Question about Ovens
I have a Neff double oven (Model U1421) - the fan in the main oven works but the oven is not getting hot
  • 24 Answers
It sounds like your oven element needs replacing you will need a service man to do this
Posted on May 29, 2011
Neff u1421 double oven , both ovens work fine but the grill trips the circuit breaker after 5 minutes of getting hot
you need to check size of breaker the oven is wired too if this is to small it will trip also cable size
Sep 18, 2013 | Neff U1421 Double circotherm Electric Oven
My Neff U1421 bottom oven has failed.
Probably the ring element. If the clock is flashing zeros or 8's the bottom oven will not operate but the top will. Make sure the clock is set (doesn't have to be the correct time, just not flashing) If the fan and light then work but no heat, defo the element part no 499003
Mar 21, 2013 | Neff U1421 Double circotherm Electric Oven
Our fan oven will not warm up. Fan working but oven will not get hot.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Jan 16, 2011 | Neff U1421 Double circotherm Electric Oven
Fan stops intermittently
If you are referring to the main oven fan, then that indicates it is failing.
It will only be a matter of time before it stops altogether.
Only solution is to replace the fan motor.
Please rate my solution.
Thankyou.
Jan 11, 2010 | Neff U1421 Double circotherm Electric Oven
Neff U1410 main oven trips the main RCD. Occurs
I have a u1421 with the same problem! I notice the fan doesnt run too well, sometimes it doesnt run at all, needs a prod to get it running. I suspect with no fan, that the element gets far too hot, and then starts to leak to earth, tripping the RCD. I'm gonna try buying a new fan motor - you should ckeck if your fan is running full speed OK.
Oct 25, 2009 | Neff U1421 Double circotherm Electric Oven
Neff u1421 bottom oven: Either fan works but no
You need to replace the oven fan element, as there is probably a seperate element in use when used on convection heat.
Thanks.
Oct 24, 2009 | Neff U1421 Double circotherm Electric Oven
Neff u1421 bottom oven fan is working t/stat
Can only be either element or thermostat. I suggest you check element and connections
Aug 26, 2009 | Neff U1421 Double circotherm Electric Oven
Neff U1421 main oven trips the circuit breaker.
It might be that the breaker is overloaded and it's no longer supporting the load of all the appliances together.If you do not want to change your breaker you can still use your oven by switching off other appliances that is running while you are using the oven
Feb 04, 2009 | Neff U1421 Double circotherm Electric Oven
Neff U1421 double oven fan has packed up ?
Yes it is the fan that needs replacing.
It is a fairly straight forward repair, just remember that the nut that holds the fan blade on is a left hand thread, so to undo it, turn
it clockwise, as though you were you were tightening it.
Please leave a fixya rating for my solution.
Thankyou.
Feb 03, 2009 | Neff U1421 Double circotherm Electric Oven
I need to take off a fan from a neff oven,how do i remove the fan?
Remove inner rear panel of oven.
Unscrew nut clockwise that secures the fan blade to the motor, undo screws that secure the motor. and replace same. You may have to remove main back panel to access fan motor screws and terminals.
please leave a fixya rating for my solution.
Thanks.
Jan 25, 2009 | Neff U1421 Double circotherm Electric Oven
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
