I have vista on my laptop. i can connect to the router and get internet with a direct wire to the router. i can connect with a wireless connection to the router but cannot get on the internet with that wireless connection.
  • Anonymous Mar 13, 2014
    can't connect to internet/router shows error 651
    Champion:
  • 214 Answers
Hi, for setting up the wireless router, click here
thank you
Posted on Aug 16, 2008
  • 44 Answers
Check the wireless switch is on, located somewhere on the laptop. Also Vista has an automated lan setup I believe, so try and refresh the IP and connect to the wireless router which default is the name of the brand usually. If that doesn't work you can right click on the lower right bar in Vista where there should be a symbol with waves or the like. it will bring up the wireless window and if you need help read the help file.
Cannot connect to internet wireless
First things first, make sure the router you are using is wireless capable and you know the ssid and WEP to connect.
- check your wireless switch on your laptop.
- if you are using a router, try to connect it directly to your laptop to better isolate the issue.
- if its connected online wired to your router and you were able to connect to the internet, that means there's no problem with your router adn your internet connection its just that we have to make sure we got the right SSID (name of your wireless connection) and WEP (password for your wireless connection).
- you should be able to connect if those are checked
May 23, 2011 | Computers & Internet
My laptop running window 7 64 bit connects to linksys wrt160N but internet connection is not available? Connecting via wire to the same router works fine. While the internet works fine on the other...
Check the IP address on the Vista wireless network connection. Make sure that there is not static IP address on the wireless connection. That could be one of the reason.
Apr 14, 2010 | Linksys WRT160N Wireless Router
XP PC connects/Vista PC doesn't/Connectivity issues
On the Vista Computer
Goto
Start>Control Panel > Network and internet > Network and Sharing center
On the Left Hand Side Click on Manage Wireless Networks
Remove your network From the List
then
Start > Connect to> Click on ur Network > Click Connect
Dec 22, 2009 | Belkin F5D7234-4 Router
Unable to connect two wireless laptop for internt sharing
Make sure your computers are set to DHCP instead of static.
Sep 04, 2009 | Dell Inspiron 6400 Notebook
Lose Internet connection on wireless network
Go to the router configuration and change the options so you could use both of them, there is an option says only one type of connection or both of them, change it to both, and everything will be fine.
Regards
Aug 02, 2009 | Zyxel Prestige 660HW Wireless Router...
Losing internet connection when enabling ICS on the wireless network connection
Do not enable ICS on any of the computers that are connected to a router regardless if it's wired or wireless, you only need to enable ICS is if you don't have a router/server on your network(the purpose of a router is to share a single internet connection from your ISP). To connect your computer wirelessly to the router(on a Windows XP computer given that you do not have a 3rd party Wi-fi application installed) is to right click on wireless network connection on the System Tray(lower right hand side of the computer's Desktop near where the clock is) or you can do it the hard way by going to Control Panel then Network Connections and choose view available wireless network and under the list of available network that your computer can detect, select the network name(also called SSID) of your wireless router and try to connect(of course if you enabled Wi-fi security you also need to key-in the security key(WEP/WPA) you configured on your router and that's it both wired and wireless computer/devices connected to the router should work at the same time.
Nov 05, 2008 | Belkin (F5D7230-4) Router (587009)
I recently purchased a new desktop which I had linksys connected to my old pc so that my laptop would work wirelessly. Both are Dell computers. I have a Linksys WRT54G router. I have Vista and the...
I don't see why not..
are you trying to hook up both computers to your linksys router?
if you have 3 computers now... I'm assuming your old pc was connected directly to the router, your laptop was connected wirelessly and now you have a brand new computer that you also want to connect to the internet using your lynksis router.. you should have not problems doing it, wirelessly or using a wire...as long as your router has ports avaliable...
Sep 21, 2008 | Computers & Internet
Wireless problem
Hello router_lost
I believe you are correct in your assessment that the issue is related to your router. Likely, that issue involves configuration - of your router and/or your laptop computer.
(01) Is the computer that is running Vista connecting to the Internet (via the router) using a wireless network adapter or a wired network adapter?
(02) Assuming that the Vista computer is connecting to the Internet wirelessly, please, tell us the manufacturer, model number and version of your router.
If the Vista computer is connecting "wired" and not "wirelessly" AND you have no other devices on your LAN (home network) that are successfully connecting to the Internet wirelessly through this router, then, it's possible that the router's radio is not enabled. However, if the laptop is "seeing" your router, then, of course, that isn't the case.
(03) Are you sure you are attempting to connect to the correct wireless router from your laptop?
I've seen it quite often where users will think they're connecting (or trying to connect) through their own router when, in fact, the router is a neighbor's (not their own).
(06) You can avoid this possibility by assigning an unique SSID to your wireless radio. In other words, change the SSID (wireless router's "name") to something other than the manufacturer's default SSID. (e.g. Netgear's default is "netgear" and Linksys's default SSID is "linksys", etc.)
It's best, for security purposes, not to assign a revealing SSID (e.g. "TheSmiths" or "2201YourStreetName", etc). Call it "BlueMoon" or whatever you like. Just something unique yet not revealing of your identity or location.
(07) Please, tell us the manufacturer, model number and revision of your router.
(08) Please, tell us the manufacturer, model number and serial number (or service tag) of your laptop computer.
(09) Please, tell us the operating system that is running on your laptop computer.
W/ this information, we'll be able to provide you with specific instructions for correcting your laptop's connectivity problem at home.
(10) Do you know if you have WEP or WPA encryption enabled on the router?
If you do, then you will need to enter either the router's wireless encryption "password phrase" or the hexadecimal key code password in order for the laptop to be allowed to access the Internet. You should only have to do this one time - then your computer will save the information.
If you've been connecting to free networks fine, then you've likely not been required to enter a password phrase or key in order to connect.
Please, post back here w/ answers to the questions I've asked here along with any other questions, comments, and observations you might have. We'll continue to work w/ you on this issue until it's resolved.
Thank you
BJ @:)
Apr 15, 2008 | Computers & Internet
Wireless internet connection
I may be able to help with this...but I need a detailed description of how you have things connected between the XP desktop, the cable, modem, the Linksys router, and the laptop. Also, is the Linksys router new?
Typically, the wan port on the wireless router connects directly to the cable modem with a cat5 network cable....then the desktop pc connects to the router...on port 1 for example...with a similar cable. Once the wireless router is set up properly, the laptop should then be able to connect using wireless.
Feb 01, 2008 | Computers & Internet
Wireless connection
Hi, I am going crazy! Just moved house and took my Netgear Wireless router with me. However, even though the hard wired base unit works, my wireless laptop can't access the internet - even though a full stregnth signal is there when i browse for wireless connections. Using Vista Home Premium. Help appreciated!
Dec 29, 2007 | NetGear WGR614 Wireless Router
Computers & Internet Logo
70 people viewed this question
David Payne
David Payne
