I AM TRYING TO REINSTALL WINDOWS BUT WHEN I BOOT FROM THE WINDOWS DISK I GET THE ERROR MESSAGES MEMORY OVERFLOW AND ERROR LOADING OPERATING SYSTEM
  • 44 Answers
Ummmm...remove the memory, put it back in. Format the hard drive(again.) Check that all your IDE cables are correctly connected to the hard drive and also check the jumper if the hard drive is primary Disk drive. Are the cables good, is your disk drive clean? Does any other disks work and boot that can boot in dos?
Posted on Aug 16, 2008
    Champion:
  • 214 Answers
HI, LET ME KNOW HOW MUCH RAM DO YOU HAVE?
When i turn it on it says i need to reboot
If message is given by windows then your windows need reinstall or repair and also check hard disk for errors. If this is message of BIOS then you need to check proper hardware connected properly. Generally this error is caused when operating system is able to load from boot partition.
Nov 09, 2013 | HP Mini 1000 Netbook
Error loading operating system
You need to reinstall the Operating System with the help of recovery disks.
Feb 11, 2013 | Acer Aspire 5334 15.6" Hard Drive Caddy...
Recovery disk for SX2855-UB10P
At what stage of the installation process do you get the message ?
Which operating system are you trying to load ?
Is there an operating system on your hard drive ?
You have to format your hard drive using a third party disc to erase everything on your hard drive
Restart your computer during the boot process you will see on the screen to press a certain key to enter setup usually the Delete or F2 key
Press and hold that key during the boot up process to enter BIOS then using the arrow keys scroll down to advanced bios features press enter change your first boot device to cd press escape then press f10 to save to cmos to restart
Note this will erase you operating system you will have to have an operating system disk to load it onto you hard drive or create a partition to load another operating system
Note after you have loaded the operating system you should go back and change the first boot device to failsafe or optimised defaults after windows has loaded
your computer will automatically restart it might restart 2 times one to finish the installation
the next will be because the operating system is loaded and will boot from your cd
Hope this helps.
Jan 24, 2013 | Gateway SX2855-UB10P Desktop - 2GB Memory...
When i start my pc, it starts well but a page appers telling me to start windows normally. when i click on that then windows starts loading bt after 2 sec the systems gets restarted.
1.You have to do a diagnostics test on your hard drive to check if the there are any bad sectors developed on the hard drive!
2. If your system restart, when you just click your mouse, your system files are probably corrupted and your may have to reinstall the system ie. provided your hard drive has no errors.
Here is an option you can try.
Can you boot your system to "safemode"? & Use the "Dos Prompt" to do a "Check Disk" on your System. ie Run -> "CHKDSK /f/r" (without quotes)
Hope it helps.
Apr 17, 2011 | Computers & Internet
Every time the system is turned on it says Non-system disk or disk error, replace and strick any key when ready. There are no disk in the disk drive or the sd drive. No matter how many keys you strike...
Your computer tries to "boot" from various devices:
* bootable files on a USB memory-stick or SD memory-card
* from 3.5-inch diskette drive (if installed)
* from CD/DVD disk
* from your disk-drive
Your computer tried to boot from your disk-drive, but FAILED to do so.
Since the disk-drive is "dead", it tries to boot from any of the other devices,
and displays that error-message when it cannot boot.
So, your disk-drive has "died". Ouch!
You need to purchase a new disk-drive, and reinstall Windows onto it.
Dec 23, 2010 | HP Compaq nc6000 Notebook
I can not boot my hp pavilion a1720n. I get the error message below. I have opened up the case and moved the jumper and replased the battery. Award Bootblock Bios V 1.0 2000, Award Software Inc Bios Rom...
First of all your problem is caused by the hard disk - it has died and must be replaced. Second you are booting from the wrong disk Hiren's disk is a very specialized system analysis and recovery disk, it's not a Windows reinstall one. You should use the disks that came with your pc for that, after you replace the hard disk. Finally you should check the memory sticks, the low memory warning appears only when it way low, less than 256MB. If this is really how it is then you should buy more.
Aug 08, 2010 | Computers & Internet
Windows xp wont boot and keeps restarting.
first try booting in safe mode
last if nothing seems to be working then just reinstall the windows as it seems to be that there is some preoblem with OS.
Aug 28, 2009 | Ipswitch Instant Messaging (mi-7000-0200)...
CD BOOT: MEMORY OVERFLOW ERROR
did you overclock you cmos? go to cmos again and load factory default. and try to install xp again.
Feb 16, 2009 | Microsoft Windows XP Professional
''Can't load kernel file'' error message on boot up
try to boot in the safe mode and tell me what happens
Nov 11, 2008 | Dell Dimension 9100 PC Desktop
Computers & Internet Logo
57 people viewed this question
David Payne
David Payne
