Roper washer wil drain but not spin - Washing Machines
    Master:
    Sergeant:
  • 385 Answers
Check your lid switch.
Posted on May 26, 2011
My roper RAX4232KQO washers but won't drain. What could be causing this?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 27, 2011 | Roper RAX4232KQ Top Load Washer
I have a Roper ( RAS7133RQ4 ) washer It will not spin. It does everything else. Can you help??
You say it doesn't spin. Does this mean it also doesn't drain? If it doesn't spin or drain, then you probably have a bad lid switch, if it doesn't spin but does drain, then your problem is in your tub drive clutch.
Hope this helps
kcomp1863
Jan 12, 2011 | Roper RAS6233KQ Top Load Washer
Washer does not drain and spin
If you are having a problem with your top load washer then check out this tip...
Washing Machine2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 20, 2010 | Roper RAX4232KQ Top Load Washer
Roper won't drain
doe's it go into the spin cyc if not spin the lid switch is broken
Aug 19, 2009 | Roper RAS6233KQ Top Load Washer
My washer spins but will not drain. the pump seems to be working but wont drain
The drain line is probably clogged... sometimes debris or small objects can get in between the tubs and plug the lines...if not, the pump may be bad. I just replaced my pump on my GE washing machine.
May 19, 2009 | Roper RAX4233PQ Top Load Washer
I have a roper that spins but want drain
Your drain pump is clogged.
Remove the cabinet, remove the pump and remove whatever is clogging the pump.
The pump is located in front of the drive motor.
Mar 03, 2009 | Roper RAK2751WWH Top Load Washer
Roper(whirlpool) washer will not spin model # ras7133kq1
check the motor coupler between the motor and the transmission
Mar 17, 2008 | Roper RAS8445KQ Top Load Washer
check the tub casting under the agitator or it the gearcase
Mar 17, 2008 | Roper RAX4233PQ Top Load Washer
Roper washer does not drain
Alicia7q : Faulty water pump or restriction in drain line between tub and outlet hose.
arlenekc,: That metal thing is part of the motor. What you have is a leaking water pump.
badwasher,: Check the lid switch. This machine will not spin or drain if the switch is faulty.
Oct 23, 2007 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
