Question about Kenmore Dryers
Dryer will not turn on.. plug is working, no burnt wires no problem with door, fuse in breake panel ok
    Brigadier General:
  • 3,301 Answers
Remove the back, you will see a thermal fuse along the inside back panel,, usually a little white piece of plastic with a wire on each end,, replace it
Posted on May 26, 2011
Will not start
It doesn't work at all If your dryer doesn't work at all, it could be because of problems with: Power from the house Door switch Thermal fuse Wiring Power from the house Check to see whether there's power getting to the dryer. Is it plugged in? If you plug something else into the outlet, does it work? If not, check for a blown fuse or tripped circuit breaker. Door switch If the door switch or the door-switch actuator is defective, the dryer won't work and you need to replace the failed component. The switch is inside the dryer main housing near the door frame. Sometimes you need to raise or open the top or front of the dryer to reach the switch. Thermal fuse On many dryers, there's a thermal fuse (a heat-sensitive fuse that blows if the dryer overheats) mounted to the exhaust duct inside the back cover panel. The fuse is about an inch long. It's usually embedded in black resin and mounted in a white plastic housing.
If the fuse has blown, it has no continuity. When this happens, your dryer either just stops heating, or it doesn't work at all. Be sure to inspect the venting/heating system before replacing the fuse to put the dryer back into operation. (You can't re-set this type of fuse.)
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached
Jan 01, 2010 | Kenmore 63942 Dryer
The 3405281 relay burnt out. I replaced and the dryer still will not run unless I hold the start switch
Wiring Often the main wiring connection from the house, at the dryer, burns and the connection breaks. In this has happened to your dryer, you need to replace the power cord and the terminal block inside the dryer to which the wire is attached.
Dec 31, 2009 | Kenmore Dryers
Will not start, replaced timer. Voltage getting out of timer Checked door switch-OK, Checked Thermal fuse-OK Model HYE2460AYN
Here are a few tips courtesy of www.repairclinic.com
For more information visit,
http://homemanagement.services.officelive.com/FieldServiceHelp.aspx
How to Use a Volt-Ohm Meter Safely
Courtesy of www.ehow.com
If you have access to a volt-ohm meter you can test these components.
Door switch
Thermal fuse
Wiring
Sep 22, 2009 | Maytag Dryers
96 Honda Civic 4 door sedan back passenger window doesn't work with master switch on drivers front door but it does work with the button on the back door. Also front passenger window doesn't work at all...
the wires at the door jamb connector get brittle and crack and break, causing all manner of oddities. and it can certainly be intermittent. like your window rolls down with the door open, but does nothing if the door is closed. wires may need to be repaired or replaced with that molex style plug/connector in the door
Aug 11, 2009 | 1996 Honda Civic
Checked the fuse it's ok but the dryer still won't start
Hi, What kind of problem are you having? Heating or running?
I can help.
Vic
May 25, 2009 | KitchenAid KEYS700LQ Electric Dryer
Dryer has no heat to it, but runs
Running is good. That means lots of stuff is working. On the motor is a switch that turns the heat on once the motor gets up to speed. The other wires on the motor are start and power for run. Check your heater elements for continuity. Running usually means the door switch is ok, timer ok. Check around for fuses, burnt wires, loose wires. Check the heat sensors for continuity. They should conduct electricity untit they get hot.
Apr 23, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Dryer doesnt start, 600 series kenmore
Q - My dryer is dead, what could do that ?
A - Common problems...blown house fuse/tripped breaker ( electric dryers need 2 )...loose white/neutral wire...broken belt ( on some models only )...door switch/door switch bracket...*thermal fuse open ( venting needs attention )...broken or burnt wire...timer...motor...burnt power cord/plug...start switch ( especially the ones with a built in relay switch )
* If you find a blown thermal fuse, always clean, change, adjust the venting system and vent hood first, then it is sometimes a good idea to replace the operating thermostat at the same time. This is a picture of -some- modern thermal fuses.
Door switch
Thermal fuse
Wiring
Apr 01, 2009 | Kenmore 63942 Dryer
Will not turn on
check out the following cause =
Door switch
Thermal fuse
Wiring
good luck..........
Mar 28, 2009 | Whirlpool Dryers
Maytag Dryer will not turn on
Door switch
Thermal fuse
Wiring
Dec 15, 2008 | Maytag MDE9700AYW Neptune 174 Electric...
Water light on
Oct 24, 2008 | Dryers
Dryers Logo
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
