cover off, is a little black box that would have a red light lit if that's the case. If oil full & no red light, may be oil injection system...would also check to make sure lines aren't pinched, etc. Mine has been specific to oil the two times its gone off.
The full non-pulsating is engine overheat. Not sure beyond that.
Not much, but hopefully gets you going.
Jun 13, 2009 • Boating
3helpful
3answers
40hp 1987 yamaha outboard motor will run for 30-60
Sound like the fuel pump is not keeping up with the engine's demand. Check it out. Good luck. Hope this helps.
Apr 27, 2009 • Boating
1helpful
No acceleration
I'd be checking fuel flow. Usually if you have to choke or squeeze a primer bulb to keep it going, the motor isn't getting enough fuel. Check all fuel lines and connections are air tight, then if problem persists, investigate fuel pump.
A good carburettor cleanout and new carb overhaul kit wont hurt either.
Top Seloc Boating Experts
jws1013
ADMIN Andrew
ADMIN Andrew
Are you a Seloc Boating Expert? Answer questions, earn points and help others
