Question about Pentax Optio W60 Digital Camera
When I turn the power button on it only stays on for 5 seconds the battery is fully charged and an optio w60
4 Suggested Answers
  • 22 Answers
SOURCE: Pentax Optio S not functioning
I don't know if it would help but try to update the firmware for the camera.
Posted on Jun 06, 2008
SOURCE: switching off as if battery is depleted when the battery is newly charged
I called Pentax and they said it's a known problem and the lens needs to be re-synchronized. They said this is usually caused by dust in the lens.
I have to send the camera to : -
Pentax U.K. Limited
Pentax House
Heron Drive
Langley
Slough
SL3 8P
It's a free repair if you bought the camera less than a year ago o/w they will send you a quote for the repair.
Posted on Oct 01, 2008
  • 11967 Answers
SOURCE: My pentax optio T10 turns on then turns itself OFF
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Jan 03, 2010
When I put fully charged batteries in my camera and turn it on the screen works fine. However, when I install any picture card and turn the camera on it gets stuck at the Pentax Optio screen. I will stay...
I have to say that you are probably using the wrong SD card. Or the memory card is to big and the camera cant handle all that memory space. I recomend that you try a 512mb San Disk SD Card. Dont mistake this for any card. Dont use a San Disk SDHC card. Do this and make sure your batteries are charged and you should of solved your problem. Good-Luck.
Jun 13, 2011 | Pentax Optio E10 Digital Camera
MYFI XM2GO WILL NOT TURN ON. ALSO WHEN I PUT IN CRADLE WILL NOT SHOW CHARGING
I had the same problem. This procedure from the "Technical Questions" section of http://shopdelphi.com/consumers/support/faqs/myfi/ worked for me:
"My MyFi won't power up, how do I reset it?
To reset your MyFi, start by turning the receiver off and removing it from its (car, home, audio system) cradle. Then remove the back cover and battery. Using a small paperclip, press the reset button located on the top left corner of the battery compartment. Now plug the AC power adapter into a wall outlet and plug the power port directly into the bottom of the MyFi (battery stays removed). Wait 10 seconds and listen for a beep. After you hear the beep the message "insert battery" will appear. Cycle the MyFi to ensure it powers up and powers down. If the power cycle is normal, then turn off the MyFi, unplug the power adapter, and reinstall the battery. Re-plug the AC power adapter directly into the bottom of the MyFi. Wait 10 seconds and listen for a beep. After the beep you will see the message "battery charging". Leave the MyFi plugged in until it's fully charged. You will see the message "charging complete" displayed. After the MyFi is fully charged, turn it on and reset to the factory defaults. Unplug the MyFi from the AC power adapter and using the battery power leave it on until it fully discharges (approximately 2-5 hours). Plug the MyFi in using the AC power adapter to recharge the unit and resume normal use. If you need help at any point during this process contact us at 1-877-463-3574 for technical support."
I hope it works for you too.
Sep 27, 2010 | Delphi MyFi SA10113 XM Radio Receiver with...
When I try to take a picture with my Pentax W60, it will focus but not take the picture no matter how long I hold the button
I have the same issue, no message appears - every now and again after I push & hold the shutter button (sometimes 4-5 times, 5-10 seonds) it will finally take the picture. But, again - once it focuses it doesn't take the picture when the shutter ****on is fully engaged.
Apr 10, 2010 | Pentax Optio W60 Digital Camera
Camera wont turn on!! help!!
Dear Texaslilly,
Although there is nothing much to do but you can still try the following.
  1. Try with different set of batteries
  2. Remove the memory card from the camera
  3. Cameras generally do have an option to plug-in external power supply..Try with external power supply .. if there is any.
  4. Now this might sound little crazy but no harm in trying .... Remove batteries... Press and hold the power button for few seconds... release the power button ... reinsert the batteries and try to power on without memory card.
Try the above and let me know if it works.
Regards,
Srinivas.
Jun 19, 2009 | Pentax Optio T20 Digital Camera
Acer 4520 Power up for 1 second and turns off
Can you hear the system fan running? If the fan fails, the PC shuts down itself to protect the processor from FRYING.
Apr 14, 2009 | Acer Aspire 4520-5582 Notebook
My magellan maestro 3100 won't stay powered on
If the battery is fully charged then press the RESET button.
Jan 20, 2009 | Magellan MAESTRO 3100 98083401 GPS Device
Pentax Optio M20
Maybe.
But it does seem to be a lens problem. Possibly the lens is out of sync as mentioned in another post here.If there is a grinding, the lens is probably damaged by dirt or sand.
Make sure the batteries or battery is fully charged.
May 31, 2008 | Pentax Optio M20 Digital Camera
Pentax Optio M30 won't turn on!
MY CAMERA WONT TURN ON... I HAVE CHARGED THE BATTERY SO I KNOW IT IS CHARGED...ANYONE HAVE THIS PROBLEM.?
CHERI
Feb 25, 2008 | Pentax Optio M30 Digital Camera
My less than 2 year old sony dsc-w100 keeps powering off and on
my only idea would be that the power button is glitching out...anything in the manual about this?
Jan 22, 2008 | Sony Cyber-shot DSC-W100 Digital Camera
Power issue
First of all try the Pentax web site Technical support line. also when fire it up press the battery compartment door shut it may be tired contacts. But it looks like a repair job is needed- or it it is getting on a bit - replacing
May 30, 2007 | Pentax Optio A10 Digital Camera
Pentax Optio W60 Digital Camera Logo
Top Pentax Cameras Experts
mohamed salim shaikh
Jerry Greenberg
Jerry Greenberg
Are you a Pentax Camera Expert? Answer questions, earn points and help others
