Question about BuffaloShop Buffalo Technology MiniStation Cobalt 320 GB USB 2.0 Portable with TurboPC HD-PET320U2/B ... Hard Drive
My external hard drive modal HD-PET won't start up the last time it worked the blue light kept flicking on and off if the unit was moved which makes me think it may be the cable? can I replace this? Any help is appreciated Andy
Lacie Case Only lighting up when HD is disconnected
I had the same problem with a 1TB hard drive. The fault was caused by the casing being knocked from the computer and falling onto the desk. If the hard drive hadn't been powered up it would have been ok...
I removed the hard drive from the casing and fitted it into my computer as a slave drive, hoping to access all the music and movies stored in it. No go .. But, it's worth you fitting your hard drive as a slave and trying the same. It's worth a shot.
I took the hard drive to a computer market here in China, where I work. These guys take hard drives apart to fix them, if possible. They couldn't fix my hard drive as it had been powered on when it fell ..
However, I bought a new desktop hard drive and they were able to transfer 95% of all things from the old hard drive to the new one. The cost of transferring from the old hard drive to the new hard drive was the same as the price of the new hard drive. That specialist service doesn't come cheap ... but it can be done. I paid simply because I didn't want to lose what had taken more than a year to download.
Try fitting your hard drive as a slave to see if you can access the information on it. If not, a new hard drive and the cost of transferring your music from your old hard drive may be the only course of action left open to you
Jun 05, 2013 | LaCie Big Disk External USB 2.0 1TB Hard...
Hitachi 1 TB external hard drive won't power up
yes you can fixed it replase cover and and cut hdd and buy new rak out side and conected the new rak with hdd that is very esy
Apr 23, 2013 | Hitachi Touro Desk 1 TB USB 20 External...
HD-PE250U2 had it for 3 years - very much loved and working last night. Computer will not recognise it this morning - but power and blue lights are on. Computer does not register the 'name' of
Either the hard drive went bad or the electronics of the enclosure went fubar. Suggest you remove HD and directly connect it to your desktop computer to see if the cmos recognizes it along with the OS. If so you can access your data. If not, the drive is ng - if the drive at least spins and is recognized you may be able to retrieve the contents using windows explorer. If unit will not spin you are in deep doo doo.
Do not format - that will erase everything - try to access the data.
Sep 03, 2017 | Buffalo Technology (HD-PE250U2/BK) 250 GB...
My 500GB Elements external hard drive is not being recognized by my computer
check usb cable first might try another cable to be certain it's not communications
and afterwards, you might consider running this utility to optimize your ext drive
Jun 16, 2012 | Computers & Internet
Problem with the Mobile Disk External Data Storage Enclosure model HD-338-COMP for my 80gb Western Digital HD
just a suggestion but a few years ago is aeons in tech time maybe, just maybe the drivers for that ext drive were overlapped with OS X migration?
check apple site for more or ext drive site for latest drivers
Jun 02, 2012 | Beyond Micro Mobile / 250GB / 7200 / 8MB /...
External hard drive won't show files
If it behaves like this for multiple computers with multiple operating systems, I would think that the problem is with the hard drive or with how the files were stored. I would recommend trying a free recovery utility:
http://www.piriform.com/recuva
If this does not work, there are professionals who can do this service for you however it is generally expensive.
As a last ditch effort, boot your computer from a free Ubuntu CD (http://www.ubuntu.com/download/ubuntu/download) and see if it recognizes your files.
Dec 13, 2011 | Buffalo Technology Buffalo DriveStation...
I accidentally plugged my laptop cord (19v) into my Simpletech pininfarina 500gb external hard drive (12v). It was only plugged in for about 20 sec and the HD power light was slowly blinking. I...
Your hard drive is probably dead. However there are stillhopes for hard drive datarecovery.
Put the hard drive in a plastic bag to be compatible for the freezer. Freezingsometimes works to revive a dying hard drive, at least for a shorttime(Probable just about 20 minutes), but be sure that the bag is sealedtightly so that condensation and ice crystals don't form. Put it in yourfreezer for 24 hours that will do the trick. While it's still cold, plug itinto your computer. And you may be able to view it in 'my computer'. And youmay act quickly, because you may only have 20 minutes to recover your data offit and after that the hard drive is completely dead.
If it fails, you will have to go to a recovery office where supply datarecovery service but let's hope not because it will cost you a lot of money andwhether they can recover data is not guaranteed.
Here is a tutorial to guide you how torecover hard drive data.
Aug 31, 2011 | SimpleTech SimpleDrive Pininfarina 500GB...
It make tic noise when the hard drive is running
This sound is the heads of the disk hitting. The drive should be backed up immediately to another.
You can put this drive into a drive enclosure to clone it to another.
This drive will stop working and there is no telling how soon that failure will occur.
Jun 06, 2010 | Western Digital Caviar SE WD1600AAJS 160...
Acomdata External Hard Drive blue light constantly blinking and not recognized by computer
how do I fix my external hard drive, because one day I turned it on and the drive was fine, the next day when I turned it on, it kept on flashing blue, does that mean that the drive is dead. Please help me with this.
Aug 04, 2008 | Acomdata (HD320UFAPE5-72) (HD320UFAPE572)...
Problem 2
The feint ticking noise usually indicates a dead hard drive.
The heads are flicking back and forth at random and make the ticking noise you hear.
The drive can still be detected because the physical hard drive and the controller board on it are in reality 2 seperate components working together. So the controller board is also trying to access the hard drive without luck.
If you have not dropped the unit or knocked it over etc, then chances are the controller board is what has died and therfore you still cannot access the drive. You may get lucky in finding a new controller board to replace a failed one and that will also get your data back.
May 14, 2008 | Acomdata 250GB External Firewire HD 250 GB...
BuffaloShop Buffalo Technology MiniStation Cobalt 320 GB USB 2.0 Portable with TurboPC HD-PET320U2/B ... Hard Drive Logo
218 people viewed this question
Top BuffaloShop Computers & Internet Experts
David Payne
David Payne
Are you a BuffaloShop Computer and Internet Expert? Answer questions, earn points and help others
