Question about LG LHD45EL Dehumidifier
The humidifier is starting and running,but there is no water in the bucket
    New Friend:
Definitely clean any area where water drains. I wasn't sure what the intake duct was and the manual for my dehumidifier doesn't state where it is..but says to clean it. This might help you clear up where to clean...even if this is not your model...the applicaiton is really the same.
https://www.youtube.com/watch?v=Zb2rj-xWE9A
Posted on Sep 30, 2014
    Brigadier General:
  • 4,736 Answers
Ayke, this can be caused by several things: The air intake filer is dirty and needs to be removed and cleaned. The humidity level on the unit is set too high and should be lowered to 35%. The air circulation around the unit is obstructed. There should be a minimum of 12" free air space all around the unit. The air temperature in the room is to low for the unit to operate properly. Most dehumidifiers will not work well between 40 and 60 degrees F.
To do an in home test, move the unit to the bathroom, and start it with the humidity level set at 35%. Turn the shower ON hot enough to generate steam. Do Not turn the bathrooms exhaust fan On and close in windows in the bathroom. As you exit the bathroom, close the door. Wait 15 to 20 minutes, before returning to the bathroom. Then open the door and turn the shower OFF. Allow the dehumidifier to continue run for 5 minutes, the check the water collection bucket for any signs of water. If you see any water, the bucket is working as it should.
If you don't find any water in the bucket, the humidity sensor may have failed and/or the compressor needs to be recharged with refrigerant gas.
Hope this helps you to troubleshoot and solve the problem.
Posted on May 26, 2011
Water does not fill in the Aprilaire humidifier on my furnance
It sounds like the feed has been shut off or pluged. Be sure the feed is off, remove the feed from the humidifier. open the fill valve slowly and run water into a bucket or whatever. If it does not run you found the problem, if it does then it is probably the fill solenoid valve on the humidifier.
Mar 21, 2014 | Edison 40 Pint Dehumidifier
Our maytag and dayton humidifiers all starts but no water collects in the bucket.
There are many reasons why a dehumidifier willnot work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrongwith their dehumidifier
Dehumidifier is running but no water is in bucket
heatman101
Jul 02, 2011 | Maytag Dehumidifiers
My humidifier runs, but no water is collected. It will start and just keep running. Could something be clogged. The filter has been cleaned. It has sat not running through the winter.
heatman101
Apr 21, 2011 | Haier Dehumidifiers
The humidifier runs but there is never any water in the bucket. The basement is having a musky smell so I know the humidity is high. What can I do?
If this is a refrigerant based humidifier with a compressor in it, you may be low on refrigerant or have a refrigerant leak.
Apr 11, 2011 | Whirlpool AD50USS Dehumidifier
When my dehumidifier is on, it says there is 90 humidity. I come back an hour later, it is still running and no water in the bucket.
If there's no water in the reservoir, first make sure that water is getting to the humidifier. The humidifier must have a good stream of water available to it. If there's water in the water line but the reservoir doesn't fill, replace the float mechanism inside the humidifier.
Take care.
Jul 29, 2010 | Haier 45-Pint Dehumidifier
Water is no longer collecting in bucket, but appears to leak out of humidifier. Humidifier also ices up.
Basically there is a drainage blockage from the humidifier to the bucket. Take one for the boys and **** hard on the pipe which very possibly will release the blockage.
May 23, 2010 | Kenmore 54351 Dehumidifier
Our de-humidifier is running cool but there is no water in the bucket, should there be?
Is it warm outside,and do you have your A.C. on? Dehumidifiers ,just like A.C. systems, remove humidity. If the weather is cold, put an open gallon of water in front of your unit and let it run a day or so. If the bucket gets water in it, and the container of water goes down, then the unit is working.
Feb 22, 2010 | Whirlpool Gold AD70USS 70 Pint Per Day...
Start up instruction for dehumidifier
A dehumidifier does not need water in the tank.It takes humidity out of the air and the moisture goes into the bucket. A humidifier has to have water in the tank.Note ,a humidifier puts moisture in the air, and a dehumidifier takes the moisture takes moisture out of the air.
Feb 16, 2010 | Kenmore 54501 Dehumidifier
Dehumidifier not sure is working
There is water in the bucket or no water in the bucket? If there is water in the bucket then empty it and put it back. If there is no water in the bucket then make sure the bucket is all the way in, (there is a switch that senses the bucket). If the bucket is not all the way in the de-humidifier will not work. If you do not hear it, it is not working.
Jun 21, 2009 | Dehumidifiers
Bucket fills, doesn't stop
make sure unit is level , the cut off switch will not work if not level
Jun 07, 2009 | LG LD65EL Dehumidifier
LG LHD45EL Dehumidifier Logo
205 people viewed this question
Top LG Dehumidifiers Experts
Bill Long
Craig Butler
Craig Butler
Gil Shultz
Are you a LG Dehumidifier Expert? Answer questions, earn points and help others
