Question about Hotpoint Aquarius WF000 Front Load Washer
SOURCE: hotpoint ultima wt960 washing machine noisy on spin
My WT960 was also very noisey on the spin cycle, but it had been like this since new, but became increasingly loud, to the point it sounded like it was going to explode. Boyfriend took machine apart to find the concrete weight had also loosened, bolts tightened, though awkward to get to. Now the machine spins ALOT silently than before!
Posted on Aug 10, 2008
SOURCE: Hotpoint wma76 front load very noisy on spin cycle
If the machine is only noisy during the spin cycle then it is probably not the bearings, more likely it is probably the same issue I had. There is a large weight attached to the top of the drum, in my case it was loose. A simple fix, remove the lid and tighten the three bolts. The lid is removed using a T20 star key, you can buy these at places like Homebase or B&Q (about £7.50 for a set of 10 different sizes). There are two little plastic lugs on the side of the lid, the screws are behind these, remove them and then pull the lid forward and up. The weight is obvious, it looks like an odd shaped brick and is bolted down with three bolts. In my case the front one was loose.
Posted on Nov 14, 2008
SOURCE: Hotpoint WF620 - flashing error F05
This is a drain problem. Most likely something caught in the pump which is accessed by removing the small panel at the rear/bottom of the machine. The pump slots in place and can be removed by lifting and shifting to the left. Unscrew the pump off or remove the pipes will reveal all.
Posted on Dec 13, 2008
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Posted on May 27, 2009
SOURCE: I have a Hotpoint WF540 washing machine. When it
Sounds like drum bearings most cases you need to buy half drum with bearings fitted if your very good at diy no problem if not call engineer.1st check concrete weights are not loose top and bottom.............you can buy parts @ espares.co.uk this will give you idea of cost which maybe quite high.
Posted on Apr 21, 2010
Sep 28, 2014 | Hotpoint Repair Pcb / Module Wf240 Wf250...
Aug 31, 2014 | Washing Machines
Aug 31, 2014 | Hotpoint Washing Machines
Jan 07, 2014 | Hotpoint Aquarius WD63 Front Load...
Sep 08, 2010 | Hotpoint Washing Machines
Jan 23, 2010 | Hotpoint Aquarius WF000 Front Load Washer
Dec 13, 2008 | Hotpoint Aquarius WF210 Front Load Washer
Nov 13, 2008 | Hotpoint WMA54 Front Load Washer
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
42 people viewed this question
