Question about Smith Corona Office Equipment & Supplies
On my CLassic 12 machine, the half-space and power-space were working just fine but after moving, they are jammed up and back really far that they're stuck under the ZX and . / keys. Is this just a locked position or how can I unjam this?
  • 300 Answers
Sorry to say it is not a locked position. Somehow they got pushed down by accident, and either the levers got bent or the plastic keys got broken.
You may need to take it to a repair shop.
Is the spacebar working at all?
Posted on May 27, 2011
How do i clear paper jam after tearing half of the paper leaving other piece locked inside machine?
IF the jammed paper tears and you cannot remove the paper either from the paper output slot or from the transport unit, or the jammed paper remains inside the machine, remove the paper following the procedure below. 1. Turn off the machine, and unplug the power cord of the machine from the power supply. 2. Open the paper output cover. Remove the paper on the front tray if any.
Important:
    Do not touch the clear film (A). If the paper or your hands touch these parts and blot or scratch them, the machine can be damaged.
3. Make sure that the FINE cartridge holder does not hang over the paper. If the FINE cartridge holder hangs over the paper, move the FINE cartridge holder to the right edge or the left edge whichever is easier to remove the paper. When you move the FINE cartridge holder, hold the FINE cartridge holder and slide it slowly to the right edge or the left edge.
4. Hold the jammed paper with your hands.
If the edge of paper is jammed near the paper output slot, pull the edge of paper to the position where you can hold it with your hands.
5. Pull the paper slowly not to tear it, then pull the paper out.
6. Make sure that all the jammed paper is removed. If the paper is torn, a piece of paper may remain inside the machine. Check the following and remove the piece of paper if it remains.
7. Close the paper output cover, then reload the paper.
All print jobs in the queue are canceled. Reprint if necessary.
Jul 20, 2014 | Canon Pixma Mx432 Wireless Inkjet Office...
After typing first line, hit the return key. The carriage would not return to the far left margin...it only moved 12 or so spaces to the left.
The carrier slides on a silver shaft that is about 1/2" thick spray some WD40 on the shaft, if that doesn't do it you have to get some on the carrier motor bearings located under the case in the R. rear corner.
DickyO
Feb 22, 2014 | IBM Wheelwriter 3 Series Ii Typewriter...
Unable to wash a full load
Run a "Washing Machine Cleaner solution" through your machine to clean out built up grime and dirt inside the drum.
You must of course always only load up clothes so that there is good space left for them to move freely. Jammed up clothing will never wash clean.
Use a really good detergent, and my tip is NOT to use fabric softeners as they really gum up the works and cause grime and dirt buildup in places you cannot see! This mucky stuff then finds it way back into the next wash and the next and so on.
Poppa
http://www.cdbaby.com/cd/poppamadison
Nov 13, 2011 | LG WM2277H Front Load Washer
Our Canon jx210p fax keeps saying "chk printer
CHK PRINTER 5100 / SEE MANUAL
Cause Action Movement of the Holder is blocked. Clear the paper jam or foreign object that is preventing the Holder from moving, then turn off the machine and turn it back on again. There may be an obstruction that is not allowing the Holder mechanism to move. Check for any obstruction (paper clip, small object, etc.) and also that the protective tape are removed from the FINE Cartridge. Check also for a paper jam and clear the jam if necessary . Then press [Stop/Reset] and start again. The FINE Cartridge may be defective. Press [Stop/Reset]. Reinstall the FINE Cartridge (see Prepare the Machine ) and start again.In either case, if the error does not clear, try unplugging the fax. Wait several minutes, then plug it back in. Also, try replacing the FINE Cartridge with a new one. An error requiring servicing might have occurred. Turn off the machine, and unplug the power cord of the machine from the power supply. After a while, plug the power cord of the machine back in and turn on the machine. If the same error occurs, contact the service center.
Jul 26, 2011 | Canon FAX JX210P All-In-One Inkjet Printer
When I turn on my MP830 Cannon the error "release the scanner lock switch and turn the power off and back on" appears. I have done it . The scanner appears to attempt moving, but does not get very far
hello, what i have found out so far, sometimes a small bit of tape they use on the scanner and ribbon cable rubs on glass, then catches on the white calibration area, but not all the time, when a machine has been used really well, and taken care of, the scanner just fails, replace whole top unit, not the doc feed, just scanner unit only, if main pcb still good machine will work just fine
Sep 21, 2010 | Canon PIXMA MP830 All-In-One InkJet...
When I use the zoom button the lens moves three times, then I get a massage to turn the power button on and off!
Hello
This is a classic symptom of a broken or jammed lens assembly. The cost to repiar ranges from $100 to $175 to repiar so it might not be worth it.
I recommend you try the steps on the following blog as it works for about half of cases where this happens.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Kind Regards
Andrea
Dec 30, 2009 | Sony Cyber-shot DSC-W200 Digital Camera
Lid will not close. Jams half way down
is there any build up any where aound the hinge? Rub a bit of butter on hinge then move lid up & down. this is kind of like oiling something but your using butter or margerine. I do this on the hinges of my doors when they start to squeek.
Jun 10, 2009 | Cuisinart Brew Central 12-cup Coffee Maker
Baumatic washing machine instructions
the twelve programs are explained on the detergeant drawer.if not i will post them for you.
to use the dryer turn the middle knob clockwise to the amount of time you desire upto 140 minutes then select the temperature on the far left knob and then depress the half load button your dryer should now work.
Jan 11, 2007 | Baumatic BTWM4 Front Load Washer
80 people viewed this question
Top Smith Corona Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
Ron Dufek
Ron Dufek
Are you a Smith Corona Office Equipment and Supply Expert? Answer questions, earn points and help others
